Question about Carrier Beverage-Air UR30GEFD Beverage Cooler
Fridge not keeping temp. goes from 30 degrees up to 65 and back down again at random. losing food. help
  • Carrier Master
  • 1,078 Answers
I would investigate the thermostat first. It sounds like the most likely place to start based on the symtom
Posted on Jan 15, 2011
Jenn air refrigerator jcd2389ges freezes fridge
Bea, try this. UNPLUG the refrigerator for 12 hours and keep the fridge and freezer doors open. You might lose some food. NOW you will find some water under the fridge. clean that and now power up the fridge. Make sure you hear the motor working. Your fridge will start cooling. Keep at recommended temp.
Mar 07, 2014 | Jenn-Air JCD2389G Side by Side...
I have an Gallery series Fridgidaire side by side fridge, model number GLHS68EJSB0... the line to the water filter keeps freezing and unable to depense water... we have the setting on the fridge set to the...
We have the exact same problem. But ours is in a vacation home so we have to keep the water turned off all the time. It seems something in the ice line freezes when the fridge is empty. Then, no ice, no water. When we turn the water back on, after a few days of having food in the fridge, it seems to make everything melt and flood the tray then leak out onto the floor all day and night. The fridge temp goes down to 12 degrees when the fridge side is empty. It seems to stabilize when there are items inside. We put several gallons of water inside instead of leaving it empty and it helps with the temp but not with the leaking. We have had service come out several times and they just said, "don't leave it empty and turn off the water when you leave." What good is that? I don't have water or ice for the weekend when I go up to the house! OR I clean up floods the entire time!! Now it's out of warranty. Now that I see it happens to people in their main house, I would just say NEVER EVER EVER BUY FRIGIDAIRE AGAIN!
Sep 24, 2011 | Frigidaire FRS3R5EMB Side by Side...
Do the kenmore refridgerators have a daily defrost cycle? If so, how long does it last and what is the temperature fluctuation? The freezer is empty right now, and the temperature fluctuation seem to go...
All refrigeration products have a defrost set point. Most residential units defrost about every six to eighteen hours. This process should take about 30 minutes to 1 hour. The temp goes up so high inside because there is a heating element in the coils to thaw any residual ice. The temp should not exceed about 45 degrees though. If it does the the compressor is signaled to come back on and start cooling again. This is perfectly alright. The time at higher temp is not enough to spoil the food. Hope this helps. Good luck.
Nov 18, 2009 | Kenmore Refrigerators
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
The freezer keeps getting too warm, it was 30 degrees, came back down to 0, and is now up to 14 degrees.
Could be faulty temp sensors, faulty defrost timer/temp sensor, or failed _condenser_ coil fan (under/in back of the fridge).
Jul 27, 2009 | GE Profile PDS20MFW Bottom Freezer...
Temperature not low enough
check fan at the back of refrigerator or you have defrost problem
Apr 05, 2009 | Kenmore Refrigerators
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Freezer losing temp... intermittent buzzing sound
Either the start device for the compressor is bad or the compressor has died. The easiest way to tell is to replace the start device. It cost around 30-40 bucks and the part number for it is 218721119. In most of these cases its just a bad start device. The start device is located on the side of the compressor in the bottom back of the unit. It will have a capacitor attached to it that you will want to keep and stick on the new one. If you need anymore help just let me know. Good Luck!
Nov 02, 2008 | Frigidaire FRS26RLECS Side by Side...
Carrier Beverage-Air UR30GEFD Beverage Cooler Logo
137 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
