Question about Canon PIXMA iP1800 Printer
Transperancy problem Thank you . Had opened the side door, and followed instructions. Is there another access point?
    Problem Solver:
  • 12 Answers
Ya duh>????
Posted on Aug 03, 2008
    Genius:
  • 2,785 Answers
Then you have to open the whole printer
Posted on May 13, 2008
I have an open door message on my hp 350 copier printer
Open the door, ensure there is no debris of any kind arount it and then shut it firmly. This may resolve the issue
Jun 10, 2015 | HP Deskjet 350 InkJet Printer
I have a maytag mer6751aab, the bottom door will not open unless I lift up on it. Is their a way to fix it easy?
The hinge maybe out of place. You have to remove the side panel to gain full access to it. Follow instruction in the owners manual to remove to door to check it out.
Mar 14, 2015 | Maytag Refrigerators
How to remove casing
To make sure there is a clear understanding here's a complete diagram
Overall Parts Diagram
To Remove the Outside Plastics on the HP Color LaserJet CP5220 Series Printer
1) Remove Right-front cover and control-panel assembly
a) Open the front door and the right door.
b) Remove two screws (callout 1).
c) Release 3 tabs (callout 1) on the right side of the assembly.
d) While holding the assembly up, pull the cable holder (callout1)
disconnect one connector (callout 2).
2) Remove Left cover
a) Remove Tray 2 from the product.
b) Open the front door.
c) Remove three screws (callout 1). Starting from the left side
tabs (callout 2),and then remove the cover from the product.
TIP: Opening the toner-collection door might make it easier to release the tabs on the left side of the cover.
Reinstallation TIP: If the front door will not close after the left cover has been reinstalled, verify that the two tabs on the right side of the cover have been aligned correctly with the product chassis.
3) Remove Rear cover
a) Remove six screws (callout 1), and then remove the cover
from the product.
4) Remove Toner collection unit access door
a) Open the toner collection unit access door (callout 1), remove the toner collection unit, and then release the link arm (callout 2) on the left side of the door. 18798043-wfiifre4chsxw5xgazxianfb-1-48.jpg
b) Partially close the door, and then disconnect the right-hand link arm (callout 1) from the door.
CAUTION: Do not disconnect the right-hand link arm when the door is completely open. Doing so can disconnect the link arm spring. 18798043-wfiifre4chsxw5xgazxianfb-1-63.jpg
c) Rotate the access door down 90 degrees, and then pull on the left side of the door to remove the access door.
5) Remove Right-rear cover
a) Remove the rear cover. See Rear cover on page 93.
b) Open the right-door assembly.
c) Remove two screws (callout 1), release one tab (callout 2),
and then remove the cover.
CAUTION: The grounding spring on the back of the cover falls off easily. Be careful not to lose it.
6) Remove Top cover
a) Remove four screws (callout 1).
b) Open the toner-collection door.
c) Release two tabs (callout 1), and then remove the cover.
7) To Reassemble Follow Instructions in Reverse
Jul 08, 2013 | HEWLETT-PACKARD Color LaserJet CP5225...
Picture is ugly we want to clean transperant sheet how can i open the transperant sheet?
I'm assuming you are asking about the Intermediate Transfer Belt. I remove the belt cleaning assy first just to get it out of may way. Open front door and remove the waste toner bottle. You will see a screw just up above and slightly to the left. Remove the screw and gently pull on the handle. It should come out easily. This is what is supposed to clean the belt assembly. Are you sure this isn't bad and is why you think you need to clean the belt? Set it aside for now. Open the right side access door and you should see the black belt. Remove the panel just above this by removing the one screw towards the front of the copier. Once removed you should a a blue handle. Lift up on this gently and it will lock in place. Then you should see the handles, front side one and rear side one, of the transfer belt assembly. Gently pull them straight out and the assembly should come out fairly easily. Be careful what you clean it with. Just use a clean, soft and dry cloth. Hope this helps.
Mar 26, 2011 | Canon imageRUNNER C3200 Copier
Its not printing says problem of opencover
hi
go to this link (see below) .. it will list the issue near bottom of page.. follow instructions (read carefully and entirely )
The top access door on the printer might be open, or there might be something wrong with the print cartridge.
Solution
  1. Check to make sure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door opens, the print carriage moves so the yellow arrow on top of the print carriage points to a drawing of a cartridge. Each drawing describes a symptom. Find the drawing in the following table, and then review the solution as necessary.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=ca&taskId=110&prodSeriesId=304441&prodTypeId=18972&prodSeriesId=304441&objectID=c00035263
if this deosnt solve problem, let me know , i will continue research
-- i need excat error that it indciates
--BUT please do not rate with less than 4 star.
Nov 22, 2010 | HP DeskJet 5652 InkJet Printer
Springs on detergent compartment have come off...how can they be put back on again?
