Question about Insignia NS-LCD22-09 LCD HDTV
My Insignia NS-LCD22-09 LCD HDTV powers on fine sound is good, display is problem, almost as if the screen cannot catch up to the information that is sent, all menu windows/ boxes appear slowly, has picture but "smears" with any movement on screen, happened once before, powered off then back on & then fine tv is maybe 2 yr old
  • 36 Answers
Your mainboard is deffective...go to service center for spareparts
Posted on Sep 06, 2010
  • gbarks66 Sep 06, 2010
    is that the same as the controller board?
Insignia ns-55l260a13 does not power on. Power led blinks 5 shorts, pause, 2 shorts and stays on. Screen blinks and nothing else happens afterwards.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 23, 2016 | Ideal Sales New Insigniatm - 55 Class -...
Need manual for my tv,XVA133DLM-080507-01196
Product Support ' Insignia
www.insigniaproducts.com/support.html
Manual, Firmware, Drivers & Product Information. Most of ... For OPEN SOURCE SOFTWARE information refer to the on-screen display on your product. If you ...
[PDF]English - Insignia
www.insigniaproducts.com/.../manuals/NS-55E560A11_11-0573_MAN...
manual, or otherwise listed by an independent laboratory as suitable for your TV. •. Follow all instructions .... NS-55E560A11 Insignia 55" LED-LCD TV, 1080p.
Oct 07, 2015 | Insignia Televison & Video
I have a Insignia 32 inch LCD TV Model number NS-LCD32. It recently started displaying no inputs. The backlight comes on but no inputs/ no sound. Green lines display if you press the menu,input, channel...
The first troubleshooting step would be to measure all the voltages from the power supply to the other circuits boards specially the 5 volts going to the main board. If you have the following: Insignia 6HA0112010 Power Supply, check FU502 for open conditions.
If all the voltages appear normal, then the main board should be replace since is hard to find individual components for a component level repair.
Let me know if you need further assistance.
Aug 21, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Insignia NS LCD 37
Sounds like the power supply board have problem, but if you provide the model; and version. And more detail, may get better helping.
Knowledge obtain from: Repair experience on same symptom.
May 02, 2010 | Televison & Video
Damaged Insignia NS-L32Q-10A Screen
The damage actually occurred on the LCD (liquid crystal display) itself, not on the screen. Therefore, when the tv is switched off, no damage is visible. What happens is that when it is turned on, the liquid crystals "leak" because the display is broken. This is why you can see lines and a small dent. Depending on the tv, replacement LCD panels may be sold separately, though chances are that it would cost less to simply buy a new tv. Thanks for your post, and I wish you the best of luck! Sincerely, Der Strom
Apr 26, 2010 | Insignia IS-LCDTV32 32 in. Television
Insignia 32" NS 32 q09
Since you don't mention how you're receiving the signal, I'm assuming you use a cable box or computer. Adjust the output settings (e.g. 720p, 1080p) on the box and then adjust your TV settings. If it's a computer, you'll need to adjust the video card settings to a compatible aspect ratio (e.g. 1366x768) for the desktop to display properly on the TV. Details can be found in the owner's manual.
Jan 04, 2010 | Insignia 37" LCD Flat-Panel HDTV
Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
May 14, 2009 | Insignia IS-LCDTV32 32 in. Television
Red tint on my TV, instead of all colors? Reset doesnt work?
Sounds like the component cables are misplaced. Check that, and report back.
Dec 30, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia NS-LCD22-09 LCD HDTV Logo
264 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
