Question about Weslo Exercise & Fitness
I have a Weslo Cadence 400cs and the roller at the end makes a terrible squealing noise (only on the right side). We have tried adjusting it which makes it go away for a little while. I also am looking for a manual as I bought this used from someone. Can you help me?
  • 79 Answers
Check if the belt is not making contact with the rail foot. but most likely the problem is the roller bearings checks can be changed only if the bearings or need to change the whole piece. you know bearings are tiny wheels with numbers and letters on the sides. you probably have that seek the services of a qualified technician
Posted on Sep 10, 2010
My Weslo Cadence 840 treadmill mat keeps trying to run off to the left
Check that the plastic end cap has not broken first. If it is OK, adjustment should be simple.
Start the machine running. With the allen key provided (3/16) simply tighten (clockwise) the left hand rear roller adjustment screw about 1/4 turn and observe the belt. If it is way off, you might need to turn 1/2. Let the belt do a couple revolutions before adjusting more. A very small adjustment id usually needed to straighten the belt. If it is way off, there may be a more serious problem..
Feb 26, 2011 | Weslo Exercise & Fitness
Weslo Cadence 830 ....Looking for a free online manual
my weslo 830 the belt seems to drag when you step on to it. should i oil it if so how?
Dec 18, 2010 | Treadmill Doctor Weslo Cadence 835...
The walking deck on my Weslo Cadence 975sel slides to the right and causes a loud rubbing noise. How can I correct this problem? Thanks,
Find the allen key that came with the machine. If you don't have it, you will need a 3/16" allen key to adjust the roller.
If the belt is pulling to the right, adjust the right screw by turning it clockwise 1/4 turn with the belt moving. You may need to do this more than once. Between adjustments, watch the belt closely to see how much it moves to the left.
Unless something dramatic has happened to the frame or some other part, the amount of adjustment should not be too great..
Dec 17, 2010 | Treadmill Doctor Weslo Cadence 930...
How do i lubricate the belt or rollers and what do i use to do so?
you can log onto iconservice.com, and order the belt lube kit. You loosen the drive belt, and use the applicator to apply the oil under the walk belt. The rollers dont get lubed.
Hope this helps, Matt
Dec 13, 2010 | Treadmill Doctor Weslo Cadence 400Cs...
Our Weslo Cadence Dx12 treadmill will only operate at the highest speed and will not turn off without the safety key. The speed cannot be adjusted to slower speeds.
Go to Radio Shack and buy some contact cleaner. Clean the peed control on the console. If that doesn't solve the problem, you will need to replace the motor controller PCB..
Dec 11, 2010 | Treadmill Doctor Weslo Cadence Dx12...
How do i tighten my belt ..it goes from one side to the other
First check that the treadmill is level. Then adjust levelers if possible. Most treadmills will have a bolt at the rear of the tail roller one each side to adjust belt tracking. If it is tracking to the left tighten the left , for each adjustment on one side make equal and opposite adjustment on the other side to avoid over tightening the belt. 1/4 turn at a time
Feb 09, 2010 | Cadence Weslo 215s Treadmill Walking Belt
How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Exercise & Fitness Logo
282 people viewed this question
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Jim London
Jim London
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
