Question about Kenmore Refrigerators
The ice maker on my Kenmore refrigerator makes crushed ice in both the CUBE and CRUSH modes. The rod that is supposed to operate to divert the ice cubes from the crusher is not operating. It appears that a solenoid or relay that actuates the rod is not working. can you suggest a repair for this problem?
  • 787 Answers
I strongly recommend calling in a technician to change the relay that activates the rod. I've seen countless refrigerators damaged by the owners trying to apply the fix themselves.
Posted on Sep 06, 2010
Mu Kenmore refrigerator's ice maker is dispensing crushed iced even in the cube mode
Take out the ice bucket and check the metal arm and make sure it moves freely. Ice may have gotten stuck.
Jul 20, 2016 | Kenmore Refrigerators
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
My ice maker is crushing the ice despite the fact that I have it set on cube. I have dumped the ice out of the catch tray twice and made sure that the dispenser is not blocked, but it still continues to...
the bottom of the tray has a rod attached to it that controls a flapper that opens up to allow the ice to pass thru without hitting the cutter or crush blades. this rod goes into a housing at the back of the freezer that has a solenoid switch that activates it to open it up. check to make sure all of these items are free of ice and in their proper position and or not broken. if this all looks good then you may have a bad solenoid switch.
May 29, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice maker stuck on crush, continues to crush ice when cube button is pushed.
Remove ice bucket,check solonoid on back wall behind bucket may be stuck in up position pull down and recheck dispencer.
Jul 14, 2009 | Frigidaire GLHS66EE Side by Side...
Ice maker will only make crushed ice
There is a rod on the back of the ice cube bin. It goes below a plastic slide in the back of the fridge. If yoiu pull the bin out and it does not engage right, you will be 'stuck' on crush. Pull the bin part way out and see whether the rod is going below or above the horizonal rung in the rear. If it is above, rotate the metal control until it will slip under the rung.
Apr 17, 2009 | Frigidaire Refrigerators
My ice-maker keeps switching to crush on it's own.
There is a long rod on the right side of the ice dispensing bucket.
This rod goes through a hole in the back wall of the freezer where a solenoid should pull up on the rod allowing the ice cubes to dispense without being crushed.
If this solenoid goes bad or ice forms around the plunger, it cannot pull up on the rod.
Check out that solenoid and the rod assembly.
https://www.repairclinic.com/Frigidaire-Refrigerator-Parts
appliance parts, help & more
Apr 13, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice maker only operates on crushed ice mode
There should be a solenoid behind the ice bucket that moves an metal arm on the ice bucket to move the crush teeth away for cubes or keeps the crush teeth in place for crushed cubes. Bad solenoid, bad wire at the solenoid, broken solenoid/mechanism piece, bent arm, no power from dispenser to the solenoid are -some- possible trouble makers.
Also the solenoid that controls the crush/cube function is probably frozen. First, pull out your ice bucket. On the bottom of the bucket is a long metal rod the runs all the way to the back wall of the freezer. That rod runs into a little square hole in the back of the freezer. The hole is about 1 and half inches square. Just put your finger in there and see if the solenoid plunger moves up and down easily. If it doesn't move, then it is frozen. Just hit that area with a hair dryer and it will release. If it moves easily, then make sure that the the rod on the ice bucket is seated in there properly
Feb 09, 2009 | Kenmore Refrigerators
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser crushes ice when cube is pushed
the little gate/door, is a common issue, its a solenoid htat either burns out, or merelt freezes over. if you put your finger into where teh "shepard hook" supposed otgo, can you freely lift it ip and down???i would assum not, .the entire ***,bly lifts out of freezer( remove 2 1/4 inch scres under each corner and diconnect apower plug behind the ice maker. from ther you can try to defrost teh piston,if not rplace it.
Jan 02, 2009 | Frigidaire GLRS267ZA Side by Side...
Ice dispenser is stuck in crush mode
Carriage that moves ice bucket rod up is frozen.It's right by the auger drive mote on the left- square hole. Remove bucket and try to free it with your finger. If no luck take hair dryer until you can move it up and down.
Nov 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
