Indesit 825, drum only rotates in one direction. is it an easy fix?
  • 487 Answers
Normally it would suggest that the motor needs to be rebuild.
You can do it yourself it you are a little bit technically inclined
Posted on May 13, 2008
My indesit dryer just makes a buzz for 1 second, it wont start ?
Check the lint filter and for any blockage at the blower fan and motor.
Dec 19, 2011 | Indesit IS70C Electric Dryer
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
Indesit 825 front loader, broken down.was spinning then loud nois
try and move the drum, if it is loose with excess up/down movement then the bearings/spider have gone. was there any leaks, did the fuse trip out?
Mar 16, 2009 | Washing Machines
Bearings getting noisy
no need to remove the drum
u just unscrew the screws and spyder wil come and u can change the baring
Mar 07, 2009 | Indesit W 123 Front Load Washer
Indesit wil103 makes LOUD banging noise on spin cycle
The two dampers that fix to the outer drum casing have plastic bushes that can fall out. Check the floor under the machine, They are easy to replace just click in place.
Jan 26, 2009 | Kenmore 43052 Front Load Washer
My indesit WG1230 washing machine does not spin or move drum but water go in and out.
With the door open, try spinning the drum, there should be some resistance along with a slight wherring sound. If it spins freely without much sound at all - you probably need a new belt.
If you can feel it driving the motor, you may need new contact brushes for the motor.
If the machine buzzes when it should rotate on program, you need a new motor Run capacitor also.
If no sound - nothing, the motor may need replacing or at least checking.
Nov 05, 2008 | Indesit Washing Machines
Indesit wash machine drum bearing
depends on the model that you have some indesit machines you only have to undo the spider and others can be a bit of a pain because you have got too split the drum would recomend an engineer regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine
Sounds like belt has fallen off!
Mar 15, 2008 | Indesit WA 125 Front Load Washer
Indesit wg 1285w
Replacing the capacitor might solve your problem. Good luck!
Aug 30, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
