Question about SanDisk Sansa MP3 Player
Died unit just bought and died
    Genius:
  • 1,224 Answers
Did you charge it and if you did you do by instructions on how to charge with usb cable
electronic devices freshly bought need a battery charge before anything can be put into it or used this is a manufacture feature to keep batterys from exploding in trucks when being hauld to there destinations some trucks arent air conditioned heat expands the batterys so remember to charge battery before use
Posted on May 13, 2008
    Genius:
  • 2,785 Answers
Send it back to the vendor from whom you have purchased
My husband bought a Straight Talk Lucky as a temp. it started acting up. Battery will die in a few minutes. In files it says cloud cache is @ 4.00B why? It's eating data & pics are gone. Pease help!
just bought --- take it back for an exchange new unit under warranty if old unit , take it to a phone shop and get a quote for repair
Feb 25, 2016 | Cell Phones
I own a jvc RC-XC1 boombox which i bought just under 19years ago and lasted just over 18years when the power supply on the unit failed.unit only stays on for3 seconds then dies. Where can i either get...
Getting components is not hard, but you'll need to know what components you'll need, so unless you are a electronics service tech or dabble in electronics, getting the correct parts would be a major challenge. First you would need to test the circuitry and locate the faulty components. Then you would order the parts. The other alternative is to find a local repair electronics repair shop (they are around), and have them look at the boom box.
May 31, 2014 | Audio Players & Recorders
Unformatted disk error message
Make sure your storage settings have not been altered. A dying battery on the units man board can cause this.
May 18, 2014 | Yamaha Disklavier Control Unit Dkc500r
Problem with frothing unit. I bought my Die-Cast
It probably has a line clogged. It could be from backed up milk, but also could be the water you're using. Those things are finicky about have filtered water, especially because when the water heats up it can deposit calcium etc. onto the inner water lines. Only use store bought filtered water.
Oct 28, 2013 | Breville BES830XL Die-Cast Programmable...
Yamaha RX-A1010 died when connecting new cable
check the hdmi jack that you plugged into and make sure that none of the pins got bent. If the wrong pins touch each other or the chassis it could short out something and cause it to shut down.
Jun 24, 2013 | Yamaha RX-A1010 Aventage Audio video AV...
My Edge 705 unit will not recognize the DSC 10 cadence sensor. Had one, thought the battery had died, changed that, this didn't work so I guessed the unit died and bought another one...same problem. Help!
When changing battery, accessories need to be paired again.
For pairing please follow instructions in manual or go to site http://www8.garmin.com/manuals/2297_OwnersManual.pdf
Aug 15, 2010 | Garmin Edge 705 Handheld GPS Receiver
I bought a used mp3 player put the battery died
There's a slide switch on the top of the unit, near the headphone jack. Slide it away from the jack to unlock the unit. Slide it toward the jack to lock the unit so that accidental bumping of the controls won't do anything.
Jul 07, 2010 | SanDisk Sansa e200 MP3 Player
Husqvarna yth180
check the seat switch
Jun 09, 2009 | Husqvarna Garden
92 318I BWM , Starts for a second then dies
check to see if there is a vacum leak, usally pcv valve unit leaks at back of the maifold
Sep 16, 2008 | 1997 BMW 318
Brand new unit ...battery (or unit) died.
it sounds like the battery.but if new batterys dont work.then its the unit and you need to take it back.
May 13, 2008 | SanDisk Sansa MP3 Player
SanDisk Sansa MP3 Player Logo
60 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
