Computers & Internet Logo
Posted on Sep 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hp pavilion laptop screen is to dark how can i fix it
john smith
Level 2:
  • Expert 406 Answers
  • Posted on Sep 06, 2010
john smith
Expert
Level 2:
Answers
406
Questions
0
Helped
84012
Points
950
Hit the menu button on the screen and put up your contrast or brightness.
I have a HP PAvilion dv5-1125nr and I recently encountered a problem where on startup it shows a white screen. I tried looking at it from all angles to see if there was a faint image but there was nothing....
no photos of white screen presented or posted.
is it white in a dark room???????????
DV5-1125nr (9 years old (first made date) RTC COIN cell time? sure. page 59 tells you how.
http://h10032.www1.hp.com/ctg/Manual/c01550108
lacking any photos , it be impossible to fix this talking in text box.
no?
as they say ,seeing is believing, what you call white I call black.
white on sunny beach, or black in dark room, can be the same.
PAvilion dv5-1125nr
always post what a pC does in the dark, its best.
all text seen , all logos seen (hp or compaq)
any boot screens, any log in screens.
and if the "hit F10 key to enter HP setup" is missing on said screen as seen now for 9 years running.
if that text is missing,
remove the big battery in rear of LP,they short, so get it out now
and first., do that first. always,,,
then run on AC power,
do the HP long reset? (battery out, ac pack pulled
push power button 10 to 30second, not use the ac pack only
it can run on AC forever, end ever , no problems.
do so now.
got that that 9 year old text now? in the dark, ok?
The F10 is BIOS hot key, power on and quickly hammer F10
bingo for BIOS. see that? see those screens, those are first.
if BIOS is dead, it can not boot any OS made.
BIOS does the booting job, see?
here is your support page. at HP, Fixya is NOT HP. so....
https://support.hp.com/us-en/product/hp-pavilion-dv5-1100-entertainment-notebook-pc-series/3744201/model/3795325/manuals?jumpid=reg_r1002_usen_s-001_title_r0001
this OLD PC, is CCFL back lighted, all are.
2010 year is the magic hear we went to LED backlamps.
but your PC is 2008, see?
CCFL do these things
dim, go yellow, do dead, go intermittent and blink(strobes)
if dim, AS I SUSPECT , then its that. (brightness set to max)
CCFL tubes are 99% caused
the HV inverter is 1%
here is the tube sets.
https://www.ebay.com/itm/CCFL-Backlight-for-15-4-LCD-HP-Pavilion-dv4400-dv5000-dv5100-dv5-1000-1100-1200/401259562873?hash=item5d6cef0779:m:mcD2SCb17BxyIvQPKdpd78A
here is the inverter (high voltage inverter for HV CCFL tubes)
https://www.ebay.com/itm/HP-Pavilion-dv5-1125em-dv5-1125eo-dv5-1125es-dv5-1125nr-laptop-LCD-inverter/121175375836?epid=1758409030&hash=item1c369d7fdc:g:CXEAAOSwRbtaAU5l
if you tell what it does in the dark , all things
good or bad,.
answer get 10x smaller, or in fact , dead accurate.
why not just get it fixed by a tech.
all old laptops do this, EVERY SINGLE ONE.
HP Pavilion notebook's screen is too dark to see!
do u have a external monitor,connect it up and see whether,u r output is any better..
Dv4000 hp pavilion dark screen
Have you replace the lcd inverter? if it works on external monitor, given the screen is new, then it leaves the inverter. Usually in the case of dark screen, it should be the first thing to check/replace.
Dark unreadable screen
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Screen dark/ mouse not working
Nelia, JUst fixed one with the same problem. The lid switch is faulty - I will take a technician about 20 mins to disconnect the switch and leave it disconnected.
Dave M
Hp pavilion dv4000 screen is dark and unreadable
hi this is a website where you can dawnload service repair manual
http://www.laptop-repair.info/hp_laptop_repair_manual.html
check with it
regards
Dark Screen
the ac adapter needs to be pluged in, try the normal mode..
its hard to fix it from here, if you could get someone to look at it?
Grand Canyon Tech
Grand Canyon Tech
