Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My cub cadet 2140 batery will not stay charged. and my PTo will not engage and my amp light is on?? I believe my altenator or what ever give me power when the engine is running is not doing its job. But I cannot find if this has any altenator? Any help would be greatly appreciated. Thanks Billy
  • 472 Answers
Sounds like the stator is burnt up if t`hats it you will need to re place the fly wheel and the regulator
Posted on Sep 07, 2010
My cub cadet pto will kick off when you go faster, it will only run when you are just barely moving
If you are referring to an electric PTO here is the way they work. They need good current from the battery to stay engaged because they are a electric clutch and if the charging system is not supplying the right voltage to keep the battery at a good state you would have a charging problem. Another could be the clutch may be worn enough to cause the problem and that would be the most likely cause if you have a known good or new battery. Hope this will help you.
May 30, 2017 | Cub Cadet Garden
1806 cub cadet PTO blows fuse when engaged
check the pto switch..un hook it if thats it then replace
Nov 19, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Does a cub cadet model 2544 use a alternator to charge the battery my battery is not holding a charge alredy put in a new battery
yes it has a low amp charging system charge the battery and disconnect the neg cable install a test light between the cable and the battery if the light is on there is a draw unplug the harness that goes to the charging system if the light then goes out the diode on the charging system is bad
Aug 06, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Jul 09, 2010 | Oregon Scientific Electric PTO Clutch for...
Cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Jul 06, 2010 | Cub Cadet Street Sign- tractor lawn riding...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Jul 24, 2009 | Mtd Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
219 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
