Question about Samsung CLP-500 Laser Printer
Jam in Exit Area
This message will not go away and I cannot find the source of the jam. There doesn't seem to be any way of accessing the top area to see if there is paper caught in there. I've tried everything I can think of and I still can't get it to work. Any assistance you could provide would be greatly appreciated.
There is a little pin at the top of the heating unit of the printer sometimes that pin breaks off and the printer cant pick up that there is paper that slides over the heating unit and tells you that you have a paper jam
Posted on Jun 18, 2008
On the top of the printer there is a button that you need to push down which releases the lock on the paper outfeed. If you put your right hand on the paper outfeed and pull up on it when pushing the button it will open and that just might be where the paper jam is located.
Posted on May 17, 2008
  • 161 Answers
You can also check the paper size settings in your application when printing. If the printer has leeter size paper and the application sends a legal size document, the same error occurs. Microsoft applications do not create this error, but other such as Wordperfect do, for Wordperfect paper settings bypass your Windows or printer settings.
Posted on May 28, 2008
Code 077-106 in docucolor 252
Hi
This error code indicates a jam either in the fuser exit area or in the final exit area so I would check these areas for a small bit of paper that may be sticking on one of the jam sensors in this area
Cliff Cook
MCP
Aug 01, 2014 | Office Equipment & Supplies
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Hp laserjet pro 400 paper jam in cartridge area
One of my customers has roughly 100 of these pro 400 in service. Many of the constantly display "Jam in cartridge area" We have found the message is not related to any part of the cartridge area. The exit flag spring in the back of the fuser seems to be lightly wound. Carefully turn the end of the spring that rests on the plastic ( closest to you when looking at it) one full turn over the top of the pivot and re-secure back on the piece of plastic. For safe measure, bend the tip of the spring down the piece of plastic so it won't unwind. Secure the tip with a small amount of glue. We dis this to all of the machines in question and have not had a single problem since
/uploads/images/8_13_2014_3_21_55_pm.jpg
/uploads/images/8_15_2014_7_14_32_pm.jpg
Mar 20, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
Scan unit open or paperjam 2 message in Samsung CLX- 3185w
Please close the top cover (is just above the paper exit area)
Jan 31, 2013 | Samsung Office Equipment & Supplies
My Brother Intellifax 5750e has paper jam issue. The paper jam sign will not go away. I took out the paper that was jammed. Still problem.
take your drum unit/toner out and close door to see if "jam" goes away. if so, look closely on bottom of drum unit in the middle. may be a scrap caught in there. if jam doesn't go away, you may have a piece caught in the fuser which is just b4 paper exits and that area is not easily accessible w/o tearing machine down.
good luck,
razors
Jul 28, 2011 | Brother IntelliFAX 5750e Laser Fax
Error: open upper cover exit jam
Feed Jam or Exit Jam ecblank.gif ecblank.gif dot.gif ecblank.gif 1. Remove the tray and clear any misfed sheets as given above.
2. Open the top cover.
WARNING! The fuser area will be hot. This area is clearly marked. Do not touch it.
CAUTION! Never expose the image drum unit to light for more than 5 minutes. Never expose the image drum unit to direct sunlight. Always hold the image drum unit by the ends or from the top. Never touch the surface of the green drum inside the image drum unit.
3. Carefully lift out the image drum, complete with the toner cartridge. Be careful not to touch or scratch the green drum surface.
4. Remove any jammed sheets from the paper path.
5. Re-install the image drum complete with toner cartridge, ensuring that it correctly locates into the slots on each side of the printer.
6. Close the top cover and press down to latch it closed.
7. The printer will warm up and commence printing when ready. he page lost through the jam will normally be reprinted.
NOTE If the edge of the jammed paper protrudes (or can be seen) from the exit, reinstall the image drum, close the top cover and switch the printer on. Remove the jammed paper from the exit when the exit roller begins rotating after a few seconds after switching on. However, if the jammed paper cannot be removed, contact a service representative.
Mar 12, 2010 | OKI B4350 Laser Printer
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Samsung 6210 paper jam
open access(load area) check feed roller take a q tip and use rubbing alcohol and clean photo eye that detects paper be sure all jammed paper is removed
most jams are at the exit and there may be some paper obstructing that area
insert card stock through the paper path
insert ine
Dec 30, 2008 | Nikon COOLPRINT Thermal Printer
Canon D880 Printer/Fax
1. Take off 3 plastic covers one above exit area-slide top to left to access screw
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
plastic heater membrane. remove paper jam and reassemble.
Nov 15, 2008 | Canon imageCLASS D880 All-In-One Laser...
Samsung CLP-500 Laser Printer Logo
241 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
