Question about Garden
Is there any place that I can obtain parts for a McCulloch F1250 electric pressure washer? I need a new gun and a hose shut-off assembly.
CRTN
  • 716 Answers
SOURCE: High pressure hose connection blew up. Fix? or buy new?
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Posted on Mar 11, 2009
  • 15 Answers
SOURCE: builds up to much pressure in hose and stalls engine
Sounds like the unloader is not working. try replacing it and see if that helps.
Posted on Apr 23, 2009
  • 25 Answers
SOURCE: paslode 900420 piece fell out
Be sure to remove the metal nose piece that covers the lockout bar when assembled. It may be stuck to the other half of the gun. Replace the bar and the spring and put the metal nose piece in its position over the lockout bar. At this point the metal nose piece will be on the opposite side. This will allow you to replace the 2 halves carefully so as not to loose the spring.
woobie dog
  • 1273 Answers
SOURCE: no pressure
It is probably air locked....Here's what you need to do. Connect the garden hose, and HP hose, but not the gun. Turn on the water, and let it run while you make sure that there are no high points in the garden hose that can trap air....Work the hose so that any air is displaced through the pressure washer. Continue in this manner through the HP hose. Shut off the water and connect the gun. Turn the hose back on, and operate the gun for several minutes, pulling the trigger and releasing. This alternately allows the water pressure to build up on house pressure and then to depressure, pulling residual air from the system. Release the trigger, and start the machine. Usually, this is enough to get full washing pressure. If it is very difficult to start, you can hold the trigger down on the gun and pull the start cord at the same time. Holding the trigger down acts as an unloader, making the starting easier.
Hope that this helps, --W/D-- please feel free to rate this solution! Thanx!
Posted on Jul 31, 2009
SOURCE: Simoniz s1900 electric power washer with no water pressure
What a jacka$$ response.
Do you think its the seals? wow that describes f**Kall!!!
Posted on Sep 03, 2009
Where can I get a gun and hose wand for a fhh 18A McCulloch power washer?
from a mcculloch service agent
check that other brands do not have the same fittings as they may be cheaper or available on e-bay if oem is too expensive
Sep 26, 2016 | McCulloch Garden
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    Trigger don't release
    I have a hose and gun that fits the McCulloch FHH18A that I no longer need as I had to buy a complete universal hose/gun and wand unit since I had broke the wand and the replacement wand was no longer available. If you are interested in it, email me at burmakow@nwciowa.edu and we can figure out a price.
    Apr 28, 2012 | McCulloch FHH18A Electric Pressure Washer
    I have used the McCulloch (FH180A) three times over the course of two years. On my fourth use the pressure washer just surged on and off and I would get a tiny spray from the gun each time it surged. In...
    Sounds like the problem could be low input water flow or pressure. There could be crud on the intake where you hook up the garden hose, there could be some other sort of blockage. Try hooking it up to the hose and pull the trigger (with the power switched off) and wait to see if water comes out the tip. Also look at the tip(s) themselves. sometimes a piece of crud gets into the hose and then clogs the tip.
    May 15, 2011 | McCulloch FH180A Electric Pressure Washer
    Where to get a replacement gun
    Best place for replacement parts for many different brands of pressure washers is WWW.Northerntool.com . on the net or at your local Northern tool store. Most washers use standard fittings. The only info that you need is pressure and gallons per min rating. You can purchase a higher quality hose with very high pressure rating however you must use same size gpm tip to obtain proper pressure. Good luck
    Mar 08, 2011 | Psi Blue Max 2200 High Pressure Gas Power...
    Removing lance from gun on McCulloch FH140A pressure washer
    The Karcher is the same, and possible made the Mac. It's likely the sealing 'O' ring has deteriorated and stuck the two parts together. Try a little petrol around the joint to soften the 'O' ring. Perhaps it will come apart then. You will need a new o-ring however.
    Apr 20, 2010 | McCulloch 1400 Psi Electric Pressure...
    Where can i get a new hose for a1600 psi jet washer? Hose has a leak in it and we are not having any luck finding a replacement locally. Washer was purchased at either walmart or Canadian Tire.
    I have an older Karcher Pressure Washer and I am unable to find the model number. This is the info that I have: 79C2, Volume 1.9, Pressure 1400, Serial # 800983493B, 120 Bar, 60 degree C,
    QC506-877. I need the model # to order a replace gun and/or wand. thank you
    Jul 14, 2009 | McCulloch FHH18A Electric Pressure Washer
    What are the steps to use Mc Culloch FHH18A powerwasher? What is the liquids I should use?
    Hello awseibel:
    1. attach your garden hose to the inlet (at the back I believe)
    2. Attach high pressure hose with gun wand/nozzle
    3. turn on the water
    4. plug into electrical outlet
    5. turn on/off switch on
    6. spray away
    7. Any non-caustic soap can be used
    8. You must set the machine on low pressure to apply soap.
    Jul 05, 2009 | McCulloch FHH18A Electric Pressure Washer
    Pressure washer leaks
    I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
    ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
    May 25, 2009 | McCulloch MCCFH180B Electric Pressure...
    Garden Logo
    54 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
