Question about Brother Office Equipment & Supplies
Fax machine at work was working then all of a sudden, we did not have a dial tone, just static! What to do? Thanks, dl please respond to tapdancerdl@yahoo.com
    Genius:
  • 1,218 Answers
Plug a regular phone into the fax line..unplug the fax mchine...if you still only have static then you have a problem with the fax line and should report it to your phone provider...if you do have dial tone on the telepnone but not off the fax's phone then you have a prob with your fax machine.
Posted on Sep 06, 2010
Why did my fax machine suddenly stop working?
Check that the memory is not full. Also, make sure a setting like (auto-dial 9 for outside line) is set incorrectly.
May 17, 2015 | Office Equipment & Supplies
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
None of our faxes are going out and we receive error number 87
set the fax so you can hear dial tone... if no dial tone then check the fax line.... if fax line plugged in... plug it out of the fax and plug into a phone... if still no dial tone then change fax cable... if dial tone... then call your cell... if static... fax wont work call phone company... if you get a funny signal call phone company...
Dec 10, 2009 | Office Equipment & Supplies
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
FAX function stopped working
honestly, it sounds like you have the phone cord and the fax jack swapped backwards, make sure you have the fax line plugged into the correct jack on the machine. 1 is for the handheld phone and the other is for the telephone line... give this a shot...
Mar 10, 2008 | Brother MFC-7220 All-In-One Laser Printer
After static shock, keypad on fax machine is not working...everything else ok
Most office machines are properly grounded and don't suffer from static problems as severe as this. The machine is not repairable. Before you replace the machine, make sure that your electrical outlets are properly grounded. Then buy a line conditioner that will protect against this.
Nov 30, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
I can't fax! BUSY/NO RESPONSE
go into menu
go to fax settings
find send
click auto not manual, please make sure that when you push the hook key you hear a dial tone. always reminder that every fax machine has the capablitiy of either dial or tone. now if everything is set up properly  the problem will be in the tx portion of the board. if you can link up with somebody close to you and try to transmit back and fourth that will let you know if it is their problem or your. it may not be your problem.
Oct 21, 2007 | Brother IntelliFAX 1840C Plain Paper...
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
