Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
"I have a 3 year old 19"self propelled john dere mower and have had to replace the needle bearings on the drive and told they had rusted due to me washing the mower down (*********) I have never in my 60 years of grass cutting had this problem with any other make mower and advised to wash them down. Are your products inferior?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
You are one of the unfortunate ones who purchased the John Deere BRANDED push mower.Deere's upper managment decided to use a lesser quality mower made by someone else and slap their logos on it,all to save some $.In all my years with Deere I have never seen so many pushers come back for warranty work.Look on the net and you will find your exact mower a different color for 40% less.
Posted on Sep 07, 2010
Why does a transmission on a self propelled john deere 14SZ mower ,18yr old, squeal?
Is it the transmission or is it the drive belt slipping.
That will make a squealing noise as well.
Is the fluid up where it should be?
Sep 28, 2014 | Garden
How do you install a split hex flange bearing?
The split hex flange bearing fits on the front axel assembly of the Troy-Bilt self propelled mower. To install it, remove the front wheel to see if you can access the old bearing and pop it out of its position on the assembly. If you cannot reach it, you'll may to detach the axel assembly from the mower itself. You'll find the old bearing behind the plate that attaches to the mower frame. You may have to remove a nut that holds it in place, then remove the flange bearing itself. Put in the new one and reverse the procedure.
All that being said, it's hard understand how you would know that the split hex flange bearing needs replacing if you haven't already disassembled the axel assembly to check its condition. If the bearing, itself, just fell out and someone told you what it was, he should know how to replace it.
This bearing should rarely need replacing. If it does or if it just fell out then you likely have much bigger problems than just replacing it.
Jul 26, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Lawnboy self propelled walk behind mower
a drive that old is going to be hard to repair so it generally not worth it
Sep 11, 2013 | Garden
Our troy bilt self propelled lawn mower is about 8 years old and has served well. However it has developed the following problem: requires extra priming to start and then dies....will not remain started....
The float and needle need replacing. Take the carb off soak in a high octane gas or booster for 15 min. The float isn't floating in the gas bowl, which rises the needle to let more fuel in. When you prime the carb, you are directly shooting gas to the carb, this is why it will start and then shut down because the float can't keep gas flowing in. A kit cost about $5-7 and easy to replace.
Apr 19, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
MTD front wheel drive self-propelled 21". Self-propelled does not work. Can it be fixed?
Yes it can be fixed. Try some basics first.
1) Check under belt drive cover for excess debris
2) Belt and Idler pulley condition
3) Control cable operation
a) rusted, frozen, broken, disconnected
Dec 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Troy Built 6.75 Self Propelled to Slow
put oil or grease all the shafts and bearings inside and out, if possible adjust the cutter blade contacts.
May 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
125 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
