FixYa.com
Tags:
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS
Broadband Speed
posted by bardig on May 13, 2008
My AOL Platinum Broadband appears to be running rather slowly - could the problem be router performance - How do I check - Thanks in advance
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 13, 2008
Not Rated (0)
rickatnight1
Rank:Guru Guru
Rating: 85%, 41 votes
First make sure that you don't have any devices straining the network. Culprits of this could be spyware on one of your user's machines, someone downloading large amounts on your network, and an unsecured network that allows anyone to connect.
A possible way to eliminate the router being the issue would be to disable the wireless access through the router's administrative panel, and then connecting directly to the router with an ethernet cable. Before doing this run a speed test at http://www.speedtest.net/ and then disable the wireless.Try surfing the web to see if there is a noticeable difference, and then run another speed test.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Routers problems?
D-Link ADSL2/2+ Modem/Wireless Router 4-Port...
disconnect
My internet connectin is... Answer This...
Username & password
Attn: tech curly, How do i... Answer This...
adsl2+
i bought a wireless G ADSL2 +... Answer This...
i need the drivers to
i need the drivers to make it... Answer This...
About D-Link Modem
i have D Link ADSL 2 + Router... Answer This...
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
