Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Reigerator side not cold no cold air coming in. Freezer working fine
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 06, 2010
Reigerator working but does not freeze or get cold.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Dacor IF48NBOL (297 cu ft) Side by Side...
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
Refridgerator side not cold freezer side fine
Difficult to properly diagnois with such a brief description, but try the following as a good first step at correcting the problem. Reset the freezer and fridge thermostat settings at the factory default. Also, check the freezer section to make sure nothing is blocking the cold air supply vent into the fridge, do the same on the fridge side too.
Normally is the freezer is working fine, and the fridge is warm, it can be due to either a blockage of the cold air cross vent by items in either the freezer, fridge, or both, preventing proper cold air flow from the freezer into the fridge. Also, check to see if the cold air vent is not frozen or obstructed, with a fashlight (you;ll need to remove stuff from fridge and freezer to make this possible to check.
If the vent is not obstructed and you can clearly feel cold air passing from the freezer into the fridge, it is possible that the cold air vent control has ceased operating properly and needs to be replaced. Usually though this type of problem is caused by people over stuffing things into the freezer section and blocking the cold air cross over vent. Hope this helps.
Jul 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Sep 24, 2008 | Hotpoint HSS25GFP Side by Side...
Appliance: Frigidaire 3.1 Cu. Ft. Compact Refrigerator Problem: How do I adjust freezer temp in my mini-fridge with top frost free freezer, has turn dial for refrigerator but no turn dial for freezer and...
The turn dial that controls your fridge temp also controls the freezer temp. The freezer air is directly forced into the freezer compartment and then sent to the reigerator. Adjust the dial for the fridge not to be so cold and it will adjust the feezer also. Allow about 24 hours for any noticeable change.
Apr 19, 2008 | Refrigerators
Freezer works; fridge side doesn't
First thing to check is look and see if there is  thick frost build up on the back lower panel inside the freezer?  If not there must be a problem in the damper (vent).  Let me know what you find so I can help.
Oct 21, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Frezzer is fine but fridge is warm
See if cold air is coming out of the air diffuser top-back freezer side of fridge. A common problem is a bad air diffuser assembly. Sometimes it may freeze closed and break when it tries to cycle. The freezer usually works fine.
Aug 05, 2007 | Kenmore 53602 / 53604 / 53609 Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
53 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
