Question about NRS Fleck 5600 - 64,000 Grain Timer Water Softener
Not using salt - NRS Fleck 5600 - 64,000 Grain Timer Water Softener
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 306 Answers
There may a salt bridge in the salt tank. Eductor nozzle may be plugged preventing brine draw.
What model softener is it?
RJ
Posted on Feb 27, 2011
What is a salt
From Wikipedia, the free encyclopedia
This article is about common table salt. For salts in chemistry, see Salt (chemistry). For other uses, see Salt (disambiguation).
Salt deposits beside the Dead Sea. Common salt is a mineral substance composed primarily of sodium chloride (NaCl), a chemical compound belonging to the larger class of ionic salts; salt in its natural form as a crystalline mineral is known as rock salt or halite. Salt is present in vast quantities in the sea where it is the main mineral constituent, with the open ocean having about 35 grams (1.2 oz) of solids per litre, a salinity of 3.5%. Salt is essential for animal life, and saltiness is one of the basic human tastes. The tissues of animals contain larger quantities of salt than do plant tissues; therefore the typical diets of nomads who subsist on their flocks and herds require little or no added salt, whereas cereal-based diets require supplementation. Salt is one of the oldest and most ubiquitous of food seasonings, and salting is an important method of food preservation.
Some of the earliest evidence of salt processing dates back to around 6,000 years ago, when people living in Romania were boiling spring water to extract the salts; a saltworks in China has been found which dates to approximately the same period. Salt was prized by the ancient Hebrews, the Greeks, the Romans, the Byzantines, the Hittites and the Egyptians. Salt became an important article of trade and was transported by boat across the Mediterranean Sea, along specially built salt roads, and across the Sahara in camel caravans. The scarcity and universal need for salt has led nations to go to war over salt and use it to raise tax revenues. Salt is also used in religious ceremonies and has other cultural significance.
Salt is produced from salt mines or by the evaporation of seawater or mineral-rich spring water in shallow pools. Its major industrial products are caustic soda and chlorine, and it is used in many industrial processes and in the manufacture of polyvinyl chloride, plastics, paper pulp and many other products. Of the annual production of around two hundred million tonnes of salt, only about 6% is used for human consumption; other uses include water conditioning processes, de-icing highways and agricultural use. Edible salt is sold in forms such as sea salt and table salt which usually contains an anti-caking agent and may be iodised to prevent iodine deficiency. As well as its use in cooking and at the table, salt is present in many processed foods. Too much sodium in the diet raises blood pressure and may increase the risk of heart attacks and strokes. The World Health Organization recommends that adults should consume less than 2,000 mg of sodium which is equivalent to 5 grams of salt per day.
Jun 10, 2014 | Measuring Tools & Sensors
Tip
Water softener salt bridging
One of the most frequent problems with water softening systems is salt bridging in the salt/brine tank. There are several reasons for salt bridging to occur. This generally occurs when pellet type salts or potassium chloride is used to regenerate the water softening system. Pellet type salts contain binding agents that in turn give the salt a very starchy consistency when wet. As water evaporates in the brine tank the pellet salts partially dissolve, bind together and form a "salt bridge" in the tank. Potassium chloride (Kcl) acts in the same way. Excess water in the salt tank, with high salt levels, can also cause salt bridging. Improper softener brining and lack of proper brine refill will cause bridging to occur as well.
What is the best way to alleviate these problems?
1. When using pellet type salts or potassium chloride only keep the salt tank about 1/2 full. This prevents too much compaction of the salts and helps to prevent bridging. When using potassium chloride get the salt tank off the floor on a wooden platform to prevent wicking of moisture from concrete floors.
2. Use a high grade of salt. Most water treatment dealers use either
DuraCube or HardiCube water softener salts produced by Cargill Corp.
Cargill has a link to find dealers in your area.
https://saltapps.cargill.com/cargillsalt/product_locator_new.asp
Solar Salt is another option as the crystal structure is very hard and virtually impossible to bridge. This is also available from many Cargill salt dealers and in stores.
