Question about Poulan Pro Chain Saw 46cc 20"
I have a Poulin Pro 46cc he problem I'm having is with the brake. How can I adjust it to stop the chain.
    Brigadier General:
  • 4,088 Answers
The likely problem is that the 'toggle' mechanism for the brake is plugged with dirt/sawdust and won't allow full travel of the brake. Try compressed air to clean it out. The brake band could also have excessive oil on it--wipe it clean along with the clutch outer drum surface. Hope this helps!
Posted on Sep 06, 2010
How to adjust a poulon pro chain saw 46cc 20" chain tighting
First, I'd read the manual if in doubt. No matter the type of adjuster, tool-less or not, you loosen the bar nuts, tighten the adjuster until the chain just touches the bar on the bottom (while holding the bar nose up) then tighten the bar nuts. Chain should move easily.
Re Poulan chain tightening. Be sure it's oiled and sharp, of course.
Aug 20, 2014 | Poulan Pro Chain Saw 46cc 20"
How do i adjust the module-ignition on poulan pro chain saw model #PP4218AVWhat's your problem?
are you talking about the magneto to the flywheel gap i just use a piece of paper between the two and tighten it
Apr 07, 2012 | Poulan Pro Chain Saw 46cc 20"
Poulin pro chain will not get gas to engine all parts are clean and it has gas
Possible plastic hose running from fuel tank to primer or from fuel tank to carb is broken or cracked. Remove cover to access the carb and inspect hoses for cracks or being broken. Also inside fuel tank the hoses can break off and not be notice from the outside. The hoses can be replaced but not easily. Small engine parts store should have fuel hose.
Nov 26, 2010 | Poulan Pro Chain Saw 46cc 20"
My saw simply will not pump chain oil. Iv'e run it with the bar and chain off and the pump works.Put it back together and nothing. Before reinstalling the bar I blew the saw clean. I had a Sears Poulin a...
Check that the bar oil ports are clean; there should be a small hole or slot on each side of the bar and these can become pluged with sawdust. Also clean the groove in the bar with a small screwdriver or bar cleaning tool every 8 hrs of operation.
If this does not fix the problem check the oil sump screen in the oil tank(usually on the end of a rubber hose); if no screen in tank: remove oil pump and clean(screen is sometimes in oil pump assembly).
Oct 06, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain on my Poulan 20 inch pro will not tighten
If you've got the adjustment all the way out, you may need to remove a link or two from your chain or replace the chain. You can find replacement chains at Partsbuggy.com.
Sep 02, 2010 | Poulan Pro Chain Saw 46cc 20"
Idle
The 'H' and 'L' jet needles on late model saws have 'D' heads requiring a matching screwdriver that only servicing dealers have (thank the EPA). The idle speed screw is owner adjustable and is set so that the chain stops turning, but the engine keeps running. Hope this helps!
May 27, 2010 | Poulan Pro Chain Saw 46cc 20"
How do i loosen chain on my poulan 46cc 20 inch chainsaw ?
Is it fitted with a tool less adjustment device? See Operator's Manual. Normal configuration as below:
d914aed.gif Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Oct 12, 2009 | Poulan Pro Chain Saw 46cc 20"
Chain will not turn
take it back sounds like you have stripped the drive gear
May 25, 2009 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan Pro PP3516AVX chain saw. I used it
Their not the best saws but make sure the nuts holding the bar and cover on are tight after adjusting chain sometimes improper cutting will continue to kick chain off bar.
Mar 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
77 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
