Question about KitchenAid KUDS24SE Built-in Dishwasher
How do I replace the detergent dispenser(W10224431) in a Kitchen Aid dishwasher. I've replaced the door twice. It worked for a few weeks and then stopped functioning. Maybe replacing the whole unit will be better since the latch on the old unit may not be working properly. Please advise. Thanks. Sincerely, Manfred Einnatz
  • 11,896 Answers
Disconnect the power source to your dishwasher before you conduct this or any other repair. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel
Before you can begin to replace your dishwasher's wax motor, you must first locate the device. It is located within the door assembly, in very close proximity to the detergent dispenser cup. You will need to gain access to the inside of the door.
Examine the outside of the appliance. Depending on the model, you will have to remove either the entire internal door panel, or the entire external door panel. In each case, the panel can be removed by removing anywhere from 6 - 10 screws. Be careful to not remove the screws at the very bottom of the door that are actually a part of the hinge assembly. Removing the hinge assembly screws will remove the entire door from the appliance, which is not at all necessary to replace the unit's wax motor. With all of the screws removed, the door panel should be easy to lift off of the door assembly. If you have difficulty lifting the panel, look for additional screws you may have missed.
With the door panel removed, locate your dishwasher's detergent dispenser cup and the wax motor assembly.
There are two wires connected to the wax motor. Label them so that you will be able to correctly reconnect them later. Remove each of the two wires from their respective terminals - they are connected with slip-on connectors. When removing the wires, grasp the connectors and pull firmly. Do not pull on the wires themselves. You may want to use a pair of needle-nosed pliers to help you. Now that the wires are removed, remove the wax motor.
Discard the used motor and connect the wires to the terminals of the new motor. Position your new wax motor in place of the old one. Replace the door panel and restore power to your dishwasher.
Posted on Sep 06, 2010
Where do you put rinse aid
For most dishwashers, there will be port on the door. Usually it will be near the detergent dispenser. On mine, the two items are in one grey plastic enclosure. The rinse aid port is on the right side of the area as you look at the dishwasher door from the front of the dishwasher. Look for a knob surrounded by a few numbers and a few symbols/words. In one direction, the dispenser will be closed; no rinse aid will be released. Turn the knob fully in the other direction, it's open and the cover can be pulled up to allow for refilling the dispenser.
I hope this helps. Please add a comment with your dishwasher's make and model number for more information.
Apr 06, 2015 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Dishwater detergent door not working
replace the dispenser mechanism...the little solenoid inside has failed that triggers the door to open.
Feb 06, 2012 | LG LDF6810ST Stainless Steel Built-in...
How do I replace myself the detergent/rince aid assembly on a Maytag Jetclean dishwasher EQ plus model #MDB9150WB? I only need to replace the door, but I don't see a part for that, just the entire...
Carol,
This is a simple repair. Remove the screws around the outer door edge and separate the door. The dispenser is clipped into position with several screws. Remove the screws and push the dispenser through the door.You can purchase the part from the link below.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Tub leaks, with a partially filled tub (2.5 inches measured from the lowest point over the pump assembly.) Promblem occured after the washer was idle for 3 weeks. Have just replaced the main water inlet...
I am assuming leaking when it is running, not sitting idle. Leaking from the door? Fill and run unit for 1 minute with no detergent. Open door. Are suds present? Suds turn into water when they drop to the floor. Suds can flow over the lip of the tub and drip to the floor. Oversudsing, Sometimes old detergent breakdown. Rinse aid dispenser leaking will cause oversudsing. Combination of all in one products will cause many problems. If suds are present after running unit a minute, pour a cup of cooking oil in unit. Run and fill it a few times until suds are gone. Possible most common cause is dispenser latch grommet.
Oct 15, 2010 | Maytag MDB7100AWB Dishwasher
The door to the dishwasher detergent receptacle does not open during the cycle. We have tried cleaning it out, using far less detergent and being very diligent about the Rinse Aid but nothing seems to...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Oct 08, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
Soap dispensor on kitchen aid dishwasher is leaking
First try rinsing out the dispenser cup and switching to a gel detergent.
Second,the door is spring loaded, and the spring may need to be replaced.Do this byturning off the electricity, then removing the front panel of the dishwasher-loosen screws holding the cup to the door and replace the springs. If the cup does not have springs, then it probably works on a was motor or bi metal switch that can be changed.
I can also be a defective timer switch
Sep 19, 2010 | KitchenAid 24 in. KUDP01DLBS Free-standing...
I have a built in Kitchen Aid Dishwasher and my rinse aid dispenser has been full for weeks
since it only uses a few drops each cycle it it quite possible it looks full
a full jet dry resivoir, will last about 6 mos
Oct 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
302 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
