Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Gfi turns off and motor quits, tub gets cold - Dream Maker Spas Dream Maker Ez Spa Hot Tub
  • 6,826 Answers
I'd try a different brand Ground Fault Inerrupter in the Circuit Breaker Box, if that's where it's located.
Or, find the source of the ground fault and correct if necessary.
Posted on Sep 06, 2010
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
I have a GE two speed motor/pump for a hot tub that I have adapted for a type of therapy called underwater pressure massage (all of the hot tub jets are channeled through a single hose for the high...
Disconnect both hot leads from the breaker at the box. Using an ohmmeter measure the resistance to ground or the neutral bar in your box. If the resistance is LESS than about 50 K you have excessive leakage current. It is unlikely the motor is the problem. I would check the wiring and switching for the leakage. Now to the second problem: If you switch between speeds while the unit is running, the GFI will LIKELY trip. This is normal as you create a massive transient that the GFI PROBABLY can't handle. There are a couple things to try: One is using a two pole control switch and turn off the pump before "switching gears" ... as an electrical engineer I can't explain this unless you can understand electrical transients AND capacitive coupling between the windings and the case of the motor. I realize you may have a combination speed and on off switch so you MIGHT have to add a switch. Ideally I would want a relay for on/off near the breaker that momentarily disconnected before shifting gears. The next fix possibility involves a trick we use to control transients in electronics. This involves noise control by using a toroid around the pair of hot wires. This MIGHT take several turns through a good sized ferrite toroid with both the hots in the same direction, side by side. This forms what we call a "Bi-Filar" choke. Look that up on Google to understand the principle... it essentially helps balance the currents in the hots and isolates them from ground for transients.
May 08, 2011 | Bryant 50 Amp 2 Pole Br250 Type Br Ni...
When I try to turn off my Jacuzzi tub it will not turn off. I pushed the gfi and it went off. I then reset it a few days later and the tub would not turn off and this time the gfi would not shut it off. ...
You will need to have a technician from the store you purchased it from install a new switch.
To be up to code, you should have a GFI for your Jacuzzi to plug into and a GFI circuit breaker dedicated only for your Jacuzzi. I
If you already have it, that's great, but if not check with an electrician for installation.
Regards
Apr 05, 2011 | Jacuzzi Mito, 5 Soaking Bathtub -...
My Whirlpool ciello only has a 2 prong plug. How do I ground the tub?
You can go to any metal part of the tub or electrical part (motor - valve - connection) and fasten a ground wire to that part using a nut and bolt or screw. I would suggest you use a screw that is already on the motor. Run the ground wire to a known good ground. The ground doesn't necessarily have to be the electrical outlet (a cold water piper, for example). There is that possibility that there is nothing metal that you will find exposed. That makes it a little tougher. If this tub came this way from the manufacturer (two prong plug), it is probably exempt from the grounding requirement. I would suspect that the manufacturer wants you to plug this device into a GFI. You can get a GFI at any store that sells electrical parts. A separate ground is NOT required for full protection when using a GFI. All consumer grade GFI (they look like a regular, rectangular outlet) come ready to accept a three prong plug and there will be a place to fasten your house wire ground to the device. As I said, the ground it not a requirement for correct and complete function of the device. If you don't have a GFI available where you are connecting the plug, change it or get a qualified electrician to change it for you. DO NOT, UNDER ANY CIRCUMSTANCES, PLUG THIS DEVICE INTO A STANDARD OUTLET . Use it only on a GFI protected circuit. The outlet you are considering may already be protected by a GFI breaker. You can only prove this by finding the breaker, turning it off and checking the outlet in question. If it is a GFI breaker, it will look different from the others - and have a test button on it. If you are unsure, replace it with a new GFI breaker. I suppose I should also say here that you should check with yout town building inspector as to the requirements before you proceed, so you will meet any local code requirements. If you live in North America, I am certain the GFI is a requirement for this installation, as the National Electrical Code requires it, (Canada and USA).
Thanks for your question here @ FixYa.com today.
Jan 06, 2011 | Whirlpool 5"x36" White Bathroom Drop-in ...
My jacuzzi tub will not come on . fist it was making a humming sound , i turned it off checked the reset plug tried to turn it on and not a sound
mine did the same thing. the tub is plugged into a ground fault interupter (gfi) plug. hit the reset button. if this doesn't work, check the circuit the gfi is on, sometimes they are on the same circuit as the plugs at the sink. check them for reset also. if this fails, on the motor of the tub, there should be a reset button. try to reset it. OH first make sure the breaker has not been tripped.
Jan 04, 2011 | Jacuzzi 4481-959 Nova 5 Soaking Bath 5'-...
Kohler Whirlpool tub motor problem. Turn motor on and trips GFI. It looks like the GFI is wired right and suggestions
Unplug tub from GFI, does GFI hold, plug something else into GFI to see if it holds under load. If all is ok then make sure you have a good ground from the motor to the GFI and the polarity is good. If 120 vac black wire to gold post, white wire to silver post and ground to green. Check proper connections, including polarity and ground at tub junction box and at pump motor it self.
Mar 21, 2010 | Kohler Home
2 yr old softub Hot tub with connected GFI wire was emptied and cleaned out and filled; now the GFI trips when pluged in, and will not turn on!
Either the GFI is bad or it is tripping because there is a short in the system (obviously, right). I would turn off your panel break, disconnect the GFI and using a meter test to see if there is a short in the system. You would check the hot lead coming from the GFI to the tub and see if it is shorting. If you can't find a short, you should try replacing the GFI. If there is a short then you need to search for the short. Hope this helps and good luck!
Mar 14, 2010 | Leviton 8599 GFCI Receptacle
Kohler Whirlpool tub motor wont turn on
Kohler Whirlpool tub turns on and shuts right off. Reset gfi and motor turns on and shuts right off. Help
Mar 15, 2009 | Kitchen Appliances - Others
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
89 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
