Question about Yamaha DSP-A1 Receiver
Yamaha dsp-a1 I have connected my dvd and sky tv into the amplifier using scart leads and a s-video from the amplifier to a plasma monitor the picture is black and white.If i connect the dvd straight into the monitor using s-video the picture is colour. Also if i connect everything back into the amplifier and connect to a tv using s-video the picture is colour. how do i get colour on the monitor through the amplifier regards Dave
    Genius:
  • 1,224 Answers
You need to set the ntsf or pal settings for hdtv and s-video is video1 video 2 or video 3 seting on input on remote
Posted on May 13, 2008
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Can you show me how to connect up the scart and aerials up to the following so they operate correctly Samsung PS42C450 42-inch 600Hz Widescreen HD Ready Plasma TV with Freeview SAMSUNG DVD-SH893M 160GB...
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
Mar 19, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
I want to connect a sky+ hd box to my jvc gm-v42e can you tell me what leads I require to get 1080 resolution. The sky box has a hdmi connection but the tv doesn't.
Hi, I've just been given one of these. I'm not a 'Techy' but I am having the same problems as you so I'll share what I've found out so far.
The JVC GM-V42E is actually a plasma monitor, not a TV, as it doesn't have a built in TV tuner.
The picture quality is very good, as at the time it was produced, it was a top of the range plasma monitor for professional use, and was discontinued in about 2006. However, it is not HD/HD Ready, so you won't be able to use an HDMI cable or view programmes in HD. There is also no scart, so you can't connect it to the Sky box this way either.
I spoke to JVC Professional's technical department and they suggested using a scart to 3 BNC connector. The scart plugs into the Sky box and the 3 BNC connection plugs into the monitor. The monitor itself has loads of connections, the ones you want are labelled 'Component RGB/B'. The three pins you are after in this section are labelled 'Video' and each are called 'Y/G', 'Pb/B' and 'Pr/R'. This will connect the visual aspect, and you will also need a twin phono lead (red & white) to plug into your Sky box and into the monitor to connect the audio / sound.
I went to Maplin's and they don't sell these so I am trying a scart splitter that connects to the screen with a 3 phono lead (the red, yellow and white connectors). At the moment I am trying plugging these into the section marked 'Video B'. The 3 phono lead then connects to the splitter, where scarts from the Sky Box and DVD can be connected. I don't know if this will work yet - but I'll keep you posted and update this thread once I have managed to get it up and working...
Hope that helps... :-)
I have yet to try either solution, but will get back to you once I have tried them and tell you which one works.
Jun 19, 2010 | Televison & Video
I have a Toshiba DVR19DTKB DVD & VHS Recorder with Freeview , A SKY + Box, A Panasonic NV-SD240BL Video cassette recorder, A Samsung PS42B450B1W 42'' Plasma TV, and would like see a diagram of how all...
connect the aerial to the dvd/vcr/freeview combo, connect a scart from that to the tv, from the scart out socket.
you can then connect the sky from the scart marked tv to either the tv direct or to the combo if it has a second scart.
Note. a scart socket with an arrow going into a box is an input, coming out of the boe is an output and a double arrow is a two way scart.
if you use scart 2 on the tv to connect the combo, the combo will recieve a signal from the tv for recording.
Jan 21, 2010 | Televison & Video
Jvc plasma monitor gmv42e can not get a picture just sond no scart so what do i do
I have just been given one of these, it not a TV, it is a monitor, and so does not have a TV tuner or a scart (it was made for professional use).
You need to plug it in to a DVD player/Freeview/Sky box using alternative means to a scart lead. You can do this by using a scart to 3 BNC lead and plugging this in where it says 'Component/RGB B'. This carries the picture, but not the sound. To get the sound you will need to plug a twin phono lead into the red and white audio plugs.
Alternatively, you can use the 'Video in' yellow socket to connect to connect to a DVD etc. The guy did this in Maplin's and it seemed to work.
JVC professional were really helpful on the phone, ask for their technical department, they can also email you the manual.
Sep 06, 2009 | JVC GM-V42 42 in. Plasma Television
Connecting sky box to to non scart reysis tv,via scart plug cable
This lead is usually coloured yellow and looks like the red and white leads you use to connect the tv speaker OUT sockets to an amplifier or external speakers. The input on the tv should be coded yellow also.
Jul 18, 2009 | Relisys RLT-1500 15" LCD Monitor
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Yamaha DSP-A1 Receiver Logo
188 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
