Question about Amana Heating & Cooling
There is frost on the inside of the air conditioner
  • 384 Answers
Dear sir /madam
please make sure your air con is well clean i mean manuel maintenance if it,s already cleaned then it,s showing same problem the it can be low gas problem please contact to your maintenance personnel for further action refill the freon gas.
hope answer the question
pease vote
thank you!
Posted on Sep 06, 2010
PAC L90 air conditioner keeps frosting up. The room air intake frosts up completely, blocking all the air.
Air conditioners frost up when there is a lack of air flow. Clean the filter, check if a belt is broken (if any), check that the fan spins freely, check all in ports and out ports for blockage and clean the coils with mild soap and water.
Jun 08, 2016 | DeLonghi PAC L90 Portable Air Conditioner
We have a ruud heat pump that is developing frost inside it. What should we do?
Frost on the outdoor coils is normal...it will defrost them as neccesary...
Frost on the indoor coils when in cool mode is bad and indicates a low charge or a low air flow condition...
heatman101
Dec 02, 2010 | Heating & Cooling
Barely blowing out of vents even with filter out. Not cooling the house down . The copper line from outside to inside has frost on it
Your indoor motor is going bad and not running full speed...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 04, 2010 | Goodman CLQ36AR49 Air Conditioner
High pressure air cond line has frost about 10 feet inside home
You have a low freon charge or a blockage in air flow. Check the filter if it is clean then there is a low freon charge in your system in which an a/c tech will be needed.
Good luck on repairs
Dave
Jan 06, 2010 | Amana PTH123B35AJ Air Conditioner
Should the small copper pipe inside the air handler have frost or ice on it. If not what is wrong.
The capillary lines will normally freeze during startup and should defrost after a short time. However, if they are remaining frosted, this is a sign of a low refrigerant level.
Dec 02, 2009 | Whirlwind FH-778 Air Conditioner
Fujitsu ASU12C1 is freezing up
unit is freezing up because it either has too much freon or not enough. the pressure should be checked on both the low and high sides and corrected.
Jun 13, 2009 | EMI EHW 18000 Air Conditioner
Our central air has started to not cool. I have looked at the outside unit and lines going from the unit to the inside of the house are frosted. What is the cause and how to fix it?
when lines are frosted you have an air flow problem ie dirty filter or blocked return air grill, fan problem or its low on refrigerant
Jul 14, 2008 | Heating & Cooling
AIR CONDITIONER
Do you have any frost on the lines going to the outside unit. If the large line is frosted your evaporator (Cooling coil in the furnace) could be frozen up. Operating it with the fan in automatic with the cooling on will sometimes be the cause of this condition.
If there is not frost on the large line going to the outside unit and you are getting air circulation inside the house the problem could be a loss of refrigerant charge. Look at the joints where the pipes were soldered to the inside and outside units for signs of oil. If you find oil at any point it is the indication of a refrigerant leak.
May 17, 2008 | Goodman CLQ36AR49 Air Conditioner
Ice or frost on the inside coils of the ac unit
Reduced or no airflow, Evaporator may be dirty. Low on freon.
Jul 31, 2007 | GE AJCQ08ACB Air Conditioner
Heating & Cooling Logo
110 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
