Can you let me know what size mcb is required for this unit
  • Robert Horton
    Robert Horton Sep 06, 2010
    Hi tell me what MCB stands for and I can tell you. Thanks,
    Shastalaker7
    President:
  • 1,515 Answers
Hi, if you mean main circuit breaker, look on the condenser unit outside and it will tell you on the data plate what the rated amperage is for the unit, minimum and maximum. This will tell you this size you should go with, very easy. It will tell you not to exceed so many amps for instance 35 amps maximum. Go with a double pole 30 to 35 amp breaker and at the disconnect box, the same with cartridge fuses if it has them. Please do not forget to rate me on this as I know you will be king. Please keep me posted and I will check in on you as I keep records on you and all of the people I have helped
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Posted on Sep 06, 2010
Rangemaster Ceramic 110 randomly trips the MCB.
Electric rangemaster tripping electric - what size mcb? ' DIYnot ...
www.diynot.com > Forums > How to... > Electrics UK
Apr 6, 2013 - Cooker occasionally trips the 'Wylex B32 MCB' when almost everything is going. ... http://www.ebay.co.uk/itm/Rangemaster-Leisure-110-Electric-Cooker-/ ... Find the total load via the site below, a ceramic nit is 14kw shock:
Oven or cooker tripping electric, what to do next? - YouTube
? 3:11
https://www.youtube.com/watch?v=O42p_tWYgAU
Dec 21, 2011 - Uploaded by Richard Saupe
Hi Richard, i recently bought a all electric rangemaster cooker second ... I'm asking because our oven trips the breaker when we try to turn it on, ...
Frequently Asked Questions ' Rangemaster
www.rangemaster.co.uk/rangemaster-owners/faqs
For earlier specification110cm models, remove the storage drawer and the silver ...Ceramic and Induction models may be connected to a suitable 6mm cable ...
http://www.diydoctor.org.uk/forums/electrics-forum.html 2015-12 ...
www.diydoctor.org.uk/forums/electrics-forum-f182.xml
Jan 19, 2016 | Rangemaster Range Cookers Kitchener 110...
When I put the plug in the wall it keeps tripping the fuse what can I do
hi ya
if its tripping the MCB on the consumer unit there could be several reasons,
The fuse in the plug is too low / high in the plug, as the Air con, requires more power on start up,
it is also worth checking the plug is wired correctly E N Live etc..
or the MBC is too low, normally sockets are 16 amp - if its lower check with a qualified electrician it will be noted on the MCB denoted sockets
if the air con is portable, or able to be plugged in else where try upstairs sockets or kitchen sockets as these should be on a different circuit - if it does trip on these the air con is faulty and dump or see if a qualified repair agent is local
but always consult someone who is qualified - simply doing the above should be fine,
Apr 13, 2015 | Heating & Cooling
Total electrical output
Bad news really, the supply cable you have there is not going to be capable of supply to any type of electric oven and hob like you listed above. Your supply cable is possibly only 2.5mm in size, and not the required 6mm with a much higher MCB at the fuseboard. Get a registered electrician to run a new cable from the board to your cooking area. A single oven takes about 3.2Kw adding the hob rings will take way over your limit. Curry's listing of that cooker as a load of .75Kw or thereabouts is obviously incorrect.
Jan 15, 2014 | Ovens
Maxon wire fuses
If a inline fuse in a holder the old one will aside from length have the amperage printed on it---very few mobile radios use larger than a 3 amp fuse-----look on metal ends of old fuse if have it for markings like 3ag 3 250---3AG is size, 3 is 3 amp, 250 is max working voltage (120 is fine).
Oct 24, 2012 | Maxon MCB-30 40-Channels Base CB Radio
Hob is tripping fuse box
If the hob is tripping the RCB or MCB on the consumer unit, there is a fault, usually in the elements or halogon heaters, you will need a multimeter to define but please ISOLATE FROM MAINS POWER BEFORE OPENING ANY PANEL
Some electrical knowledge would be helpful, check each element seperatly, you may have to carefuly disconect each heater on the hob, unless you know which blows the mcb, check all connectings to see thay are secure, work round the hab reostates, make sure there is no shorts to ground from elements, with temp control down at zero. Check wiring into mains as a loose connection will cause heat and mcb to trip.
If it is wired into the same outlet as an oven disconnect oven in case the other appliance is causing the problem. it is realy a question of eliminating causes one at a time, working round the affending appliance to define what is the cause.
Hope this is helpful
John
Jun 06, 2011 | Ovens
There is no pedal resistance is battery needed to be changed? where is the battery located or what is the problem w/ the equipment???
hi
if console is on it is not battery problem
it is alternator or MCB board
it is usual for these units MCB fails
Nov 25, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
Split ac runs for 2 hrs and MCB TRIPS
The most common reason is that the electrical power is not supply to the air conditioners. If the air conditioner operate for period of time then only it trips. Then , it could be possible that the MCB is under-sized. Please check the recommended MCB size.
Rate it.
Mar 02, 2010 | Heating & Cooling
Wash cycle will not complete
Hi, this code(LR), represents a malfunction that is located in the Motor Control board. this board is responsible for the proper function and speed of the motor. the unit will not operate properly with a bad MCB
You will need to replace the damaged MCB asap if possible.
This MCB replacment will cost $215.00(part cost)
Jun 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Earphone/mic for Maxon 27MCB radio
I recall the combo unit as I used to sell them. I am about sure they are no longer avaidable. You never know, you might see something on ebay/auction sights that might be to your liking. Good Luck.
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
