Question about Reliance & 40 Gal Electric Mobile Home Water Heater
My dad lost the manual to his 606 Model # 640DORS. We can't figure out where you change the temp.; the person who installed it several years ago, turned the temp. way down, and in the winter, it doesn't cut it for showers, dishes and laundry. It can take 3 hours to do dishes and get in a couple of showers. We need to turn the thing up! Thanks for your help.
  • 518 Answers
Remove access door usually on upper side of unit. Will need to unscrew retaining screws. Under cover is a thermostat that you can adjust to your liking. Reattach cover when done.
Posted on Sep 06, 2010
Hot water tank wont heat water, how do you relight or resat, its a reliance self cleaning 808
Reliance Water Heater Literature ' Owner's Manuals ...
www.reliancewaterheaters.com/resources/instruction-manuals
Welcome to the Reliance Water Heaters Owner's Manual and Installation ... 9 40 EKRT - 40 Gallon Tall Self-Cleaning Electric Water Heater - 9 Year Warranty . ..... 10 50 DHPST - 50 Gallon Electric Heat Pump Water Heater - 10 Year Warranty .
How to light the pilot on a Reliance 606 water heater ...
? 3:27
https://www.youtube.com/watch?v=VU2PsFVd2ug
Jul 12, 2011 - Uploaded by kilroywashere123
How to light the pilot on a Reliance 606 water heater ... How to fixwater heater, will not stay lit - sealed combustion no hot water - Duration: ...
Reliance Water Heaters - Consumer Affairs
www.consumeraffairs.com > Homeowners > Bath & Plumbing
Rating: 1.6 - ‎84 votes
I purchased a Reliance 606 water heater in 2010. ... That they don't TELL you there's areset button or that I'm having conspiracy thoughts ... After several attempts, I was able to relight it. ... It's heading to the junk pile and I will purchase a new reliable (NotReliance) ... Checked breaker and changed breaker still no hot water!
Dec 28, 2015 | Reliance Water Heaters
End of my rope, tried everything I can think of.
check power from t-stats to elements
dont try any power without being full of water
elements will burn out
Nov 02, 2015 | Reliance 606 Series 40 Gallon Electric...
How to change thermocouple on model 640YORT
I believe that is a Reliance 606, ehow has instructions on how to change the thermocouple.
http://www.ehow.com/how_6579030_change-reliance-606-thermocouple.html
Aug 24, 2014 | Water Heaters
The reliefe valve opening on my reliance 606 gas water heater is hissing. what could be wrong?
thermostat.Check Settings,and if you turned it up or down while power was still on, thenchange them both. also t+p valve may be weak from temp overshoot.Change it if it continues after replacing thermostats
Aug 21, 2014 | Reliance 606 Series 40 Gallon Natural Gas...
Hot water not coming out
Tank-type Electric water heater?
Press reset button.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add comment and describe water heater, and more detail about problem
Mar 30, 2013 | Eemax "Flow Controlled" Electric Tankless...
I have a 640dors reliance capacity40 water won't stay hot long(electric)
remove the two covers one high and one low and set the temp higher. This time of year with colder water comming in the house the water heater has to work harder to raise the temp of the incomming water. In the summer the incommong water is much warmer. 40 gal is a small water heater and you will only get about 15 gal of hot water with the ice cold water entering the water heater as you use the hot water. You can get a bigger water heater. even better is to go tankless and a have never ending hot water and save money at the same time.
Jan 10, 2013 | Reliance & 40 Gal Electric Mobile Home...
Model 606. Water temp. extremley hot enough to burn, Both therm. set to lowest possible
your thrmostat has been short circuited, replace it immediately and plz dont use the heater before you replace the thermostat of u r machine....its dangerous!!
thx :)
Nov 27, 2010 | RELIANCE ELECTRIC WATER HEATER
How to change a thermostat on reliance 606 hot water heater. water is getting too hot and there is no sediment build up. also water heater is only 4.5 years old.
I wrote a page for changing water heater thermostat.
The photos take you through step-by-step
I recommend replacing both upper and lower thermostats so it eliminates thermostats as possible cause if water heater keeps overheating.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
The Reliance 606 manual shows your water heater uses generic upper and lower thermostats from hardware store.
http://www.reliancewaterheaters.com/lit/om/manuals/185761-000.pdf
Likely the thermostat will solve the problem:
Nov 09, 2010 | RELIANCE ELECTRIC WATER HEATER
Pilot won't stay lit in Reliance 606 gas water heater
The Reliance 606 has an enclosed thermal couple. Before you try taking that assembly apart take a wire brush to the bottom opening directly under the burner. There is a metal filter on the very bottom of the water heater. It could be that the filter has gotten filled with dust or animal hair. It took a serviceman 2 days to figure this out for me. The water heater has to have good airflow through that filter to work well.
Feb 13, 2010 | Reliance & 50gal Electric Water Heater
Reliance & 40 Gal Electric Mobile Home Water Heater  Logo
171 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
