Question about Helio Ocean Cellular Phone
Bluetooth problem I have followed all instructions in the manual to turn on Bluetooth (including putting it in Display Mode) but no other Bluetooth capable phone seems to pick up the signal so I can't reiceve anything via Bluetooth. I have alot of ringtones on my old phone that I want to send to my Helio Ocean but no way to do without other phones being able to detect the Helio. Please Help.
    Filmmaker:
    Uploaded 5 video answers.
  • 43 Answers
The helio does not allow file transfer to and from other devices. It will print pictures to some bluetooth printers and of cours headsets/headphones.
Sorry, I know how you feel it is an awesome phone and I was dissapointed too!
Posted on Jul 23, 2009
  • Jonathan Smith
    Jonathan Smith Jul 23, 2009
    The helio ocean does not allow file transfer to and from other devices. It will print pictures to some bluetooth printers and of cours headsets/headphones.
  • Jonathan Smith
    The helio ocean does not allow file transfer to and from other devices. It will print pictures to some bluetooth printers and of cours headsets/headphones. you can email them
Bluetooth keyboard will not connect
I'm assuming Bluetooth is turned on on the ipad.
follow the keyboard instructions to put it in pairing mode.
Then in ipad settings - Bluetooth you may need to select the keyboard.
Feb 26, 2014 | Apple iPad Mini
I don't have the manual anymore and I forget how to pair the blue trek car kit with my phone. Please help!
Try this:
1. Put them close together
2. Switch on phone and select bluetooth discover mode (make sure it's visible to other devices)
3. Switch your BlueTrek device. Press and hold both Talk and Vol+ button for about 5 seconds until the indicator light flashes red and blue alternatively and sound can be heard from the speaker.
4. The phone should then detect the Bluetrek device. Follow the instructions from the phone to accept the pairing request. If you didn't change it, the PIN code should be 0000 (zeroes).
Hope this helps.
May 04, 2011 | BlueTrek Surface sound Duo Bluetooth Car...
Kindly help me connect my samsung HM1100 bluetooth headset to my playstation 3
1) Go to "Settings" on your PS3.
2) Scroll down and select "Accessory Settings."
3) Select "Manage Bluetooth Devices."
4) Select "Yes" when the message "The Bluetooth device has not been registered. Do you want to register?" is displayed.
5)
Turn on your Bluetooth headset when asked by the message "To register (pair), you will need to prepare the Bluetooth device. For information on preparing the device, check the instructions supplied with the Bluetooth device." While each Bluetooth headset is different, for most this means to hold down the power button until the blue light on the device remains solidly lit.
6)
Select "Start Scanning" once your Bluetooth headset is in "pair" mode. Wait for the PS3 to scan for your Bluetooth headset. If the scan was successful, your Bluetooth headset will be listed on-screen. Select your headset from the list
7) Refer to the Bluetooth headset's instruction manual to find the pass key for your device (Usually the pass key is something simple like "0000" or "1234". Press "X" to bring up the on-screen keyboard and enter the pass key. Select "Enter" then "OK." "Register Completed" will display to confirm a successful connection.
NOTE: If the headset does not display after a scan, it may not be compatible with the PS3, or it is not properly set to "pair" mode. Refer to your Bluetooth headset instruction manual for directions to properly set your device to "pair mode."
If you want to check the User Manual for your Bluetooth, simply click on the following link:
http://www.samsung.com/us/support/downloads/BHM1100NBACSTA Click on the Icon below "File" Thank you.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
Need to know how to sync speak easy bluetooth CBHV2 (Scosche) with my cell phone. Lost manual. Bluetooth function on phone CAN NOT FIND DEVICE. Is there something I must do. Thanks
I had to figure it out on my own... The easiest way for me was to hold down the phone icon until it turns on, then hold down the volume down button (-) to turn on voice.... Then hold down the phone icon again to turn off... Then hold down the phone icon again until device tells you to put phone into bluetooth mode, seach for bluetooth devices, follow the rest of the instructions, and you should be all set.
Sep 19, 2010 | Car Audio & Video
How do i connect the bluetooth to my ps3
You need to put both devices into "pairing mode" Follow the instructions in your manual on how to do this. When both are in paring mode your headset will detect your Ps3.
Apr 21, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I can't get Jabra BT 2050 bluetooth into pairing mode. I follow the instructions but never get the solid light. What can I do?
Booklet instructions for how to pair it with a new device are wrong. It tells you holding the power button will put it into pairing mode but it does not.
Pairing mode is done by turning off the ear piece, then holding both power and answer/hangup at the same time. The LED should flash fast 3 or 4 times and then stay on solid. You might need to hold just power till the very first flash THEN begin holding answer/hangup as well as power till the LED goes constant. I’ve also had luck when frustrated by just holding all 4 buttons at once.
Oct 10, 2009 | Jabra BT2050 Bluetooth Headset
Lost instruction manuil for my mad catz bluetooth wireless headset
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
You can obtain a copy of your user manual by locating the FCCID on the label directly on the device, then then going to the FCC Website - https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Be sure to put the first three characters in the first box and the rest (including hyphens) in the second box.
Sep 04, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
LG HBS-200 Bluetooth Stereo Headset user manual instructions needed to pair with blackberry
User Manual
Aug 30, 2009 | LG SGBS0001606 Bluetooth HBS-200 Stereo...
Nexxus bluetooth car kit
To pair you must first turn bluethooth feature ON on Sony phone. This usually has an indication on lcd display when it turned ON (it looks like a headphone sign) the you must turn visibility of your phone ON making it ready to be paired. Following instruction that came with bluetooth kit put bluetooth in pairing mode when its in paring mode led lights will rapidly fash. At this point you phone should pick up bluetooth if it doesn't then do a search for bluetooth devices with your phone and it will find the bluetooth (make sure its in pairing mode) It will display the bluetooth type and model number. It also may ask for security code if it does it 0000 set by default. Then pairing should be complete just save and you should be good to go. Good luck and thanks for using fix ya
Jan 28, 2009 | Cell Phones
Helio Ocean Cellular Phone Logo
Top Helio Cell Phones Experts
Shehu Pro
Shehu Pro
Computer Repairing
Computer Repairing
Are you a Helio Cell Phone Expert? Answer questions, earn points and help others
