Question about Weber Genesis Silver B Grill
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't solve the problem. Any suggestions?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Posted on Sep 09, 2010
Testimonial: "This didthe trick. Thanks so much!"
  • kenneth_e_ne Sep 11, 2010
    excellent--this did the trick. Thanks very much.
  • Reggie McDaniel
    Reggie McDaniel Apr 14, 2014
    Worked for me too, thanks!!
My weber grill doesn't seem to be getting enough gas thruogh the jet to heat to proper temp.
The most likely problem is that food drippings have clogged some of the pin-hole gas outlets in the burner tubes. If those are clean and open, then either your propane tank is not releasing the gas or the controls on the grill are not releasing the gas. If you look at the flame level, probably best done with the flavorizer bars removed, and they are all the same with the controls on high, then it it probably the tank valve. If the flame heights are different, the lower one(s) are the ones where the control valve(s) are not working and need to be replaced. Good luck!
Jul 25, 2011 | Weber Genesis Silver C Grill
I am getting very low blue flames, when I light the back or middle burner the flames get smaller and sometimes go out. Grill not getting hot. Could this be the regulator??
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 23, 2010 | Weber Genesis Silver B Grill
Two burners run too hot with yellow flame.
It sound like your back burners have a partial blockage or possibly are rusting or falling apart or have cracked seams. Remove the cooking grids and burner shields, and examine the burners closely. If you can't find a blockage inside (spider web, bugs nest, etc) then their condition is probably deteriorating. Let us know if you need more assistance.
May 21, 2010 | Weber Genesis Silver B Grill
Flame up & really bad hot spot , flavor bars keep catching on fi
Remove the cooking grids and briquette grid if applicable, so you can see the burners when lit. It should be an even blue flame thoughout. If not, you may need a cleaning or replace burner(s).
May 13, 2010 | Weber Genesis Silver B Grill
Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Apr 04, 2010 | Weber Genesis Silver A Grill
How do i know the coals are still hot and cooking my food and im not sure ive placed them right in weber
Pile the charcoal up in the center of the weber to light them. Wait until they all turn white, most people don't wait long enough. Then spread them out in one layer on the bottom. Put on the grate and cook.
Dec 18, 2009 | Weber Genesis Silver B Grill
How do I take my Weber Genesis grill apart to clean the burners? The burners are not heating up properly. The flame is very poor and not hot enough to cook food.
Turn on just one burner, once it is lit, turn on a second burner, if the flame gets lower or goes out, you probably need a new regulator.
Dec 03, 2009 | Weber Genesis Silver A Grill
Uneven heat from burners
I'm experiencing the same problem, the left side has the least heat, and it seems to be getting way worse over time.  Has anyone found a solution for this yet?
Oct 17, 2007 | Weber Genesis Silver B Grill
Weber Genesis Silver B Grill Logo
3,205 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
