Question about Maytag Washing Machines
Maytag 5000 series washer displaying an F35 code, what does that mean?
marka19
  • 1430 Answers
SOURCE: whirlpool duet washer troubleshooting: What does
This indicates that the pressure switch or also called the analog pressure sensor has failed. First you will need to remove the top lid. Usually 2 or 3 screws on the back and the top comes right off. The pressure switch has a clear hose and a clump of wires going to it. Then unplug the hose and blow thru it it should be clear. Check the hose for leaks or obstructions. Also in the back of the washer on the left hand side is a air dome this is where it gets it pressure reading from, make sure it is not obstructed. If all is clear the pressure switch will need to be replaced. Here is a link to help with accessing the pressure switch also if you need diagrams or illustrations of your particular model.
Posted on Sep 20, 2010
rylee_smith
  • 8619 Answers
SOURCE: Getting an F35 failure code
Hi
Thanks for using FixYa. Error F 35 means Analog Pressure Sensor Failure- which means that there is a malfunction of the component detected by the Steamer Electronic Board.
1. Check that the pressure hose is fixed correctly.
2. Check that the air trap is not blocked.
3. Check that the hose is not blocked
If still the issue is not resolved then it is an issue with the water level pressure switch operation and there is a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch. Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
SOURCE: My Maytag 5000 front leader
We had the same exact problem. Service tech came out and diagnosed bad pressure switch, Part # W1015652. Swapped it for a $135 new one and it seems to work just fine now.
This would have been an easy fix for me to make had I known what to look for. Unplug and shut water, remove top cover, follow small diameter (1/4"?) black tube up from wash drum to where it plugs into the plastic pressure switch housing. Remove switch from its bracket, unplug wire harness and black tube, and replace.
Service tech said that this is due to using too much detergent, suds will creep up into the pressure tube from the wash drum and get into the small circuit board inside the pressure switch housing. He also recommended against using Kirkland Signature brand detergent even though it has the HE emblem on it. Best to use one of the major brands and only 1 to 1.5 tablespoons at most.
A google search for "Maytag 5000" reveals that this is a major problem because it is the 5th search result. "Maytag 5000 problems" search shows that this is the #1 problem with these washers.
Posted on Jan 03, 2011
soundman4305
  • 40 Answers
SOURCE: what does code f35 mean
I found this for you:
"F35" Analog Pressure Sensor Failure
If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  • Press the Pause / Cancel / Stop button twice to clear the display.
  • Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
Posted on Mar 07, 2011
ZJLimited
  • 17970 Answers
SOURCE: What means Error code F35 on Kenmore Elite washer
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
I suggest check:
- Check if pressure hose is fi xed correctly.
- Check if the airtrap is not blocked.
- Check if the hose is not blocked.
The analog pressure sensor can be accessed by pulling off the top panel of your washer. Remove the screws at the very back of the top panel and then pull it back slightly and then up and off of the washer. The analog pressure sensor is Key 38 in the first image below... image56387img-or.jpg
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Posted on Nov 14, 2011
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
F35 on maytag 5000 series front loader.
A F35 error indicates the Central Control Unit has detected a malfunction of the analog pressure sensor.
Oct 11, 2014 | Maytag Washing Machines
Error Code F24 Maytag 4000 Series Front Load Washer
This video will show you how to open your Maytag 4000 series washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2013 | Washing Machines
Maytag 5000 series front load washer wont spin, F11 code
I got my Maytag 5000 in 2009. After about a year started having problems. Of course, I was told warranty wouldn't cover the problem. I googled several things, fixed some issues myself. But this washer has been a piece of junk after a year of use. Front loaders are far from cheap. It will be a long time, if ever, that I buy another Maytag appliance.
Mar 01, 2012 | Washing Machines
I have a Maytag front load Washer Model MHWE500VW10 (5000 Series) . The dreaded F35 / SUD error code keeps coming up. I have checked the tubing and electrical connections to the Water Level Pressure...
Hi
There is only one Analog Pressure Sensor Switch Part no. W10156252, another one that it has is the water level switch (part no W10415587). I believe you are talking about the first one as that is what error code F35 means (ANALOG PRESSURE SENSOR FAILURE). Hope this helps...please post back for further assistance.
Daniel
Sep 17, 2011 | Maytag MAH21PDD Commercial Front-Load...
May tag 5000. f35 what does that mean
"F35" means Analog Pressure Sensor Failure
Hope this helps.
Jul 09, 2011 | Maytag Washing Machines
I get a "SUD" and
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Washing Machines
What does code f35 mean on my maytag 5000 series washing machine?
Mar 07, 2011 | Maytag MAH8700A Front Load Washer
Getting an F35 failure code on my series 5000 washer
Hi
Thanks
Rylee
Aug 22, 2010 | Maytag Washing Machines
What does F35 mean on a maytrag washer 5000?
F35
If this failure is displayed, the Central Control Unit has detected
Possible Causes/Procedure
Check if pressure hose is fixed correctly and without holes
or damage.
Damaged or faulty sensor.
Aug 18, 2010 | Maytag Washing Machines
Washing Machines Logo
586 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