3. Let the salt tank run down to 80-100lbs of salt or potassium a couple times per year to help prevent buildup of dissolved salts in brine tank.
4. Yearly maintenance of the water treatment system helps also. Restrictions in the brining system (injector/eductor assembly) caused by sediment and oxidized iron buildup cause improper brining and too much water in salt tank during refill. Have this assembly cleaned yearly. Have the water tested to see if the water chemistry or usage have changed and adjustments to the system are necessary.
5. Avoid using rock salts to prevent buildup of sediment in brine tank (which causes service problems).
Practice these tips and you will have fewer water softener problems and more consistent quality softened water.
I wish you good water!
H2O Services
on May 17, 2011 | Water Dispensing & Filtration
What do these lights mean there not going off
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in
dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water
softener. Only fill with salt just before starting one of the washing
programmes. This will prevent any grains of salt or salty water, which
may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse
aid dispenser with any other substances (e.g. dishwasher
cleaning agent, liquid detergent). This would damage the
appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
I Have a Easy Set Pool 15X36, And a Salt Water Generator How much Salt do I add for the first Time?
The Compupool CPSC/CPA Series is recommended to run at a salt concentration of 3500 ppm. If you are not installing a Compupool unit, check your manufacturer's instructions for their recommended level of concentration . Use a salt that is at least 99.8% pure NaCl. The preferred salt is an evaporated, granulated, food quality, NON-iodized salt. Avoid using salt with anti-caking agents like sodium ferrocyanide, also known as yellow YPS (prussiate of soda. These cause some discoloration of fittings and pool surface finishes. DO NOT use calcium chloride.
Using a salt water test strip, measure the current salt level of your pool. For the Compupool generators, ideal is 3500 ppm. If the level is low, determine the number of gallons in your pool and add salt according to the Salt Table. For example, if your pool has 15,000 gals of water and your current salt level is 2500, you need to add 125 lbs of salt.
Jun 08, 2011 | Sport & Outdoor - Others
Where do i put the salt
Hello Maria,
The salt goes in the salt compartment in the base of the washing compartment. Unscrew the lid of the salt compartment (counter-clockwise), pour in salt until the compatment is full or nearly full then screw the lid back on firmly, but do not overtighten it.
If the dishwasher is new and you are using it for the first time, pour about 1 litre of cold clean water into the salt compartment before adding the salt. If you spill any salt or the water spills over the top of the salt compartment, it will wash/drain away the next time you use the washer.
The most important thing is to only use dishwasher salt. The salt is used for water-softening and only salt sold specifically for dishwashers can be used for this purpose.
The picture above is from a Bosch dishwasher. You may have another brand or model of dishwasher, but the salt compartment will still be in the base of the washing compartment and will have a cap which you unscrew as above.
Hope this helps. If you need further assistance, please let me know the brand and model number of your dishwasher.
Regards,
BElectric
Mar 14, 2011 | Dishwashers
My dishwasher says that it needs salt what sort of salt and how much?
HOW MUCH SALT DO I NEED TO ADD?
shim.gifYour machine may have a float indicator or a warning light to tell you when salt needs adding to the water softener. Often float indicators are difficult to see, and there is no accurate guide as to how much salt you need to add. Quite simply, just add granular salt to the reservoir until it won't take any more!
The softener will use the salt to replenish itself each time you wash. As an approximate guide, you should do a full top up about once a month. If your machine doesn't have a warning light, a good way to remember to check and / or top up is to do it on a regular day of the month (e.g. the first Saturday or the 15th)
CAN I USE ORDINARY TABLE SALT?
No. Table, cooking, rock and sea salts may contain additives that can actually increase water hardness. Also, the fine consistency of some of these salts mean they are likely to clog when wet. Always use granular dishwasher salt because it is very pure and is the right consistency for use in your machine.
