Question about Your One Source Homeline Load Center, 200 Amp
I am trying to install a 100 amp breaker into a Homeline 200 amp load center. Breaker flips every time main breaker is turned on.
  • Larry Sep 30, 2010
    Is this breaker tripping out with anything connected to it?
  • 760 Answers
I'm assuming since it's a Homeline panel you're using a HOM2100 breaker. If it stripping then you must have a short circuit in your 100A circuit, or the breaker is defective. Disconnect your load from the breaker, and turn main on. Be sure you have the correct load conductors connected to the breakers. Typically red and black on the breaker, white on neutral bar. Bare to ground bar
Posted on Oct 01, 2010
I have a 200 amp homeline loadcenter with factory installed breaker the code inspector is telling me that it has to have a bonding screw however there is no tapped hole for a bonding screw. I read that...
For the neutral buss bar, a bonding screw goes through the buss bar into the box. Same for the ground buss bar. Usually, neutral does not meet ground until the meter, so there may only be a bonding screw for the ground buss bar. Look carefully, check with electricians.
Nov 21, 2013 | Your One Source Homeline Load Center, 200...
I have a 200 amp homeline loadcenter with a factory installed breaker and the code inspector is telling me we need a bonding screw however there is no tapped hole for a bonding screw
I checked my code sheet, and only the ground bus is to be bonded to the box. The box comes with a screw that will bond the bus to the box through a bus mounting hole, the threaded hole is down there, behind the bus. The neutral does not get bonded to the box.
I am installing a Siemens 30 Space, 30, Circuit, 100 Amp, Main Breaker, Indoor Load Center, Copper Bus Bars and want to know what gauge of wire I should run from the meter to the 100 amp breaker
I don't mean to be flip, but if you have to ask, you really shouldn't be doing this yourself. You might need to look this up in the "code", but if you don't already know where to look it up, then you are crossing a big DIY danger line here. Good luck and be safe!
Dec 04, 2012 | Cutler Hammer 100 Amp Main Breaker...
Can I change a 100 amp main breaker with a 200 amp main breaker on a homeline box
NO! The main breaker in each box matches the components of that box. Although it might fit, you are looking at a major code violation and possible fire danger. Which if you wanted to sell it later, could give you problems even if it did work and you didn't get have a fire.
Each circuit breaker box it rated to an amperage level and the main breaker is sized for that rating. Find the box tag and check what it is rated at.
Jan 16, 2012 | Your One Source 100 Amp Main Lug Load...
How do i know which breaker goes where into my house.
If the installer didn't fill in the label inside the door you're relegated to turning one off and checking what turns off in the house. You can do this by yourself but it's a lot easier with someone in the house to tell you what shut off as you switch off each breaker in the box. Use things like plug-in lamps or hair dryers in outlets to know when they go dead.
Nov 13, 2010 | Your One Source Homeline Load Center, 200...
Can i replace the main (100 amp) is a sq d QOC20u100F panel with a 200 amp main--i will up grade meter socket and entrance cable to 200 amps cwalker
First the part number QOC20U100F is a flush mount panel cover. The panel you have is most likely a :QO116M100. No you cannot replace the breaker as the bus in the panel is only rated for 100A. In addition I believe this is a 20CKT panel. If you're gonig to a 200A service you'd probably want more spaces than that. Home Depot and Lowes both carry 200A panels with starter set of breakers at reasonable price. The QO panels are a bit better than the Homeline
Here is a link to manual for their panels. :
http://static.schneider-electric.us/assets/DIGEST/load-centers.pdf
Aug 21, 2010 | Your One Source 100 Amp Main Lug Load...
I have a Homeline Load Center circut breaker Catolog # HOM48l125GRB, which was installed for my spa. Each summer the spa is drained and the circut turned off. I turn it back on in the fall. However, this...
You have 1 of 2 problems #1 the breaker overload element is bad=replace breaker, #2 You have a shot somewhere in your line feeding your spa, make sure you have power to the line side of your panel/breaker. hope this helps you...
Oct 03, 2009 | Square Homeline Circuit Breaker
Subpanel hookup
Yes the maximum size branch circuit breaker that will fit in a residential load center is 100 amps. I would recommend that you calculate the amount of power that you need the sub panel to handle, then add any additional loads you may need in the future. Hopefully this is less than 100 amps. I would recommend that you check with your local electrical inspector to make sure your installation meets all local and national codes before proceeding with the install.
Dec 31, 2008 | Your One Source Homeline Load Center, 200...
Your One Source Homeline Load Center, 200 Amp Logo
200 people viewed this question
Top Your One Source Electrical Supplies Experts
Steve
Lisa
Lisa
ray gallant
Are you a Your One Source Electrical Supply Expert? Answer questions, earn points and help others
