Question about Giorgio Armani Emporio Armani watches AR2413 WW Watch for Men
The watch fell and the back fell off but now it wont go back on
How to put hands back on battery operated wall clock
put the smallest one on first and the longest one second
Oct 18, 2015 | Watches
Tip
LOST SOUND AFTER BATTERY REPLACEMENT.
If you experience no sound (alarm) from your watch after battery replacement, that means the coil spring fell out of watch while the battery has been replaced. Coil spring is transmitting vibrations from watch movement to the sound membrane at the back cover of watch, and if it is lost, there is no physical body to transmit signal, thus no sound. Coil spring itself is quite tiny and can be easily lost without even noticing it, mostly because it is not soldered to the watch movement or sound membrane and as soon as the opened watch is turned over, the coil spring fells out. If you are not able to find the coil spring in/around the place where the battery change took place, there is no other solution but to visit your nearest watch repair shop and ask to fit new one. In case if you are lucky enough to find the coil spring, fit it back in to appropriate hole in watch movement inserting out-bent end into movement. In most watches coil spring holes are marked: C.SPRING/COIL SPRING/ C.S or similar. Hope it helps.
on Mar 31, 2010 | Watches
When replacing the battery in my Citizen 8946-095604-ta a small spring fell out ,could you please tell me where it goes, thanks
it goes in a small hole in the back of the movement of the watch and connects to the back plate when replaced to operate the alarm.
Nov 28, 2012 | Casio G-Shock GW500A-1V Wrist Watch
How do i get a replacement pin that goes on the clasp that locks and unlocks the watch band. Mine fell out and it wont stay closed now
mcdevito75 here, Your best bet is to visit a small watch repir shop in your area, I believe you"d need a spring bar type pin in the clasp and without the watch inhand sizeing the pin would be difficult.
Sep 21, 2010 | Fossil College Kaleido Alabama Kaleido II...
I need a new crystal
mcdevito75 here, Yes it can be replaced or placed back in your watch. Visit Repair Services here on fixya, right at the bottom of the page, Click on repair services the watches.
Jun 20, 2010 | Anne Klein AK Diamond Accented...
My timex watch back wont close, it fell and popped open, I put battery back in place but now wont close, jeweler tried closing it with machine thing, it wont close.. it has gray leather band with...
If the jewelers equipment will not close it, you have only one option, you must send it back to the maker (see the Timex web site for your nearest service center).
They should be able to fix it. It could be that the watch IS dented (it wouldn't take much to ruin the fit).
Discuss your problem with the service center before sending it to them.
If the maker can't fix it, then you could always use impact adhesive but you would not be able to replace the battery when it dies. No watch later might be better than no watch now!
Jun 15, 2010 | Timex Expedition47761 Wristwatch
A metal jewel fell off of the watch face and is loose on the dial
I suggest you take it to a watch shop and ask them to repair it for you.
It can be more difficult than it appears to remove and replace backs particularly.
Feb 25, 2010 | Watches
Connect metal strap to watch
If it brok at the hinge where the strap connects to the watch itself, then you might just need to replace the clip that slides in. Its a little metal tube with a spring in it. You should be able to find them at any retail shop. If all else fails, take it to a shop or jeweler.
Mar 11, 2009 | Swiss Army Wenger Sportedge Bracelet Watch
Can't get back back on Kenneth Cole KC3271
there is aspecial tool to replace watch backs if it wont click back on with fingers dont press too hard you might break the glass. walk into a shop that fits batteries and say you got it done and it fell off. maybe a small family jeweller would be best. if this helps please rate
Nov 14, 2008 | Kenneth Cole KC3271 Wrist Watch
Need Help
Please call 1-7187298600 X272 geneva watch customer service
and order a case back for kc1169, it will cost $4.00.
Thanks
Tsai
Jul 13, 2007 | Kenneth Cole KC1169 Wrist Watch
Giorgio Armani Emporio Armani watches AR2413 WW Watch for Men Logo
Top Giorgio Armani Watches Experts
Kolbrun...
JonSnell Electronic
JonSnell Electronic
Are you a Giorgio Armani Watch Expert? Answer questions, earn points and help others