Granular salt is the ONLY type of salt that should be used to regenerate the softener. Be aware that some varieties of 'dishwasher salt' use Dead Sea salt. This variety may contain minute insoluble organic matter that may adversely affect the resin within your softener over time. If you are in doubt about the origins of the salt, ask the retailer or manufacturer.
Sep 30, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
What kind of salt do I buy for use in the Danby DW?
Well Dishwasher salt is a particular grade of sodium chloride salt, and is used for recharging the built-in ion-exchange resins of the water softener in dishwashers that have a built-in water softener. The salt particles are larger than the size of table salt particles, and dissolves slowly enough that it will not clog the softener unit. This salt does not have added iodide salts, and it should have minimal amounts of iron and manganese salts. Some dishwasher detergents are marketed as not needing dishwasher salts. These detergents use higher levels of phosphate that increases the solubility of hard water ions. Never use table salt or detergent in the salt compartment of your dishwasher as this will damage your water softener unit. You can purchase the dishwasher salt from the below link -
http://www.mysupermarket.co.uk/grocery-categories/Dishwasher_Salt_In_Tesco.html
Good Luck!!
Thanks
Jan 07, 2010 | Danby 17 in. DDW1802W Designer Series...
Put rock salt in instead of dishwasher salt wat damage has been done if any
Salt? Why are you using salt to begin with? Why are you not using the liquid soaps etc. If your one of those all natural people i use all natural liquid etc. Salt is corrosive and parts that are not stainless steel will corrode quickly!
Jun 03, 2009 | Dishwashers
Salt for DDW1805 Danby
I use ordinary household water softener salt crystals, not pellets, or table salt. The table salt often is not as refined as softener crystals, and can damage the dishwasher's softener in time. Also, the water softener salt comes in a large bag (around 25-50 lbs) for about $6 US.
Jul 12, 2008 | Danby DDW1805W Designer Series...
Salt indicator light comes on?
Check the instructions which are freely available from www.miele.co.uk or the relevant site for your country. Browse to the current models and you should find the PDF for your model. For non-current models, instructions are under the link "Customer Support".
In general, the instructions are as follows:
If the water in your area is very soft and constantly lower than 0.7 mmol/l (4 °d) you do not need to add dishwasher salt. The water softener must, however, still be programmed to correspond to the water hardness level in your area. (The salt indicator light will still come on, but should be ignored).
Important: Before filling the salt reservoir with dishwasher salt for the first time, you must fill it with approx. 2 litres of water to enable the salt to dissolve. Once the dishwasher has been used, there is always sufficient water in the reservoir.
Inadvertently filling the salt reservoir with powder or liquid dishwasher detergent always leads to serious damage to the water softener. Make sure you have picked up the correct packet of dishwasher salt before filling the salt reservoir!
Only use special coarse grained dishwasher salt for reactivation. Do not use other salts such as cooking salt, agricultural grade or gritting salt. These may contain insoluble additives which can impair the functioning of the water softener.
To refill:
* Remove the lower basket and unscrew the salt reservoir cap.
* Fill the reservoir with approx. 2 litres of water (first use).
* Place the funnel provided over the salt reservoir and carefully fill with salt until the reservoir is full. The salt reservoir holds approx. 2 kg of salt depending on the brand used.
As the salt reservoir is filled, displaced water will overflow.
* Clean any excess salt from around the reservoir opening and then screw the cap on again firmly.
* Run the "Pre-wash" programme immediately to remove any traces of salt water from the cabinet.
For the Miele, the salt reservoir is usually under the bottom basket, the cap is usually grey in colour. [Only the latest models have the refill cap in the door itself].
You should be able to find dishwasher salt just about anywhere, I've even found it in Malaysia, sold at good ol' Tesco!! Brands of salt include Calgonit (Finish) & Somat.
Jan 05, 2008 | Miele 24 in. Novotronic G641 Plus Built-In...
NRS Fleck 5600 - 64,000 Grain Timer Water Softener Logo
154 people viewed this question
Top NRS Home Experts
Donni Steen
john h
Bill Boyd
Are you a NRS Home Expert? Answer questions, earn points and help others
