Question about Pensare' Rocket V17201 Handheld Vacuum
I need a dust filter for my TRex by Pensare'vacuum. Do you know where to purchase them?
Shark rotator no suction
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it.
If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum.
If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+rotator
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 10, 2016 | Shark Vacuums
Reduce suction Dyson DC41 Animal Complete Upright Vacuum
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
Ava B.
Oct 14, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc 40 loses suction
Ava B.
Oct 20, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissell carpet cleaner does not suction
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Jan 17, 2012 | Bissell 1699 ProHeat Clear View Upright...
My Shark vacuum is losing suction. How do I fix that?
You can purchase a wide variety of high quality Shark replacement parts for your Shark Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Dec 09, 2011 | Shark Navigator Bagless Upright Vacuum
My dyson 24 ball stopped sucking up
Ava B.
Apr 15, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
No suction on dyson dc07
Ava B.
Oct 25, 2010 | Dyson DC07 All Floors Bagless Upright...
My vacuum (shark modle #UV210BV) turns on but has absolutely no suction.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
You can purchase a wide variety of high-quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Jul 08, 2009 | Euro-Pro Shark Professional Upright Vacuum...
Recently purchase SC-N500 vacuum cleaner. Worked well only the first 2 times I used it to clean up plaster dust from floor after sanding. Since then it has not worked at all well wiht very poor suction....
This type of vacuum is not designed to vacuum up sheetrock
dust or pieces of sheetrock. The dust from sheetrock is so fine it will clog the vacuum bag, filters and possible the motor
So change the bag, use an air hose to blow out the motor area and
the hoses make sure that air hose has in line filter to catch moisture
Jul 14, 2017 | Sanyo Vacuums
Pensare' Rocket V17201 Handheld Vacuum Logo
403 people viewed this question
Top Pensare' Vacuums Experts
JoeVacs
Are you a Pensare' Vacuum Expert? Answer questions, earn points and help others
