Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Seagate Hard Drive issue
Hi there. Im currently having some trouble with a Seagate external drive of mine, which has worked perfectly with Vista for the past 4-5 months. I removed the drive, took it to a friends computer (XP) which worked fine. I brought it back, and now Vista is failing to recognise the hard drive in the Device Manager/Drive list when i plug it in via USB. Im sure this is something quite common but I am obviously concerned as my entire data off my old PC is on it! Any thoughts/solutions? Seagate tech support have told me to try a 'Power Down' on my PC but yet to try it.
Thanks a lot for your time, your help is much appreciated.
I want drive freeagent pro 500 gb firewere400,usb2.0, eSATA
Posted on May 16, 2008
Hi I Have an I O Error On My External Hard (500 GB Seagate) and I can't open or copy my files. Please Help Me. Thank You
  1. Unplug both the power cord and USB cable from the external Seagate hard drive.
  2. Restart your computer
  3. Plug back in both the power cord and USB cable from the external Seagate hard drive.
Comment back if this doesn't fix the issue.
Mar 01, 2011 | Seagate FreeAgent Pro 1TB External USB...
Wont reconize
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
SATA hard drive not recongised.
hi, sorry but i have to ask the question , why did you take the drive out of a external drive then buy a kit so as you can use it as an external drive , if its because the Seagate casing is damaged then its highly likely the drive is damaged too .
Apr 28, 2010 | Seagate 1 TB SATA II Hard Drive
Seagate freeagent 500gb not getting powered
is the power frequency different out in india, it's not just the voltages you have to watch!
If you can remove the hard drives and use a usb interface to connect them then software like filescavanger will recover files providing the hard spins up ok.
Jan 11, 2010 | Seagate Free Agent Go Small 12 GB USB...
SEAGATE DRIVER ISSUE
It is a internal hard drive, which connects through IDE cable (the wide one), so you shouldn't be asked for drivers. If in any case you can't see this drive in your "My Computer" ("Computer" on Vista) it's probably because you have connected it wrong. Notice that the end of the IDE cable must be connected tou your main hard drive (where OS is instaled). If Seagate ST340015A is your main hard drive, than the end of the cable should be connected to it. If not, than on the same cable, about in the middle is another connection, you should use that one.
Mar 17, 2009 | Seagate Barracuda 40 GB Hard Drive
My seagate free Agent exturnal hard drive
Hi, Sorry to hear you are having problems,
When you open your hard drive, is it locked ? Do you see a pencil with a line through it in the bottom left had corner ?
It could be that the drive has inproper permissions....
So, try this, click on the Hard drive icon (Please be sure it is the external drive, NOT YOUR STARTUP DISK ) then get info on the drive. In this info window, at the very bottom, you should see a check box allowing for: ignore ownership on this volume. Please click this box.
Now, try creating folders on the drive...
If this does not work, I highly recommend reformatting this Hard Drive, that is assuming there is no valuable information on it.
After reformatting it, it really should work porperly.
Dec 16, 2008 | Seagate FreeAgent Pro Desktop - 320GB -...
System will not detect my Seagate ST3500641CB-RK 500gb external hard disk
if your system some virus hope it is not read......better you try any other some card reader or pen driver if it read you try other OS ....
Jun 07, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
Maxtor basics external drive
Hi Nuisance101, I recall your running vista. Vista is a nightmare. If you cound only see the troubles we see on a daily basis here at FixYa you'ed understand. It's a common problem with Vista not seeing USB devices, externial devices. It does & then the next second it doesn't. Same for all external devices. I'm am 100% sure the trouble is not your system or your devices. It's Vista. I have gone over dozens of post from vista users. One would think MS has been on vacation since the release of vista. You can look at vista's web site for help for a possible fix, at this link. (I have no faith). MS blames driver software. Your Maxtor drive is external. Henve no driver software.
So it falls into that vista area of one time vista see's the drive & the next it does not.
Either way I though Maxtor addressed vista issues. I prefer Seagate drives myself. Personally know lots of people who's Maxtor's drives have just gone down for no reason. Seagate bought Maxtor.
http://windowshelp.microsoft.com/Windows/en-US/hardware.mspx
Most of the post from vista users, claim users should check vista's updates often. Since Max Blaster did its job, I'm inclined to blame vista.
I wish I could give you a better fix or suggestion but I'm up against vista. That's why I run WinXP Pro. I do not have these problems.
Best wishes Nuisance101!
Mike
Mar 30, 2008 | Computers & Internet
Can't get it to work
What operating system are you running? Windows Me or older has troubles finding plug and play external hard drives sometimes. If so look up some how to's on google for installing your model of external hard drive on to the operating system you're using. Although if you're using XP or Vista you may have an issue in your Device Manager. In that case you will need further instructions.
Jan 22, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
176 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
