Question about Dell Inspiron 1721 Notebook
I have a Dell inspiron 1721. The screen is dim ... when I try to adjust the brightness it won't adjust any brighter than it already is and makes some type of humming noise at the settings in the middle. Thanks!
  • 2,567 Answers
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Posted on Sep 06, 2010
My dell inspiron 1721 notebook display is dark on the right side and bright on the lefth side
sounds like u need replace the screen on the laptop. i am based in london and have used the company below cost 100 pounds includes fitting and if it wasnt that which i would be very surprised they wouldnt charge you or search the screen up on ebay. hope this helps Help my laptop keyboard is broken
Aug 02, 2012 | Dell Inspiron 1721 Notebook
I am locked out of my dell 1721 by the system/bios password!!
normally on a dell u have to have the power charger plugged in and hold the fn key bottom left and use the arrow keys to make it brighter. however it could be your screen or inverter that maybe faulty. the link below charges 60 pounds for inverter fix which contols the brightness and 100 pounds if it is the screen.
now for the bios password the only way you will be able to remove this is the strip the system down and remove the cmos battery for few mins with no power and put back this should reset it again the company can help you with this if needed. laptop repair london computer repair service no fix no fee
Jul 28, 2012 | Dell Inspiron 1721 Notebook
Hello, can either of you help me with my problem? My "Up" arrow on my keyboard doesn't work. I turned down the brightness (Fn + Down Arrow) until it was very dim while in class, and I now...
Press F2 at system boot up to enter BIOS Settings and look for brightness option and adjust it accordingly under "VIDEO - BRIGHTNESS. Use arrow key to highlight VIDEO then BRIGHTNESS - Press ENTER.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 27, 2011 | Dell Inspiron 1525 Notebook
How do I adjust brightness on my Dell Latitude D6...
Look for a key labeled "Fn" (blue lettering) on the lower left side of the keyboard
Hold the "Fn" key and then use the Up/Down arrows to adjust brightness.
If that doesn't work, reboot your laptop and get into the BIOS. There is a screen for brightness. I don't recall how it is labeled, but it's one of the last pages as you cycle through the BIOS options.
May 20, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
DELL Inspiron 910 Netbook 9
Hi there!
Try to change the setting of the brightness in BIOS,
You can access bios by pressing f2 after you turn on the computer, then you will see brightness there, max out the brightness.
If it still does not work then go to the power options of your laptop then change the setting of the brightness when the charger is plugged in.
Hope this helps!
Mar 20, 2010 | Dell Computers & Internet
Laptop Screen goes dim when plugged in!!!!
Hold down the Fn key then press arrow key up or down.
Aug 10, 2009 | Gateway 450ROG Notebook
Dell Inspiron monitor is hard to see, not as bright
boot and press F2 got to the menu comes up and go to display part in thath where you can increase the display brightness
or press Fn+F5 key while you are in ur OS
Jun 16, 2009 | Dell Inspiron 1521 Notebook
My screen on my dell inspiron 1525 goes dim after a few short minutes and while its in use...do i need to replace the whole screen or just a light or what?
you can try adjusting the screen brightness manually by pressing the blue FN key plus the up/down arrow keys. brighter is FN+UP ARROW. if you have a program called quickset open that and there should be an option under power options/settings. if neither of those solutions fixes the problem then the problem is the screen. a geek squad (1-800-geek-squad) will repair or replace the screen for you. thank you for using fixya!
May 03, 2009 | Dell Inspiron 1525 Laptop Jet Black
Backlight turns off on dell 1721
Seem like you have the bright very high, try dimming a little bit.
Apr 14, 2009 | Dell Inspiron 1721 17" Notebook PC, AMD...
Keys dont work.alternative way to change brightness?
Yes you can go into your display properties and look in the settings tab and look for advanced click that and open color tab or the overlay tab, color tab should get your brightness turned up, And if you can't see you can go into your bios and adjust your brightness from there and get it back to where you can see it if you can't write me back here so we can try another method. Ok I hope that helps you out somewhat, Oh yeah you can also hook up an external key board into your usb connections and you should be able to work everything from that too.
Jan 15, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron 1721 Notebook Logo
428 people viewed this question
Alun Cox
