Question about Whirlpool 247 cu. ft. Upright Freezer EV250NXRQ
Buildup of ice on bottom (inside) , drain tube in pan underneath but is always dry.see no reson for ice build up
  • 50 Answers
The drain pipe is most likely blocked. It is a plastic tube about 10mm diameter, as you've probably noticed. Try reaming it out gently with a wire hanger.
Posted on Sep 06, 2010
Ice in the bottom of the freezer compartment
there should be a drain hole at the bottom of the freezer that goes to a evaporation pan underneath. check to see if the drain is clogged. in areas with high temps and or humidity there will be excessive moisture build up,the more the door is opened the more moisture (condensation). Clear the drain, it may just be blocked by ice, MAKE SURE THE UNIT IS LEVEL! This will let the moisture drain properly and prevent ice build up.
Apr 11, 2014 | Freezers
Model No.ERF415M 13CT. I have ice forming underneath the bottom freezer draw, when I open the door it melts and runs out as water under the appliance.
drain is plugged up were it is normally drain to defrost the freezer completely find a place to store food in freezer for a few ours leave door of freezer open pull out all shelfs and lay a few tools down at bottom of freezer were you seen the ice build up after you have done that pull ref away from wall take back of bottom look fro drain pan with a turkey baster send water thru back of freezer inside if water still flows back out into freezer drain tube is still clogged use warm water when doing this if you see drain pan full of water use a shop vac that can deal with water suck out water send water again water should go strait to drain pan if still flows out may have to remove drain tube
Aug 23, 2011 | Daewoo Freezers
No drain plug in freezer to drain water out when defrosting?
The drain hole is behind the back wall underneath the evaporator coil. Im guessing you have ice on the freezer floor. This is because the drain tubing from the freezer to the drain pan underneath is clogged. There will likely be ice that will need to be defrosted in the drain tubing in order to get to the clog. Once the ice is removed, I use compressed air when I perform this refrigerator repair service.
Sep 27, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 | Freezers
My freezer is over freezing and my fridge is undercooling. there is also water collecting on the top shelve of my fridge.
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 06, 2009 | Kenmore Freezers
Ice at the bottom of freezer ice at the bottom of freezer, defrost water not draining
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 30, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Mar 05, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Water on bottom of freezer
most commercial freezers have a drain to the back of the compressor area where the condensate goes into a pan and is boiled off into the air by a loop of hot gas tubing in the pan or an electric heater in the pan. when it defrosts the ice on the coil melts and the water flows out . if the tubing gets plugged the water flows out of the pan and down into the bottom of the box where it refreezes on start of the next refrigeration cycle. clean and clear drain with a shop vac or air hose where water can flow out of pan under the evaporator coil when it defrosts. if you have a domestic residential freezer , most of these have no defrost and neeed to be shut down and manually defrosted every few years. if you leave the door ajar or it doesn't seal well ice builds up and can accumulate in the bottom as frost etc. it would be mosyt unusual for a residential box to have a defrost clock, drain and all, but possible and same rules apply. find the drain and clear with shop vac .
Nov 02, 2008 | Woods Freezers
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Whirlpool 247 cu. ft. Upright Freezer EV250NXRQ Logo
168 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
