Question about Transcend T.sonic 610 MP3 Player
I want to update my ipod
When ever i connect my ipod to my system it shows delayed write failed
  • 8,596 Answers
The hold switch is engaged - unlock it
Manuals, etc can be found here:
http://www.transcendusa.com/Support/DLCenter/index.asp
Posted on May 23, 2008
When i plug my ipod on to itunes it wont show up
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue.
Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> http://www.itunes.com/ b> http://www.apple.com/support b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page Apple.com and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
Jan 29, 2013 | Apple iPod touch Second Gen (8 GB,...
Tip
How to fix error 48 in itunes
The message does not indicate that there is an issue with the iPod but that that iTunes was unable to read the iPod software update it uses to restore or update your iPod. You can delete the folder containing the iPod software update files so iTunes can download a new copy of the iPod software update.
Here are the steps to take if you get this message:
Eject iPod and quit iTunes.
Use Disk Utility in Mac OS X or run chkdsk in
Windows to verify there are no other issues on your hard drive.
Locate the iPod Software Updates folder:
In Mac OS X, the folder is
/Users/username/Library/iTunes/iPod Software Updates
In Windows Vista, the folder is
C:\Users\username\AppData\Roaming\Apple Computer\iTunes\iPod Software Updates
In Windows XP and Windows 2000, the folder is
C:\Documents and Settings\yourusername\Application Data\Apple Computer\iTunes\iPod Software Updates
Note: If you don't see the files in Windows, turn on the Show hidden files option.
Windows Vista: Open Computer and choose Folder and Search Options from the Organize menu.
Windows XP and 2000: Open My Computer and click Folder Options from the Tools menu.
Click the View tab.
In the Advanced Settings pane, select the "Show hidden files and folders" button.
Click OK.
Drag the iPod Software Updates folder to the Trash or Recycle Bin.
Connect iPod and open iTunes. You will need to be connected to the Internet to download the files.
Then restore the ipod agin -
on Apr 25, 2010 | Computers & Internet
My ipod wont show up on the bar when i plug it in the itunes
We have a Nuvo Essentia Six-Source, Six-Zone system. It plays the iPod fine, but the control pad says 'No iPod Detected'. This means I have to control the iPod from the unit itself, rather than being...
I had a few systems that did this but once I performed the latest firmware update it fixed everything.
If the combus on the ipod gets shorted then it will also do this. You have to disconnect the Cat-5 cable from the dock, unhook the ipod, reconnect the cat-5, then reconnect the ipod.
I would contact your installer and have him update the system for you, failing that re-do your connections on the dock. If that does not work you may have a deformed connector on the ipod that shorts the combus (had that once on a Russound system). Or a defective dock
Hope this helps,
Dec 24, 2009 | Nuvo Essentia Amplifier
My ipod wont restore becuse of error 2003 how do restore it ???
Read This, then get a new cable.
K first off this is an utterly pointless error that caused me to loose valuable files, info, and time.
I was using my ipod and it had been running into a few problems. Such as the time being wrong etc. I plugged it into iTunes and it wouldnt show up. I tried over and over without success. SO eventually i decided to put it into reovery mode. I plugged it into iTunes, it saw it and that it was in recovery. I clicked restore and everything went fine untill it got to actually updating the software. I got error code 6 and error code 2003. I found a tip to restart iTunes a couple times so i did without success. I then found another article talking about battery charges and cheap caples when i got a hunch. The night before i had added an extention cable to my ipod cable so that i could run it to my bed. I pluged the normal ipod caple straight into my computer, hit restore and BAM it worked. Thus I realied that there was no need for me to recover my ipod because let me tell you, 14 gigs of music and videos takes a LONG time to copy to my ipod.
If you have the same problem try this:
1. DO NOT GO INTO RECOVRY MODE
2. Make sure you have the ipod directly connected to your computer (no extensions or hubs)
3. Restart iTunes a few times
4. If all else fails enter recovry mode and hope for the best laugh4.gif user_offline.gif quote.gif
Apr 09, 2009 | Apple iPod touch
I Pod shuffle (2nd. generation) won't hold a charge
Hold in the play button for 10 seconds to reset. If that fails:
iPod shuffle Software Update and Restore
Apple periodically updates iPod shuffle software to improve performance or add
features. It is recommended that you update your iPod shuffle to use the latest
software.
You can choose either to update or to restore the iPod shuffle software.
If you choose to update, the software is updated, but your settings and songs are not
affected.
If you choose to restore, all songs and data are erased from your iPod shuffle. All
iPod shuffle settings are restored to their original state.
To update or restore iPod shuffle with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software install file and follow the onscreen instructions to install the
iPod shuffle Update.
3 Connect iPod shuffle to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod shuffle software.
If you use the iPod Updater application and it doesn’t see that iPod shuffle is
connected to your computer, turn iPod shuffle off and turn it on again.
Mar 15, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Computer shuts down when connecting iphone
Try the latest itunes:
http://www.apple.com/ipod/download/
- Quit iTunes if it's currently open.
- Visit Apple Downloads to see if there are newer versions of iPod Updater (this contains software for all models of iPod) and iTunes than what's installed on your computer.
- If there are newer updates available, download the Windows versions of the updates, then run the installers on your computer to install the updates.
- When it's finished, iTunes will already be updated, but you'll need to run the iPod Updater to update your iPod, so connect your iPod to your computer.
- On the Start menu, point to All Programs, point to iPod, point to iPod Updater, then click the latest iPod Updater.
- Click the Update button to update the software on your iPod (if the Update button appears unavailable, your iPod is already up to date).
If it still fails, remove the automatic restart from windows:
Go to Start -> Control Panel -> System
Go to Advanced
Under the Startup and Recovery section, click Settings...
Under System Failure un-check "Automatically restart"
Feb 11, 2009 | Apple iPhone Smartphone
APPLE IPOD VIDEO 30 GB WHITE
You can try to reset :
http://support.apple.com/kb/TS1382?viewlocale=en_US
http://support.apple.com/kb/HT1320?viewlocale=en_US
If you still have the problem you can try restore :
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
1. Make sure you've reinstalled the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software.
The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Good Luck.
Live, Love, Laugh.
May 05, 2008 | Apple iPod MA446LL/A MP3 Player
"delayed write failed" in office 2003
You will get a delayed write failed when the network is no longer connected and the user tries to save the file. are you noticing any other issues on your network?
Sep 09, 2007 | Microsoft Office 2003 Basic Edition...
Why does my iPod appears on my computer but not in iTunes?
Maybe radical but this worked for me.
My computer-select ipod,Right click and format disc (fat 32)
Once refomatted plug in to computer and start Itunes.
Click on Restore to factory settings, At the end of that you will need to plug it briefly into an ac outlet.
Reconnect ti computer and start Itunes.
Sync with library.
This worked for me after trying everything else I could fine failed.
My error when I ran diagnostics said "one or more sync tests failed."
Sep 28, 2005 | Apple iPod nano
Transcend T.sonic 610 MP3 Player Logo
46 people viewed this question
Top Transcend Audio Players & Recorders Experts
Gyula Lacz
aliasger yq
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
