Question about GE Profile 30" Slide-In Gas Range - Stainless-Steel
GE Profile 30" slide-in gas range; model JGSP48S0H1SS Lower/oven burner won't ignite. Controls appear to accept the Bake command normally, control fan starts but lower ignitor won't glow and gas admission valve does not open. Upper/broiler burner and stovetop burners work fine.
aborcass
  • 2651 Answers
SOURCE: oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Posted on Mar 26, 2008
Illeagle
  • 525 Answers
SOURCE: My ge gas range will not heat up
Inspect the ignitor for a crack or break in the continuity of a ceramic ignitor. If you can't visually discern a failure, then a multi-meter is need to check for resistance through the ignitor.
Posted on Jun 02, 2008
MNTECH
  • 1543 Answers
SOURCE: JGBP33 BAKE IGNITOR
You did not post a complete model number, but this should help:
Take racks out of oven. Remove two screws at the very back of the oven bottom. Lift back side of bottom up and back a bit to remove oven floor. Remove flame spreader (one nut at center). ignitor is at the back left of burner, most likely a WB2X9154 (round style) ignitor. The entire burner can be removed rather easily at this point if you remove the two screws at the front and disconnect the ignitor wire (if you wish to have easier access to ignitor mounting screws.)
Posted on Nov 23, 2008
  • 126 Answers
SOURCE: No Bake; everything else works
Most likely a bad bake igniter wb13t10045 cant guaruntee thats the problem but I'd start there.
Posted on Jan 28, 2009
jsrock516
  • 5911 Answers
SOURCE: XL44 oven will not work
The fact that the igniter on the broiler actually begins to glow rules out your Electronic Oven Control (EOC) board. Usually when both oven features fail to work the EOC, or wiring, is the culprit. But...in your situation, the broiler igniter glows, but the bake igniter doesn't. You don't see this happen very often, but I believe you may have two bad igniters. The following link explains how to replace an igniter and gives you some theory behind how they operate:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Although an igniter glows, it still may be bad. This is usually dependent upon the age of the stove and the frequency of use. Usually, the bake igniter burns out first, because it is used more often. These igniters also grow weak with age. Which means, if they do not draw the required current necessary to open the gas safety valve, you will not have ignition. This is a designed safety feature that prevents free flowing gas from filling the oven box before ignition. I would recommend replacing both igniters to see if this corrects your problem. If you require additional assistance, or have questions, please let me know before you rate the solution. I hope this helps solve your problem.
Posted on Feb 26, 2009
When i turn on the oven it starts up as normal , "on" then "Preheat" then runs. About 30 minutes later both the "oven on" and the "preheat" indicator lights start blinking.
follow this test and fix it. God bless you
Oven Igniter
As the oven igniter weakens over time, it will take longer for the gas valve to open. If the oven doesn't bake evenly, it may be that the oven igniter isn't opening the gas valve when it should. This will cause the oven to cool down more than it should before the burner reignites. The oven temperature should not cool by more than 40 degrees before the oven igniter relights the burner.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't heat the problem is usually with the heating components. However, if the oven control board is bad, it might not send voltage to the heating components. To determine why the oven won't heat, first test the simpler components in the circuit. The oven control board can't be tested easily and will have to be replaced if it is defective.
Nov 04, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas burners & broiler work but oven won't bake
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | GE Profile 30" Slide-In Gas Range -...
How do i light the oven pilot on a ge xl44?
MOST modern appliances that use gas ignition (including dryers) no longer have a pilot light. These appliances are now equipped with a burner assembly with electronic igniters. The following link explains a little theory about how these igniters work and how to access the them on a gas range:
If you are having ignition problems with one of the oven manifolds (bake or broil), it may be a simple matter of a weak or bad igniter. If BOTH manifolds are experiencing the same problem, you may have a bad regulator or electronic oven control (EOC) board. The EOC controls all your oven features.
The surface burners use an electrode type igniter for ignition. There is one mounted next to each surface burner assembly. They get their electric source from a spark module. If none of the surface igniters are working, you may have a bad spark module. If one single burner is not igniting, the problem is probably the electrode.
If you have any questions, please let me know. Include your complete model number if it is different from the one you posted this question under. I hope this information is helpful to you.
Jan 14, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Jan 03, 2010 | GE Kitchen Ranges
I need instructions on how to light the pilot light on a GE XL44 Stove. Model#JGBS15PEA2AD
MOST modern appliances that use gas ignition (including dryers) no longer use a pilot. These appliances are now equipped with a burner assembly with electric igniters. The following link explains a little theory about how these igniters work and how to access the them on a gas range:
If you have any questions, please let me know. I hope this is helpful to you.
Nov 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a JGBP30 gas range and the oven does not. Someone checked it and said the main control is bad. Is there a manuel that I could get or is there any way I could check it, before ordering a new...
Does the oven ignitor "glow" when turned on but no flame appears? does this model have an actual broil burner ? or does it just have a broil drawer at the bottom ? If it has a broil burner up top of the oven, does it ignite ? It could be the clock/timer, but rarely. If the "bake" ignitor glows, but the burner doesn't ignite, or ignites slowly and/or a "sputtering" flame, replacing the bake ignitor should solve the problem.
good luck
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Hi...need help with my oven it won't heat up
If your surface burners work and the broiler operates normally, more than likely you have a failed igniter on your bake manifold. There are two separate igniters on your oven. One is for bake, and one is for broil. This is a common failure, due to the fact that the bake function gets used more often than broil. I found your part listed at repairclinic.com. Just type in your model number and the igniter is listed as item number 1990. For instructions on how to replace the igniter, click on the following link:
Just make sure you turn off the gas and unplug the range before starting any repairs. If you require further assistance, please let me know. I hope this information is helpful to you.
Jul 13, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Profile 30" Slide-In Gas Range - Stainless-Steel Logo
254 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
