Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon PIXMA MP140, refilled cartridge don't work
  • 4 more comments
  • ben2talk May 21, 2008
    After refilling the cartridges, the printer continues to see the ink as empty. Need a way to reset the chip, or (if I buy new cartridges) fix them so they won't be written to by the printer - so there will be no ink warning and it's up to me to make sure they're refilled.
  • richard van niekerk Oct 05, 2008
    i have a cannon mp140
    and i refilled my ink \
    but how does one reset the ink or printer \l;et me know
    thanks
  • Anonymous Nov 22, 2008
    i refled my cartage..??
    but there was a problem that its black ink was leg age.?
    plasae give me solution what i will do..??
  • pinky_1991 Jan 28, 2009
    i put a refilled cartridge in and i dont know how to use it
  • Anonymous Feb 07, 2009
    were on the catridge do i put the ink to refil it?its the mp140
  • sixnahbabe Apr 23, 2009
    I need a solution to fix the E-5 problem on my mp140 it keeps telling me color out. I really need help! I reinserted the cartridges, they are new still.
  • 25 Answers
Best solution i think
How to reset the Canon MP150 (also worked with my MP140 so it might work with others as well) after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
Printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed Printer with paper.
7) Press the power button twice and then press the colour button once. The printer will print a some stuff. Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which explains why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open Printer's cover cover (not the scanner cover) and remove the cartridges. With Printer still open, disconnect the power outlet.
9) Close the lid and turn on The printer.
10) Refill cartridges and place them back in their nice little abode in The printer.
Posted on Nov 05, 2009
    Sniper:
  • 66 Answers
Hi i have a mp145 and i use refilled cartridge working great for me i only have to hold the stop reset button for 5 seconds and printer work again but the ink level check dont work, but i have to live with that. original cartride will be more expensive than the printer cost..if a error E5 shows up i think it have to do with bad contact inside the cartridge holder, only solution is to remove the cartridge and insert again should work great
thx ake
Posted on May 29, 2008
    Problem Solver:
  • 14 Answers
Cara Mereset Printer Canon MP145 & MP160 Agustus 23, 2008 Posted by gfirmansyah in Teknologi.
trackback Canon MP160 , MP145
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported inkcartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
MERESET WASTE INK COUNTER PADA CANON MP160 DAN MP145
1. Matikan printer (kabel power masih tercolok), tekan dan tahan tombol STOP/RESET kemudian tekan tombol ON/OFF
2. Tahan tombol ON/OFF, tekan tombol STOP/RESET 2x
3. Lepaskan kedua tombol dan printer akan masuk ke SERVICE MODE
4. Printer akan charging
5. Setelah printer selesai charging, tekan tombol STOP/RESET 4x.
6. Setiap kali tombol STOP/RESET ditekan, lampu ON/OFF akan berubah warna hijau dan oranye.
7. Matikan printer dan cabut kabel POWER.
8. Hidupkan kembali printer
Kode Error Canon MP160 dan MP145
E3-3 = Paper jam
E4 = No ink
E29 = EEPROM error
Posted on Sep 12, 2008
    Problem Solver:
  • 5 Answers
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
The printer takes about 10 seconds to show the number 0.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Posted on Aug 11, 2009
  • boomzz Aug 11, 2009
    ps: this works for the canon mp 140 as well as i have one and have treid sev times in the past..
  • 3 Answers
I'm having a similar problem with a PIXMA iP1800... I bought a refilled Canon PG37 black ink cartridge at the weekend and now the printer software will not recognise either of the cartridges... not the new one nor the refilled CL38 colour cartridge that I put in it weeks ago ( and which was working fine until I added the black cartridge ).
I know it's because the printer is trying to read an electronic 'tag' on the cartridge... but any ideas how to over ride this irritation?
Posted on May 27, 2008
Hello MP140 user!
Looking for a solution to reset ink level after refill?
