My lAptop will not charge if the mains are plugged in. I have no indication that the laptop is charging.
  • 382 Answers
A battery normally lasts about 2 years before it goes. Take the battery out and leave the laptop on mains and turn on the lappy.
Make sure the metal connectors on both laptop and battery are clean and then put the battery in. If the computer indicates charging then likely you've just a loose connection somewhere else the battery is dead.
In most modern laptops they have a battery checker in BIOS which will tell you if the battery is gone or not.
Posted on Sep 06, 2010
Battery indicator on my acer aspire 5517 laptop is blue what does it mean
Acer Aspire 5517 shows BLUE light when fully charged.
Start it and check battery indicator (tray item) will probably say
plugged in fully charged (with adapter plugged in)
Dec 07, 2013 | Acer Aspire 5517 Laptop
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
The battery on my c650 laptop has a charging problem
Your battery may not be securely in the laptop.
You may also need to purchase a new laptop battery.
I would go to ebay or amazon to find a decent priced laptop battery.
Aug 26, 2012 | Toshiba Computers & Internet
Lenovo G550 battery shows fully charged but when you unplug the laptop, the laptop shuts down and will not start up again until power cord is plugged back in.
Shows a clear indication of the battery to be faulty. So in the first place remove the battery and checck the voltage, now keeping the battery off the laptop, plug the adaptor to the mains, Now checck the voltage in the battery terminals which is in the battery compartment. If voltage is present then the battery is bad as it is not charging.
However if there is no voltage then the main board has a fault in the charging section which must be looked into.
Oct 28, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Y laptop will only work on mains power. When I put in the battery, laptop shuts down.
This is either a problem with the battery or the motherboard.
If you can find someone with a similar Toshiba you can try their battery in your laptop, if it works then it's obviously a problem with the battery itself and you'll need to order a new one.
If it doesn't work then it's a motherboard problem which can be pretty expensive to fix (hopefully you're still under warranty)
Aug 21, 2010 | Toshiba Computers & Internet
My laptop won't charge when plugged in...I changed the charger but still won't charge
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or:
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or:
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
Feb 06, 2010 | Acer Aspire 5500 5570-2609 Laptop
Laptop wont charge at all, or turn on
hey friend . .
this indicates that your battery is finished just go and buy new or
the battery need a repair . . . its charged is over . .
Oct 06, 2009 | Computers & Internet
BATTERY is charged, but will not work without being plugged in
Your battery is old and worn out, even though it indicates as fully charged. The battery capacity is practically zero. Rechargeable batteries have a finite number of charge and discharge cycles.
You need to buy a new battery if you wish to use the laptop without connecting to the mains.
Dec 01, 2008 | HP Compaq Evo n610c Notebook
Battery is showing its there and at 82% and charging but not charging and laptop crashes when mains fails ?
The laptop's battery might be weak to hold the laptop. The indicator will indicate the battery is ok, but when mains is removed there, it goes off. Try swtch on with only battery and see if it goes on and then off, it is the battery that is bad.
Nov 14, 2008 | HP Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
