Question about Canon PowerShot A20 Digital Camera
The screen on the camers does is just black and does not show the image how do i fix it. it is a powershot A20
  • Canon Master
  • 4,738 Answers
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't correct the problem, then a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Sep 06, 2010
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/26928900@N00/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
Canon Powershot A20: One Compact flash card works fine and I'm able to download the pictures. The other card (which was used in a Canon A40) is not recognised by the computer, although you can review the...
about the cards their models must be not same that's why you don't get the soft copy of other pics on your computer ..or
For those of you with a Canon camera of the above models; there is a firmware release that will make the autofocus work a bit better.
Here are the links (a40,a30,a20,a10)
http://www.canon.co.jp/Imaging/PSA40/PSA40_Adjustment-e.html
http://www.canon.co.jp/Imaging/PSA30/PSA30_Adjustment-e.html
http://www.canon.co.jp/Imaging/PSA20/PSA20_Adjustment-e.html
http://www.canon.co.jp/Imaging/PSA10/PSA10_Adjustment-e.html
It mainly fixes the soft-focus problem with the second to last telephoto setting:
In case you haven't seen this problem, take an A40 and zoom to the furthest optical setting (3x). Take a pcture; preferably something a dozen meters away or so. Then just touch the button lightly to zoom back one step (there are 7 zoom settings in total if I recall; maybe only 6); and take the same photo. When you compare these the soft setting of the second photo should be apparent.
The firmware went smoothly for me and is fairly simple to do.
Hope this helps someone.
Mar 30, 2011 | Canon PowerShot A20 Digital Camera
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
Hi, my powershot S60 auto setting will only take movie images no still pic's. I've reset to manuf. settings but still no change. Any ideas whats wrong & how do I fix it?
What do you mean by "no still pics"? What exactly is happening? If the camera is showing a black or distorted screen when set to photo, and photos that are taken with the black screen also show up black or distorted, then this would likely be a CCD imager failure, a common occurrence for your model camera.
If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 30, 2009 | Canon PowerShot S60 Digital Camera
When I turn on the camer, the screen is distorted
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jul 14, 2009 | Canon PowerShot A80 Digital Camera
Black LCD display on Canon Powershot S60
Jun 30, 2009 | Canon PowerShot S60 Digital Camera
CANON POWERSHOT A70 CAN NOT TAKE PICTURE DUE TO NO IMAGE SHOWING STARTED OUT GRAINY(LIKE A TV W/ NO CABLE)NOW THERE IS NOTHING THERE WHEN CAMERA IS TURNED ON. i CAN STILL SEE PICTURES THAT HAVE BEEN...
Your Canon A70 is one of those camers made with bad CCDs. That is the image sensor has known defect after production and market launch. Instead of recall their products, Canon offer owners to send/bring in their camera for CCD replacement without service/parts charge. Go to Canon web site to find an authorized service centre nearest to where you live, phone them up to confirm free service. You may either mail in or bring it to them in person. As far as I know, Canon will reimburse the shipping cost to you as well as sending the fixed camera for free.
Take a look of a third party comment/information regarding the bad CCDs by clicking here before taking further action. It didn't show black/blank screen as a symptom, but individual manufacturer web site did mention them as symptoms.
Jul 26, 2008 | Cameras
Unable to see image
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info. I think you'll be very pleased:
Mar 24, 2008 | Canon PowerShot S1 IS Digital Camera
LCD Screen blank
Don't fret! This sounds like a defective CCD imager. If so, Canon should fix this for you worldwide for free, including free shipping both ways. This is regardless of your camera's warranty status. They just fixed my three year old A310 for free last month. Please check the following two links for more info:
Dec 17, 2007 | Canon PowerShot A310 Digital Camera
It doesn't take pictures...
Sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
Nov 02, 2007 | Canon PowerShot A80 Digital Camera
Canon PowerShot A20 Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
