Question about Garden
I recently replaced the ignition module on my Vac-Attack II blower/vac. I need to know what to set the gap between the module and the flywheel. Also what is the correct gas to oil ratio? Thank you.
  • 11,896 Answers
40:1
.035
Posted on Sep 06, 2010
Adjust ignition timing gap
CLOSE! put two pieces of paper against the Flywheel, then put the Coil in place loosely. rotate flywheel until magnets hold the coil to the flywheel ( with paper in between) then tighten
Nov 21, 2013 | Troy Bilt Tb320bv Spring Assist Blower/Vac
My Homelite Vac Attack II is 4 years old and I
fit new pump ad float diaphragms in the carby
the fuel mix has become irrelevant as Stihl have an oil that is a 50:1 oil and covers all ratios and mixtures
do not use any e-mix fuels as that destroys carby components
Aug 09, 2017 | Homelite Leaf Vac Attack
What is the gap spacing between the ignition module and the flywheel for a PoulanPro PPB2000 blower/vac?
0.010-0.012" or a 'quick tip': you can use the cardboard of the box the coil came in, or the parts tag that may have been attached to it. Those should be close enough to get you going.
Nov 13, 2009 | Poulan Garden
Vac Attack II leaf blower knocks like HELL.
Is your fuel mixture ratio 40:1? Plus there is not adjustment to the timing. It could be a loose flywheel or a rod bearing going, or a loose impeller. Basically something at the factory did not do there job. It has a 1 year warranty on it. Or you can take to a shop and for a diagnostic fee, have an estimate done to see what it would cost to fix.
HTH
Good Day.
Oct 30, 2009 | Garden
I am gettinno spark from the spark plug I have put in a new plug,
first check to make sure the on/off switch isnt shorting out anywhere. try resetting the gap between the flywheel and the igniton module. you can use an index card or manilla envelope to set the gap. if it still doesnt work try replacing the module
Nov 22, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