It's fairly easy but you need to remove the front panel of the door first. To do this you will need a T20 T-Star screwdriver or screwdriver bit then follow these instructions:
1. Open the door and fold it down flat - there are 10 screws (T20) around the edges of the door
2. Undo and remove the 3 screws on each side - leave the 4 screws at the top!
3. Close the door
4. Grab the door at the bottom on both sides and pull gently towards you about 2-3 inches.
At this point you may find that 2 plastic clips fall out. Don't panic - it's not broken. They slide back on when the panel is removed.
5. When the bottom of the door is pulled away, pull it downwards and it will slide out from behind the control panel. The outer panel of the door should now be completely free.
You will now be able to see the back of the detergent compartment where the springs are located. Re-attach the springs, then re-fit the door following the instructions above in reverse order. If one or both of the clear plastic door clips have come off, reattach them to the brackets at the bottom of the door before re-fitting the panel. It's much easier this way!
T-Star bits are freely available - I've attached a picture of one.
If you get into any difficulty removing or refitting the door, please post back and I will assist you further.
Oct 21, 2010 | Bosch 24 in. SGS43C02 Classixx Built-in...
Print cartridge carriage is stalled
There are a few steps to follow to check the Printer.
Step one: Turn the All-in-One off and on again
  1. Press the On button to turn the product off.
  2. Press the On button again to turn the product on.
If the error message is not resolved, continue to the next step. Step two: Clear any paper jam Follow these instructions to clear a paper jam. CAUTION: All paper jams must be removed from the back of the product through the rear access door. Pulling the paper from the front of the product rotates the paper feed roller in the wrong direction and can damage the product.
  1. Turn off the product and unplug the power cord.
  2. Turn the product around to access the back of the product.
  3. Open the rear access door:
    1. Locate the tab on the left side of the door and press it toward the right. The door will shift slightly to the right.
    2. As the door shifts to the right, pull the door out slightly to release.
    3. When the door is released, gently remove the door by sliding the door out and to the left.
    1. From the rear access opening, gently pull the jammed paper out of the rollers.
    NOTE: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the product. If all the pieces of paper are not removed from the product, more paper jams are likely to occur.
    1. Replace the rear access door:
    2. Insert the two posts on the right of the door into the holes on the right side of the opening.
    3. Press the tab on the left side of the door toward the right. The door will shift slightly to the right.
    4. As the door shifts to the right, push in the left side of the door to lock it into position.
    5. Reconnect the power cord and turn the product on.
    Step three: Make sure that the print carriage can move freely Follow these instructions to make sure the print carriage can move freely.
    1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
    2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
    3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
    4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
    5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
    6. Press the On button to turn on the product.
    If the error message is not resolved, continue to the next step. Step four: Remove the print cartridges Improper placement or installation of the print cartridges can cause a carriage stall error condition. Follow these instructions to remove the print cartridges.
    1. Make sure the printer is turned on.
    2. Open the print cartridge access door, and then wait until the print carriage is idle and silent.
    Press down lightly on the end of each print cartridge to release it.
    • The tri-color print cartridge is on the left.
    • The black or photo print cartridge is on the right.
    Slide both cartridges out and place them on a clean sheet of paper. CAUTION: Do not touch the ink nozzles or copper-colored contacts. Touching these parts could result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
    1. Disconnect the power cord.
    2. Move the carriage all the way to the left with your hand.
    3. Close the print cartridge access door.
    4. Reconnect the power cord.
    5. Turn the product on, if necessary.
    6. If the error message is resolved, the placement of the print cartridges caused the problem. Complete Step five: Reinstall the print cartridges. There is no need to complete any steps after Step five.
    If the error message is not resolved, complete Step five: Reinstall the print cartridges, and then continue with the subsequent steps. Step five: Reinstall the print cartridges step 6, Partial reset Follow these instructions to perform a partial reset of the product.
    1. Turn the product off by pressing the On button.
    2. Unplug the power cord from the back of the product.
    3. Plug the power cord back into the product.
    4. Turn the product on by pressing the On button
    1. Load letter, A4, or legal unused plain white paper into the paper tray.
    2. Press the Setup button until Print Report appears, and then press the OK button. Self-Test Report appears on the control panel display.
    3. Press the OK button. The product prints a self-test report.
    Hopefully fixing the problem for you
    Regards
    Richard.
    Apr 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
    Drivers side door handle won't work
    Some linkage maybe broken on the door handle. Door panel removal instructions are availablel on line www.carstereohelp.com/strford.htm but determining the problem will have to be found on your own.
    Nov 12, 2008 | 2000 Ford Focus
    Carriage jam error
    Here is the document that i want you to follow exactly in order to resolve your issue.
    CLICK HERE TO VIEW THE DOCUMENT.==>> DOCUMENT
    Please let me know the result after following the document.
    Thank you so much. I remain.
    adonscott
    Jul 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
    Canon image runner irc 3100 transperancy paper jam
    if you can open the printer you can access the rest of the paper other wise look in back for any part which can be opened and remove the paper jam
    May 13, 2008 | Canon PIXMA iP1800 Printer
    Canon PIXMA  iP1800 Printer Logo
    22 people viewed this question
    old marine
    old marine
