Question about Dishwashers
A few days ago the dish washer was running fine, maybe a single wash every day. Then, out of no were the logic seems to have left the machine. If you pressed the "normal cycle" button it would blink for about 30 to 45 seconds then the front panel would go blank. All LED lights would turn off, like it finished doing the diskes, never running a single cycle. I unplugged the machine to let all circuits reset, that worked for two days, two washes in that time. Today I'm back to a machine that will not run a cycle correctly. If Press the normal or quick wash the machine just blinks that led then goes black, no LED's light. Right now it thinks it running a " Smart Cycle" and it's pumping out water that is no longer in the machine, again it would appear to have lost it's logic. Maybe the front panel where the buttons are had moisture get in there and has screwed up things. Just a guess.
  • rich_harmon Sep 06, 2010
    I was leaning in that direction. Just have to find and order that part now.
  • 11,896 Answers
Your control panel is faulty and will have to be replaced. This is the main brain of the machine. Normally when a cycle doesn't start the timer is bad, but when your control panel doesn't do anything, then it is faulty.
Posted on Sep 06, 2010
  • Nate Stansfield
    Nate Stansfield Sep 06, 2010
    try daysappliance or partselect . com
Why do the lights throughout the house pulsate when the washing machine starts agitating?
What make and model washing machine? How far is the breaker box from the washer?
Mar 24, 2017 | Washing Machines
Bosch SHX33A05UC/36 dishwasher seems to run for hours to do a load of dishes. Checked water temperature, drain and hose and all is clean. The rinse and hold cycle times out correctly. Is it a timer or...
No, the problem in not the unit, it is programed to run up to 3-3 1/2 hours for a single cycle. You can select quick wash to shorten this time down, but this is not a problem with the unit. It wants to assure you have clean dishes and hot enough water to complete the program.
In testing one a few days ago, I ran into this same problem, I reread the time charts and cycles and found this to be normal for this manufacture.
I hope this answered your question.
Aug 13, 2011 | Dishwashers
Washer Froze, Spin Cycle Sounds like Jet Engine
when it goes into a high spin does it sound like a freight train in your house if so your bearings are going bad
Dec 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Dishwasher not pumping water
anti flood mechanism activated in base pan you have a leak once the anti flood is activated in puts the machine into permanent drain thats why it runs even with the door open but only runs the drain pump not the wash pump.
Mar 01, 2017 | Bosch 24 in. SGI43E05GB Built-in...
My Bosch Classixx washing machine has been failing to take up the fabric softener for a few days now. The drawer is left full of water after the wash. I've tried cleaning everything with bottle brushes,...
you have a clog somewhere in the system drainage hoses or threw water passage pump
run the washer machine with some liquid draino washer version to unclog what is clogged they make this for washer machines
and once done there running a cycle of washer draino make sure too run bleach in your washer to finish cleaning cycled out make sure there are no kinks in the hoses this will also hinder the draining
May 29, 2008 | Washing Machines
Slow leak in our HE 3T Washer?
khorak, I've seen this on this model a bunch of times. The inlet valve is weeping water. You need to change it out. The top has 3 screws in the back and it will slide off toward the back. The valve sits on the left side, right up on top. Easy job, part number is 8181694. Catriver
Jun 23, 2007 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
83 people viewed this question
Top Dishwashers Experts
Owen Barnes
