Question about Whirlpool Refrigerators
Whirlpool Quick-Chill Frost Free Model WRN A 258 R 20 10 years old I want to purchase Transparent Vegetable bin with easyglide for above model. Please let me know the rate in Rs.and how can I get it. My Address:- U.Varghese, A-7-501, Swastik Residency, Ghodbunder Road, Thane - 400 607. Tel.09869120485, 09987521424, 02225972189
zeusfaber
  • 247 Answers
SOURCE: fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
Posted on May 16, 2007
ifican
  • 14 Answers
SOURCE: too cold in vegetable bins
Air flow ports adjusted correctly? Air flow fan running? I once had a bad temp sensor on the freezer coil that would not let the fan run.
Posted on May 29, 2008
  • 3 Answers
SOURCE: Bosch intelligent frost free 44
there is a drain hole in the freezer dept in the fridge that is blocked This requires removing all the panels etc within the freezer until you get to the main grill at the back This will be iced up so you might have to wait a while or you might be able to chip away at it. You will then see the drain hole concerned at thre bottom Try pocking a thin wire down it or poor hot water over it Its a bit of fiddling around but is not hard to clear Problem solved
Posted on Feb 28, 2009
  • 11 Answers
SOURCE: Water in bottom of refrigerator under vegetable bins.
there should be a tray that guides water from freezer to a drain located in the fridge section normally held with one screw . take it off and unclog drain ( use a vacuum to **** out sludge) clean tray/guide and mount back on. make sure all moisture is cleaned out after drain is cleared.
Posted on Jun 20, 2009
woodchuck789
  • 4059 Answers
SOURCE: Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 21, 2009
Sears Kenmore refrigerator 18cu frost free. Water constantly flows down the back of the fridge and collects under the vegetable bins. How do I fix it?
sounds like the drain pipe is blocked. turn it round and at the bottom there is a pipe check its not blocked. to clean out use an old curtain wire or something that can get up the pipe and flex.
Nov 03, 2013 | Kenmore Refrigerators
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water is collecting under fruit and vegetable bins and then leaking out onto kitchen floor.
sounds like a problem with defrost drainage system. would need model #. older GE refs had problem with rust holes in drain trough. how old is it? do you see any rust on back wall of ref? newer refs had problem with drain hole freezing shut and heat probe had to be installed to prevent it from freezing shut.
Jan 05, 2010 | GE Profile 24.7 cu. ft. Top Freezer...
Freezer has alot of frost build up and the refrigarator has water leaking and running under vegetable trays in bottom and freezing what could be wrong It is a whirlpool top freezer 21 cubic ft and is 2...
Hi, this sounds like a problem with a blocked defrost drain. For full instructions on clearing the drain from my tips click HERE . If you have any other questions please feel free to comment. Mike
Dec 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Sep 21, 2009 | Refrigerators
The freezer section is working ok but the fridge is not cooling. about a year ago the heater element was replaced. The model is whirlpool WRN 38 WG6 362L
hi..you may have a coolant leak and need it repaired
and recharged.
check this out..
thank u..
kindly rate my response..
Jun 14, 2009 | Refrigerators
Water in bottom of "fridge" and in vegetable bins
Hi: I'll assume this is should be a frost free freezer. If so the defrost drain is clogged and the water isn't getting to the evaporator pan. Without knowing the specifics although it sounds like a top freezer. Look for a drain below the evaporator coils. The will be in the back of the freezer behind a panel. Some models have a drain hose behind the ref. Use a strong solution of clorox and water to clean it out. The parts list or diagram of the fridge will help you find the drain. If you don't have it enter your model no. at sears.com parts direct. I hope this helps, Jeff
Jun 02, 2009 | Refrigerators
I have whirlpool refrigerator. it is a frost free double door model. Recently I have found water is dripping from the top of the fridge portion. It directle falls on the vegetable drawer and water is...
It is over charged with gas. but that will probably leak out again in a few months don't worry. The leaking water are most probably because the drain hole inside the refrigerator is blocked with algae growth.
Sep 30, 2017 | Whirlpool 24 7 cu ft Frost Free Upright...
Too cold in vegetable bins
May 29, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
59 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
