Question about Denon Audio Players & Recorders
I have a Denon RCD-m37 micro system and a REGA Plannar 3 turntable. Can I connect the turntable to the micro system?
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: what type of sub-woofer can
Free or you can tempt us with $$. Your choice.
Register and download the manual for free at audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/denon/rcdm37.html
Self-powered would work but it would have to run on full-range amplifier (from the speaker posts) or Line Level signal (from the OUT RCA jacks) because this unit has no Sub-specific output. It's no bigge as the sub would naturally discard the higher frequencies via its own amp's and speaker
Posted on Feb 22, 2011
dunnbiker
  • 8546 Answers
SOURCE: Denon RCD-M37 turns on when
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 04, 2011
No sound when i connect my denon-dp 29f turntable to denon rcd-m39 receiver. what might be the reason? Wrong receiver?
If your receiver ain't has a phono input and the tt has only a phono output, you'll need a phono to line line riaa amp , between the units.
Oct 26, 2013 | Denon DP-29F Turntable
Tip
Denon VPROT Problem.
I posted a question regarding a Denon RCD-M37 DAB, which after a repair to the sub power supply transformer, came up with VPROT after a few mins use. After very careful measurements I found that the -12Volt line coming from the power regulator board situated behind the mains transformer was measured at 10.5Volts. It is necessary to replace the LM7912 regulator. Whilst with this board out check soldering and all other components. Normal operation has now been restored. I hope this will help regards Paul R.
on May 08, 2015 | Denon Audio Players & Recorders
Rega planner 3
If the amp does not have a dedicated sockets for a turntable - often marked "phono". Then plugging it into an aux socket won't work. You will need to get a Magnetic Cartridge Pre-amp. The turntable plugs into this and that plugs into your aux socket. If at the present you turn up the volume really loud you might just hear the record playing. That will tell you that the cartridge is OK.
Jul 14, 2013 | Audio Players & Recorders
Hi can you tell me that impedence on JBL TLx4 speakers- i need to know if they are compatible with my denon RCD M37 dab player thanks
hi,
Is it JBL TLX 420 then its impedance is 4OHMS. You cant connect these speakers to denon rcd m 37, because its output impedence is 6 to 16 ohms.
ok
Jul 04, 2011 | JBL PSW-D110 Speaker
I have a Rega 1. After playing several records, it just lost sound. Why?
Possible the connections are gone- check the input for audio response. Trace the audio to the head to confirm the connection.
if not the stylus is faulty as it would have worn out or the head is faulty.
Apr 11, 2011 | REGA Audio Players & Recorders
I am trying to record my old vinyl records to a CD. I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling...
Complex? Traditional turntables need PHONO preamaplifiers (in receivers) to PREAMPLIFY the minute signal they produce to something useable.
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
Just curious, priorto the arrival of the RCD, how did you play or listen to the turntable?
Feb 26, 2011 | Sony RCD-W500C 5-Disc CD Recorder
What type of sub-woofer can i add to my denon rcd-m37 system? (passive or powered). Is this information free or not.
Feb 22, 2011 | Audio Players & Recorders
I have a UK bought rega planar 2 turntable. I tried to use it in the USA using a step up transformer and it runs fast. How can I fix this?
As far as I can see, this turntable uses a belt. I believe the motor is synchronous (12 vac), it is designed with a pulley for working at 50Hz. At 60Hz, it turns 20% too fast. It may be possible to change the pulley as it needs to have a smaller circumference. I think you should contact a Rega representative or the company directly in the UK (www.rega.co.uk)
Jul 14, 2009 | Audio Players & Recorders
Connecting a turn table to a micro stereo system
You will need the following to connect this to that system:
1) Phono Pre-amp
2) 3.5mm to RCA adapter or 3.5mm 'Y' cable to RCA
3) Turntable
Your turntable will connect to the Phono Pre-Amp input. This pre-amp will also have an output. This output is RCA, from here you connect to your system using the 3.5mm adapter or cable.
That's it.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Aug 07, 2008 | Audio Players & Recorders
215 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
