Panasonic TV - want to remove on screen message
Panasonic LCD tv - an on screen message has appeared in top left of screen and is there permanently - can't get rid of it. It wasn't there before! Please does anyone know how we can take it off? It's the EC1/RGB message (or AV2 if you change to different AV).
Any help greatly appreciated!!!!
    Genius:
  • 1,224 Answers
Its an input message i dont have your remote in front of me but im going to say when you hit the input av1 av2 there should be a button on remote for display or info one of these buttons should deactivate that message
Posted on May 13, 2008
I have the same with a Panasonic plasma set - if the input select doesn't work (my didn't), then you have to go into the main menu and pick shipping condition - this resets everything
Posted on Jun 22, 2008
How to fix vertical lines on a panasonic viera 3D lcd 55" tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 01, 2016 | Panasonic 55" L55ET5 Viera 3D Full HD...
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 05, 2017 | Panasonic Televison & Video
Model number TCP50U50 panasonic has sound but no picture
...If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 25, 2014 | Panasonic TCP50U50 50" Plasma 1080p HDTV
LG - 32LD350 - 32" LCD TV - 720p is the type of tv
Hello
It has been permanantly damaged, and is not repairable. To get it work perfectly, you have to replace the screen. OK.
Aug 03, 2011 | LG 32LD350 32 in. LCD TV
The number of the selected programme does is permanently displayed at the left top corner of the screen. I tried to plug out the TV but the problem persists.
Tries used ur tv remote and go into the tv MENU and tries go down to do a resetting to the tv back to the factory setting to every funsctions,to every funsctions setting of the tv menu of setup setting menus like PICTURE,SETUP,OPTION.By resetting all these menus setting back to the factory settings,tv should have a great chances to get ritting of the permanently dispalyed on the left top corner.
Apr 08, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
The words "Digital Noise Filter
The words "Digital Noise Filter Off" and "digital Noise Filter On" appear on the top left and right and side of the screen and the words " Auto Visulisation" appear on the bottom of the screen all the time when watching normal T.V.(series 5 lcd) and if we make changes regarding in setting in picture option in mode.then after 20-30 min againg it displays same message
Feb 01, 2011 | Samsung LE40R74BDX 40 in. LCD Television
My grandaughter wrote with a permanent marking
If it is the old picture tube TV use paper towel and alcohol. If it is LCD, go get a screen cleaning kit at electronic store and wipe it very gently. :) Happy new year!
Dec 29, 2009 | Panasonic Televison & Video
A block box appears in the top left corner of my Sony TV
Check your Menu for Closed Captioning, Make sure this is turned to off in Audio Menu
Dec 15, 2009 | Sony Televison & Video
HORIZZONTAL LINES ON FUNAI LCD TV
HI,THERE ARE BAD CONTACS ON THE SCREEN DRIVER RIBBON WIRES,ITS A JOB TO GET TO THEM,AS YOU ALMOST HAVE TO REMOVE THE WHOLE SCREEN PANEL,TO SEE THEM,A JOB FOR A TV TEC IF YOU ARE NOT SURE!! THANKS
Jan 02, 2009 | Dell W2606C 26 in. HD-Ready LCD Television
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
1,097 people viewed this question
Top Televison & Video Experts
Electro Med Services...
