Question about Palm Treo 750 Smartphone
PDA Try as I might I cannot get my connect my PDA to the net, have tried new sim, dial up isp. Really fed up..can anyone help. Maybe a pay as go network that supports pda's?
Unlock code for palm tero 750 with AT&T,
jlubana@yahoo.com
Posted on May 18, 2008
I successfully unlocked my Samsung Impression SGH-A877. I put in the new sim card for my new carrier (in Japan) but when I dial a number I get the "emergency calls only" message. Does anyone know...
This can indicate that your SIM isn't registered correctly, go to settings menu and network option, look for search network or add network option, if your carrier is found try to register (this is a manual network selection), if your carrier is not found, maybe your phone can't work at your Japan carrier bands (maybe is 1200 or 1700 MHz) and your phone only supports most commonly used GSM quad -bands ( 850/900/1800/1900 MHz ), please ask your carrier if supports the mentioned bands.
Mar 03, 2011 | Samsung SGH-A877 Impression Cell Phone
My samsung d900i says no service, when i try to phone or text it says no network, anyone that phones me gets diverted to answerphone, can anyone help?
Your sim card is probably expired or maybe you have bad connection in your home.
Thats just my conclusion...
Never really happened to me.
I hope I helped!
Aug 05, 2009 | Cell Phones
PPC 6700-I'm So Lost! What Is My ISP, How Do I Get Online, Etc?
Hi. First of all, yes it is a whole new world for you, so I really don't know where to start. I think the best thing to do is giving you some advice, than maybe if you have another question mark in your mind about a particular subject, you can open a new topic in this community. To begin with, your device is a HTC Apache coded device, where you can see the detailed specs here: (http://www.pdadb.net/index.php?m=specs&id=332). After that, here is the link for the forum special for your device, where you can find updates&solutions: (http://forum.xda-developers.com/forumdisplay.php?f=252). Also, you can start learning the basics of using the Windows Mobile Operating System here: (http://www.microsoft.com/windowsmobile/en-us/help/default.mspx). And finally, when you move across a little bit, you can start to have a look at some of these great freeware applications for PDA's here: (http://www.1800pocketpc.com/), which, I think, is the greatest advantage of a windows mobile based PDA. Also, ISP stands for "Internet Service Provider", which in your case is same with your mobile carrier (because you'll connect to internet using your sim card). You can easily contact your mobile carrier (like Vodaphone) and learn their specific configuration for the data connection on your mobile. Hope this helps. By the way, your device also has a built-in wireless, so you can connect to any wifi network around and use the internet through it.
Apr 28, 2009 | Audiovox PPC 6700
My wifes laptop is trying to use DUN instead of network cable
Open up Internet Options (from the Tools menu in IE or right-clicking the desktop icon and selecting Properties, or through the Control Panel). On the Connections tab, select 'Never dial a connection.' When you want to connect to your ISP you will be required to manually start the dial-up connection.
Apr 14, 2009 | Computers & Internet
I can not connect my ASUS P320 MTNL GPRS What are SETTINGS for this on my ASUS P320?
I had the same problem in tamil nadu BSNL, all you have to do is put your sim card in another mobile Like Nokia or Motorola, since they are listed with the operators and subscibe for GPRS, once your connection is through, remove the sim and put it back to your ASus PDA, it works fine.
Give it a try
L.S.Sidduram
Mettupalayam, Tamilnadu
sidduram@gmail.com
Mar 02, 2009 | ASUS Computers & Internet
The phone is not picking network signals
just try this
when ur pda is switched off press Call and end key together and then press power button for like 5 sec a screen will appear asking u to format the pda pls confirm the action by pressing center button of the 4 way keys and then ur pda will be factory reset to the default OS , if it helps ur problem then tell me
other wise go and upgrade ur ROM from www.htc.com it will help u for sure basically it is a software issue
have u tried other sims in in it like warid or telenor or jazz try them and tell me i can help u
pls rate me fixya for help i have provided
Mar 01, 2009 | HTC Touch P3450 Smartphone
How to unlock samsung x830 to use any sim ????????
you mght have to ring the phone company and pay a little extra, thsi is the main way and have never heard any other way of doing it, unless theres a new trick, if there is let me know. thankx
Oct 25, 2008 | Samsung SGH-X830 Cellular Phone
I HAVE HIGHSPEED INTERNET AND IM STILL HAVING BAD CONNECTION WITH OTHER PLAYERS
HAI , SELECT START THEN CONTROL PANNEL GO TO NETWORK CONNECTIONS .DELETE THE CURRENT SETTING AND CREATE NEW ONE ,RESTART THEN TRY TO CONNECT THE INTERNET
Jun 26, 2008 | Computers & Internet
My modem is not installed on my windows xp computer. I can't get on the internet. I have dial-up
thing you need to be able to get on the net:
  • you will need the driver for your modem installed,and it has to be compatible with winxp,if you do not have it search the net on a friends pc, then install it
  • an internet service provider (ISP).who you pay money too for the service.
  • a user name and password from your ISP who will normally give you an email address.
  • a dial up connection set up with the phone number and other settings, to dial your ISP ,they will check your "user name and password " before allowing you on to the internet.
hope this is of help if you need anymore please ask
Terry
Apr 02, 2008 | Computers & Internet
Palm Treo 750 Smartphone Logo
105 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
