Drum seal "holed" where can I get a replacement?..
  • Washing Mach... Master
  • 3,463 Answers
Check your local phone directory to find a dealer that repairs or services washing machines, or contact the manufacturer direct.
Posted on Sep 06, 2010
Replacing door seal on w698 miele
Normally they're held on with 2 wire rings, 1 at the edge of the seal at the door opening and the other on the edge of the outer drum. Unplug your machine and remove the lid, this will help access and give you more light to work with. Remove the ring at the door opening first and pull seal from the lip. Access can now be made for the one at the drum. Do the same for the one on the drum.
When putting in new one reverse the procedure and start at the drum, make sure you have the seal the right way around, normally holes in bottom of seal for drainage. Thread the seal over the lip and then put ring on. Same process for the front. Put lid on and plug machine in and test for leaks.
Dec 29, 2012 | Miele W865 Front Load Washer
Door seal
It's held in place by 2 metal rings, 1 just at the edge of the seal of the door opening and 1 at the edge of the seal to the outer drum. Unplug your machine then remove the 1 at the door opening, this will allow acces to the 1 at the drum. If you remove the machine lid it will give you a bit more light to work with and you may be able to access the ring easier to remove it.
Refitting is the reversal of removing it. Fit the drum one first and then the door side and make sure you know which way around the seal fits, usually has drain holes in the bottom section of the seal near the outer drum.
Dec 29, 2012 | Washing Machines
Leaking water under drum area seems to leak more with larger load
Check the gray rubber seal by the door. Look all around, inside the folds, for a hole. (usually found on the right or left side) Replace door seal if hole found.
Jan 26, 2011 | LG WM-2277HW Front Load Washer
Hotpoint WMA30 is leaking a small amount of oily water from the back of the drum when in use. There is a small hole in the back of the drum, should there be a screw in this hole that has fallen out?
Thwater is leaking because the shaft seal has worn, and the hole is supposed to be there as it is a drainage hole.
The outcome will be that the main drum bearings will eventually fail as the water will get into the drum bearings.
To replace the seal involves a complete strip down of washer. not a job to be undertaken by yourself, unless you know what you are doing.
Nov 14, 2010 | Hotpoint WMA30 Front Load Washer
Replace door seal
its not to easy to do but,,,
look at the bottom of the washer were the door closes the seal is held on with a spring wire,,unhook this wire and fold the seal inside the washer,,look for the inner drum there is another spring wire holding the inner part of the seal to the inner drum undo this as well,, pull old seal out through the door hole,,,now fold new seal so that the inner wire can be fitted round the new seal first to the inner drum,,then pull the new seal through the door hole and fit the outer wire to seal,,,
and then job a good un?,,, not easy a,,well i did tell you this!
Jul 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Faulty bearing in the drum
If sealed bearing, drill small hole after removing rear plate and inject grease with syringe,seal hole with stopper or self-tapping screw.
Run for about 20 mins. to allow grease to penetrate.
Jan 04, 2010 | Washing Machines
Rubber seal damaged. needs to be replaced kenmore model 970-c44052-00 How do I remove sides to get at it?
there is no need to remove the side to replace the door seal, just behind the door seal there is a spring clip undo this and fold the seal into the drum were you should see another spring clip undo that as well and the door seal comes out from the front through the hole in the door, to refit a new fold the seal till its inside out and fitted on the inner drum first fit the inner clip then pull it through the door hole and fit the outer spring clip out side the door
Dec 06, 2009 | Kenmore 43142 Front Load Washer
Maytag Neptune MAH5500B leaks. The leak is from a small hole in the outer plastic drum. The hole is at the six o'clock position where the large pulley that turns the inner drum is attached. There is a...
You most likely need a new outer tub,the bearing seal is shot eventually it will get gradually louder in spin if it hasn't already,you can try having the seal replaced and that may stop the leak but the damage to the bearing is already done.
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Replacing door seal
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Sep 15, 2008 | Zanussi FLE1416W Front Load Washer
WASHING MACHINE DOOR SEAL REPLACEMENT
Sep 17, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
