Question about Oster 76076-010 Hair Trimmer
Oster clipper parts
Where can i obtain spare parts for my Oster A5 two speed clippers i need a new power lead
  • 193 Answers
Posted on Jun 15, 2009
    Problem Solver:
  • 7 Answers
You can purchase parts by calling 800-830-3678 or on Jardenstore.com - the Oster Professional section.
Posted on Jun 01, 2009
4 Suggested Answers
  • 3 Answers
SOURCE: oster clipper parts
www.clipperparts.com
This is a factory authorized repair shop in the USA. They will sell you repair parts. I wish I had seen your post earlier. Don't throw away or sell your old clippers. I repair Oster 76 and T-Trimmers for a living.
Posted on Apr 28, 2009
philschneide
  • 448 Answers
SOURCE: Bought Oster Golden A5 clippers new but did not
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
Posted on Oct 03, 2009
SOURCE: Simple question: Are the Oster 76 2-speed, the
well the 76 and the golden a5 are almost the same the name plates are different and the 76 uses a toggle switch but the a5 uses a rocker switch. not sure about the crewmaster sorry.
Posted on Sep 27, 2010
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
I have a older oster clipper model22 works fine
you should be able to get whatever parts needed and support at clipperparts.com
Jan 30, 2010 | Oster Golden A5 2-Speed Universal Motor...
Simple question: Are the Oster 76 2-speed, the Oster Crewmaster 2-speed, and the Oster A5 2-speed all the same clipper with different detachable blades?
Oct 03, 2009 | Oster Golden A5 2-Speed Universal Motor...
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
My A5 clipper is not clipping at all.
If the blade mover is going when you turn the clipper on than all you need to do is take the blades apart and clean them well with a Oster spray and then oil them. I would recommend cool lube.
May 12, 2009 | Oster Golden A5 1-Speed Universal Motor...
Where do I put the oil in my oster a5
across the blades were they contact each other.  WD40 works fine.
Mar 07, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 keep turning themselves off whilst I'm clipping
Ok turn your clipper on and hold it still in one hand whilst with the other hold the cable near the end of the clipper and bend it, rotate and twist if your clipper cuts in and out you have a break in the cable which is tricky to fit but our web site Help section can help.
Feb 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster Clipper Bakelite Gear Keeps Stripping
Your armature feed threads are most likely worn. This will continue to wear gears out unless the armature is replaced. Any Oster factory service center such as ourselves should be able to help. John, Shavers World. 313-534-0736
Dec 02, 2008 | Oster Golden A5 2-Speed Universal Motor...
Oster 76076-010 Hair Trimmer Logo
196 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