Take a look here:
http://digitalgraphy.wordpress.com/2008/11/19/refill-and-reset-the-canon-mp150-printer/
Try METHOD1...
my MP150 show the correct (refilled cartridge) ink level, again...
i think this solution works fine with MP140 too....good luck!
GL
Posted on Jan 06, 2009
Its the most bogus and wastage of money. the company has never said that scanner does not when any of the print ink cartige is empty os when the printer is out of service....... i had been the most unfortunate guy to buy this mp145 and havn't been able to use is most of the times. the ink is pretty expensive also but what the use of all these multy user function if one does not work if other is not working. I have my business and had been facing a lotof loss due to this functional error hus i would not recoment any one of you to buy this series printer, scanner unless you thoroughly verify these things...................... I LOST FAITH IN CANNON...
Posted on Apr 17, 2010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 22 Answers
I have trouble sometimes after refilling cartridges. I have three holes in the top where I inject the ink - I use rubber gloves to keep my hands clean and I use Blu Tac and have a spare syringe with no needle attached.
If you put ink in, and it's not printing, first you can blow the ink through using a syringe with blutac to make a seal - just push a few cc's of air in there to pressurise the ink until it comes out of the print head. I use tissue to blot it, then put it in the printer and print out a few copies of my colour printing test sheet (a .png image I downloaded). Sometimes I have to clean it a few times, waste some ink, refill, mess around - one time it took me around 40 minutes - but usually it's just a matter of it getting airlocked and sometimes it's tough to get the heads clean.
It doesn't need resetting - ignore flashing lights and warnings - just keep printing. I had Black and Colour ink lights flashing for months now - I print at least 20 full page A4 pictures every week in windows and linux - no problems.
Posted on Nov 27, 2008
Why bother to take out the cartridges. Power up the printer, when the ink cartridges begin their travel from their home position to the left immediately switch of the mains socket, This will leave the cartridges mid-way or wherever you want them. Now you can use a cordless drill and proceed to make the necessary holes in the cartridge. Fill with about 4ml of ink ( essential that you do not fill to much as it will overflow into the machine. Fit holes with rubber bungs, switch printer back on at mains and away you go. Although it will still show ink level alarms it will work - this way you have not removed the chip from the printer. Been doing this for months with no problems
Posted on Dec 11, 2009
B4 u refil dont take cartridge out by the normal means.get the black front cover off which is snapped on.then unscrew the right hand side panel and take it off. u will see the cartridges resting there.take them out.u may hav to snap/bend a bit of plastic which is obstructing the further cartridge from coming out.u may hav to push cartridge holder to the left(along its track) very slightly to get the first cartrige out. then refil and place back. doing it this way makes the printer think that no cartridge has been taken out. if u hav already taken cartridge out and there is error 5.then put another cartidge(new or old which does not show e5).then do the above and swap the cartidges around.the printer will not b aware of this. do this everytime u need to refil
Posted on Mar 03, 2010
My canon mp140 printer does not work. when switch on then cartrige move and return back at once. how to remove this problem?
Posted on Dec 27, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
Hello!
Trojak3d
No problems for my Canon MP145 with this solution (Solution #12). Thanks a lot...........................
Posted on Dec 03, 2009
  • 3 Answers
HOW CAN SCAN FAST FOR CANON MP140
Posted on Nov 01, 2010
Salve il mio computer non legge il cd per installare la canon pixma mp 140
Posted on Feb 04, 2009
The whole problem revolves around the fact that there isn't any way available to me to reset the chip. Trying with an original means paying the CANON prices, the whole point of refilling is to avoid that, and when a Guest named Apprentice says my answer is stupid, it reflects more upon his useful input.
The fact is that I CAN PRINT with refilled ink, but each time I have to over-ride the machine settings that tell me it's empty, hold down reset and it prints. Better than paying through the arse.
