Resetting the date on a Mitsubishi VCR HS-E51 (NZ)
The VCR manual describes the date setting process for this model very well, however, it only goes up to the year 2003! Problem solving requires a year between 1989 thru 2003 that is identical to 2008........., please.
  • 1PAL May 13, 2008
    Helpful, but not the total sulotion, as I suspect this may only be useful for a few years.....................!
  • Anonymous Jun 11, 2008
    i have the same problem :(
  • 1,512 Answers
Hi 1pal
2003 has christmas day Dec 25 on a thursday, but this year was a leap year...hmmm Give it a try. We are past Feb, and will remain the same till the next leap year... and then you may have to put a peice of gaffa tape over the dial.... :)
ex pat
robotek
Posted on May 13, 2008
Manual for mitsubishi hs-u790
Try the Mitsubishi website they might have a free PDF of it
Mar 12, 2012 | Mitsubishi HS-U790 S-VHS VCR
I have a reconditioned VCR HS-521V(IR) and I want to set the date but the year ends at 2009. can I change this date.?
Unfortunately no! the vcr has a built in calender that is limited to the year 2009 that was programmed at the factory. The only way to change this, is reprogramming it with specially equipment.
Apr 08, 2011 | Mitsubishi Televison & Video
Purchased in 1996. The date setting does not extend beyond 2010
No only in service can if it posible to reprogramed the EPROM.
Mar 11, 2010 | Televison & Video
Mitsubishi HS-U500
Just set it to record"today" choose the correct day and month,the year will be unimportant.
Sep 24, 2008 | Mitsubishi HS-1280U VHS VCR
Language setup for Mitsubishi HS-U510 VCR
I contacted Mitsubishi support. It is very likely the 510 and the 520 are similar. I was told to look at the back of the VCR (in the middle and lower) for a "timer reset" button. Pushing it will put you into initial setup mode and you can set your VCR to english menu. It works!
Ronrr
Jul 14, 2008 | Televison & Video
Setting date and time on a Mitsubishi VCR
My Solution for Mitsubishi HS-U500 VCR setting the date for 2008 and beyond:
I had same problem with this old unit as everyone else has.  Since the year really doesn't matter (except maybe when you're setting to tape near a new year), here's how to get the day and dates correct:
On the remote, push Menu button, then select "First time setup", then select "Set the Clock", then select the month.  Now, start adjusting the YEAR and watch how the "days" change with the years.  Adjust the years so that the "Day" (Monday, Tuesday, etc.) matches the date (1,2, 22, 23, 28, etc.) in the month.  Then cycle thru the rest of the items and get out by hitting menu button again.
That's it!  That's my quicky solution.  Caveat: This may not be permanent with leap years and the like, so you may need to check it from time to time to make sure the days match up with the dates.  But you can do this when you go to set up for timed taping.  Hope that "FIXes" it for "Ya"!
Jan 22, 2008 | Mitsubishi HS-U595 VHS VCR
How to set the clock
Check here for a similiar model: http://download.jazel.net/misc/filecache/3f/3fca776cb32a0a5f4402168c2ef88bbe_1071-ManualHSU448.pdf You have the remote box? Most functions, clock/date set, channel add/delete and so on are done with the remote, and cannot be so done with the limited buttons on the VCR itself. Early VCRS (pre-90s) were setup with these VCR located buttons.
Aug 25, 2007 | Mitsubishi HS-U446 VCR
Mitsubishi HS-U447 VCR in Lock or "Loc" mode
Hopefully you still the VCR. Your's is stuck in "CHILDLOCK" mode. To release the lock you have to have the remote and press the DISPLAY for 8 to 10 seconds.
The purpose of the CHILDLOCK is to prevent others from using your VCR. If you want to set the VCR back on Lock you again press the DISPLAY for 8 to 10 seconds.
This solution is from the owner manual for HS-U448, so I figure your model is the same.
Mar 06, 2007 | Mitsubishi HS-U447 VHS VCR
Televison & Video Logo
394 people viewed this question
Top Televison & Video Experts
