Question about Maytag M3X05F2D Air Conditioner
My maytag window ac unit: m3x05f2d-a (5000 btu) needs some exterior parts. The accordion plastic pieces the fill the gaps in window installation have cracked and I need to purchase replacements. Please help me find and purchase.
I need the accordian plastic pieces for my matag 5000 air conditioner .. Bought it at home depot
Posted on Apr 15, 2011
We do not have a window in the room this need to be installed in. Does the window installation kit allow us to install the pipe that goes outside through our exterior wall of the house? Like a dryer vent...
I think you probably could. As most manufacturers of portable AC units allow for this. It's what called a semi -permanent installation . The dryer duct idea will work if the shaft part of the dryer duct is the same diameter as the window mount duct and the shaft of the dryer duct is long enough to go thru the wall and leave enough for the AC Exhaust Duct to hook to. Be sure that the flap door of the dryer duct moves freely and will not get stuck in the closed position. That could be a big problem if it does.
Keep in mind, you will not be able to add any length the AC duct hose. It must remain the same.
Hope this helped answer your question and things for choosing FixYa.
Aug 01, 2011 | Sovereign Royal 9000 BTU Portable Air ...
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
I HAVE A 5000 BTU G E WINDOW UNIT I PURCHASED AT LOWES LAST YEAR, IT DRIPS DOWN OVER MY PATIO IS THERE A WAY TO INSTALL A DRAIN ?
a plastic pan under the unit with some small hose can divert the water elsewhere. use silicone calk to seal the hose in the hole you drilled in the bottom of the pan NEVER DRILL THE PAN OF THE AC UNIT ! use something to catch the water.. if you drill the unit, you take the chance of hitting one if the AC lines !!! there no fix'n that
Jun 06, 2011 | GE AEV05LN Air Conditioner
Can the outside area of a window ac be hosed out while it is in the window?
Hello, it is better to remove the unit from the window and place it out side, this way when you spray the water and you can be sure it does damage any components. When spraying the water dont use too much pressure.
May 30, 2011 | Maytag M3X05F2D Air Conditioner
No problem with unit. Is this air conditioner CSA or OSHA approved ?
It's not the unit that you have to worry about for CSA or OSHA. It's how you intend to install it. You have to use the proper installation guidelines as approved by OSHA. I do know that going outside a wall or window you must have the proper bracket/frame installed outside the exterior wall to prevent it from falling on someone's head if high enough. If down low, they still have to be braced/bracketed properly to avoid injury. That's standard procedure.
http://www.osha.gov/SLTC/indoorairquality/
You need to find out what OSHA has for safety guidelines and restrictions. Also check with your local building code office to check with their pre-set guidelines. They have to be automatically in compliance with OSHA if they intend to operate guidelines for business purposes. So Call either- or both. It's not the unit you need to worry about unless it's very old. Good Luck.
Mar 10, 2011 | Maytag M3X05F2D Air Conditioner
I have a LP1010SNR 10K BTu. Trying to install.
Yes. As long as the seal fills the gap from sill to unit the width will be just fine.
Jul 08, 2010 | LG Heating & Cooling
Hi i have a Maytag 12000 btu Window ac unit that
I had a similar problem with my AC last week. These newer capacitors no longer have PCBs in them. The stuff they use now just ain't as good. As a result their are more capacitor failures tan ever. I would check that. If the cap looks swolen its probably bad.6f0f1c5.jpg52ae98e.jpgYou should also try and lubricate the motor. Use HVAC oil 106f87c.jpg$2 at Ace hardware store.
You gonna have to slide out the unit a little to get to the motor. Have rags ready.
Jun 18, 2010 | Heating & Cooling
Window or wall mount
The differance between a window and wall mounted A/C is the mounting system.
Window units are usually smaller BTU systems they set in the window, so you do not have to cut a hole in the wall to install it.
For a bedroom say 10 x 10 you can use @ 5000 btu it plugs into a standard 120 volt electric outlet. If the room is bigger then go bigger say @ 6000 btu or so. Take your room dementions with you when shopping for a unit. sometimes they have sizing on the side of the unit box.
Wall units are usually larger units. Like whole house 18,000 btu
they slide in and out of the case and use a 240 volt seperate circuit.
Best place to shop for A/C's are Home Depot, Lowes, Sams Club, B.J.'s, and Cosco they buy in large volumeusually give a Good deal I've seen 5000 btu units as low as $89.00
Just don't drop the unit out the window when installing it
From the second floor it will void your warranty. LOL
Good Luck Phil
May 19, 2008 | Frigidaire FAC124 wall/Window Air...
Maytag M3X05F2D Air Conditioner Logo
322 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