Thanks for your opinion, but for me to get a full cartridge, I bought 200ml ink bottles for $2 each. $6 dollars will refill my colour cartridges enough times to save me at least 4 or 5 purchases of the new item. Savings - you work it out. Enjoy your original ;) if I want photo quality, it's cheaper to go to the shop and get better quality from an expensive printer.
Inserted cartridges but still printer operate some instruxctions
Posted on Nov 26, 2008
    Genius:
  • 2,785 Answers
This is a known issue with refilled one try with original one
Posted on May 13, 2008
SOURCE: Canon PIXMA MP140, refilled cartridge don't work
Hey thymon,
Did you fix your E5 problem on your mp140?
I have the same problem has you...Can't do nothing with it no more.. Printing wise
the following ink cartridge cannot be recognized
its a bummer
Posted on Jul 08, 2009
fotobean
  • 103 Answers
SOURCE: vista for canon pixma mp140
Here's the solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Posted on Feb 21, 2009
wayneard
  • 1901 Answers
SOURCE: Cannot instal canon pixma MP140 have CD but not
Yes, you may.
Go to: MP140 Support
Click on the Drivers & Downloads tab. Select your operating system from the drop down menu.
All available software will then be listed for you to download.
The easiest thing to do when the download window appears is to Save the file to your desktop and run it from there. That is, if you are not comfortable saving it to another location, such as a Temp folder.
If you need any further help, just use the Comment button.
Thanks for using Fixya.
Posted on Apr 18, 2009
SOURCE: Canon mp140 not printing anything after refill
MY PRINTER'S ALARM LIGHT IS FLASHING AND SHOW ERROR 2 CAN YOU HELP ME ?
Posted on Oct 26, 2009
Grubhead
  • 5309 Answers
SOURCE: Canon Pixma 510 black cartridge
I doubt it very much! Your model seems to use the PG40 & CL41. You can also use PG50 & CL51.
See also my tip on refilling these cartridges.
Posted on Feb 01, 2010
Ink cartridge of canon mp140 printer has run out.can I refill it
Do not refill,the printer works with original cartridge canon.If you refill the cartridge in the future you ruin the printer.
Apr 10, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Dear Adviser The Canon cartridges for my Pixma MP140 printer have run out of ink as indicated both on the printer by the E4 signal and on the computer by a pop up window when trying to print a...
Hello, the printer Canon Pixma MP140 has cartridges with no chips. The printer reads the serial from the cartridge and tells you an estimated ink level. My recomandation is to press the resume/cancel buton for at least 10 seconds, that being the method to cancel the ink counter. After you press the resume/cancel buton you will be able to print, scan and copyas you did before.
The only disadvantage is that your printer will never show the ink level for this set of refilled cartridges, but it will work as well as brand new cartridges.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Feb 01, 2010 | Office Equipment & Supplies
Coloured ink not registering
You can only refill those cartridges if you do it before the ink is empty. After that you need a new cartridge or a chip resetter to reset the chip on the cartridge so it will work again.
Oct 12, 2009 | Canon PIXMA MP150 All-In-One InkJet...
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
I have a pixma mp10 scaner and printer it will not scan the light flashes E and 6. What can I do to fix this? Barbara Nash
Halo Barbara,
Did you mean Pixma MP140/160/150/170/180?. I never hear Canon pixma MP10. Well,it doesn't matter. Did you refill your cartridge?. Error code E6 indicates that ink level is not detected properly by the printer. It usually occurs in refilled cartridge. To fix this problem you need to deactivate ink level detection function by performing following procedure:
For MP150/160/170/180: Press START button (Black or Colour)
For MP140: Hold down STOP/RESET button for about 9 seconds
Please rate me as Fixya if this solution useful for you. Thanks
Source:
Canon Inkjet Printer Forum
Nov 27, 2008 | Canon Office Equipment & Supplies
Reset ink level on CANON MP 140 PIXMA PRINTER
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
Aug 28, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
38,377 people viewed this question
old marine
old marine
