Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
What causes ice to build up at the bottom of the freezer in my side-by-side refrigerator?
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 06, 2010
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
Whirlpool gold refrigerator is not cooling ice build up in freezer. Water on bottom of refrigerator.
Too much build of ice in freezer will not cooled the refrigerator side, you need to defrost the fridge. Set it to proper temp setting, just enough to have ice on the freezer and also remove water on the bottom.
Thanks for asking.
Jun 24, 2011 | Whirlpool Refrigerators
Ice maker quit working and is causing ice build up on the back of the freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Ice on freezer floor
have you checked the canister on the back is attached and not faulty?
Mar 20, 2009 | Refrigerators
What causes ice build up on the bottom of a freezer?
your drain is probably plugged so when the fridge goes on defrost the water has nowhere to go.After the defrost cycle when the frige starts to freeze again the water freezes up causing ice build up
Dec 18, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Ice build up
HELLO AND THANK YOU FOR YOUR QUESTION.WITH REGARDS TO THE ICE BUILD UP IN THE BOTTOM OF THE FREEZER THAT COULD BE CAUSED BY ONE OF THREE THINGS.YOU NEED TO CHECK THAT YOUR HEATER ELEMENT IS WORKING OK AS THIS WILL CAUSE THE ICE NOT TO DEFROST FAST ENOUGH BEFOR THE FRIDGE COMES BACK ON.SECONDLY THE FAN NEEDS TO BE CHECKED IF ITS WORKING OK THAT CAN ALSO CAUSE IT.LASTLY YOU DEFROST CLIQSANS NEED TO BE CHECKED TO SEE IF THEY ARE SENSING THE TEMP CORRECTLY.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool GD2SHGX Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
