Acheiver 10 series has stopped working completely. Nothing powers on unit. What is firstthing to check?
    New Friend:
  • 50 Answers
First check the continuity of the plug in the unit.. did you try to plug it in other outlet? if the unit will work in other outlet then check the breaker of the outlet that is not working,,
Posted on Sep 06, 2010
Rudd acheiver 10 heat pump wont stay cool
did you change the air filter and do not set it below 70,the tstat is not a gas pedal its works like a light switch, on or off, also please don't use your breaker as a switch its a safety device and will be damaged over time,If the unit starts to form ice (and it should never do that)
set the tstat from cool to off and the fan button from auto to fan on,this will speed up the thawing
Jul 02, 2013 | Ruud UBHC Air Conditioner
No signal
Hi my nameis Mike Houston of DISH Network and I see you're not getting signal. The firstthing you want to do is make sure the dish is clear and then unplug thereceiver for 10 seconds and plug it back in. The receiver will power back upand acquire the signal and download the guide, if there still is signal lossplease press the buttons of MENU-6-1-1 and select Check Switch and Test. After theentire test completes please exit out of all menus and let the receiver reset andthen you will have you're programming, if you have any questions please e-mailme at michael.houston@dishnetwork.com.
May 02, 2011 | DISH Network ViP722 DTV Receiver /...
The main unit will not connect with the remote. I have tryed everything that the manual has said to do.. But it just won't work.. They seem to be working but not comunicating with each other..
The WS20 has very poor engineering.
1. Open battery compartments of all remotes and the base unit.
2. The following steps must be completed within a small time window of a minute or two.
3. Remove and replace one battery from the base (reset button on base may also work)
4. Remove and replace one battery on first remote.
5. You have 10 seconds to set the channel number, suggest you set channel 2 first if you have 2 remotes. Once you stop setting the channel on the remote, 10 seconds later remote 2 should sync with the base.
6. Remove and replace one battery on second remote.
7. You have 10 seconds to set the channel number, if you have only two remotes do nothing and it should synchronize 10 seconds after you replaced the battery as remote number 1.
8. If the base unit can receive the time signal from Colorado USA, it should eventually get the time and date correct, give it time. Alternatively you can set the time and date manually. However, if the base is trying to get the time signal, most of the controls freeze up, to unfreeze them press and hold the + button for something like 5 to 10 seconds, then the unit should be available for manual setup.
If you loose connection to one remote or change batteries, repeat all of the above.
In summary, it a POS unit .... :)
Dec 27, 2010 | Alert Works Enhance Living Series WS20...
Rudd Acheiver 13 nothing turns on outside but the fan inside is
Try pushing the red reset button at the outdoor unit near the brass service valves (where the refrigerant lines enter the outdoor unit). Also check for power from circuit breakers furnishing power to the outdoor unit ( the indoor unit has a seperate power supply source ). There may be fuses in the service disconnect box mounted near your outdoor unit. If those "blow" they will prevent operation of your outdoor unit. You can test continuity using an ohmmeter. If you do not have an ohmmeter, you can take the fuses to the local hardware store. They should be able to test them for you and offer replacements if needed. If after doing all these steps you continue to have problems, let us know and we will dig a little deeper. :-)
Apr 18, 2010 | Ruud UBHC Air Conditioner
Hi I have a Marshall avt 150 head and it has stopped working completely, no light on nothing no sound I checked the back power lead is in and still nothing, I know it is a vague question but can someone...
first check for blown fuse, near the mains power input terminal. if thats not the case and u dare not open the unit, get it fixed by a qualified tech.
u have a blown power supply unit.
Mar 13, 2010 | Audio Players & Recorders
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
