Question about Epson Stylus 880 InkJet Color Printer
Can i use this printer to print to paper tranfer?
    Scholar:
  • 142 Answers
Epson Stylus Color 880 InkJet Printer can print on different kinds of media, including "Iron-on Transfers".
See this brochure for details.
Posted on Sep 06, 2010
My printer is only printing white paper
LOOKS LIKE YOUR DEV TANKS ARE GONE/TRANFER/OR EVEN A DEFECTIVE TONER CARTRIGED
Nov 16, 2013 | Epson Stylus Office Equipment & Supplies
Printed labels yesterday, after which there were shadows and miscellaneous markings on all subsequent print outs. Found, and removed, a lead tab from the label sheet that had stuck on printer...
Welcome to FixYa!
Solution 1:If you can reach reach for the rollers, clean it with a cotton moisten with a cleaning solvent (an alcohol will do) .
Solution 2.Purchase a "printer roller cleaning paper" from a computer store or an office supplies store.
Note: After the cleaning process from solution 1 or 2, the markings will not immediately go away, it will still take some time but it will surely help speed up the cleaning of the rollers.
Thank you for using FixYa.Have a great day.
Jas
Dec 01, 2011 | Samsung CLP 315 Laser Printer
My wife tried to print on T-Shirt tranfers meant for ink-jet printers, and they melted onto the fuser roll, and it stinks. I need to remove the fuser assembly and clean it, but could use some instructions....
This might help. I did the same thing with my laserjet printer.
Staples has laserjet cleaning sheets. I ran several sheets through the printer after I pulled most of the transfer paper out.
The sheets are one use sheets so, you will need a few.They are impregnated with cleaning fluid on textured paper.
These sheets clean the entire paper travel path.
Dec 12, 2009 | Brother MFC-7820N Laser Printer
Magenta and yellow ink not printing on test print
Print head is probably plugged. With caution (this can ruin your printer if you get too violent) take a Q-Tip wet with rubbing alcohol and touch the printhead where the ink tranfers to the paper. To get access to the cartridge open the cover and when the carriage moves to the center unplug the printer. The alcohol may soften the dry ink enough to get it printing again. If it starts printing again do a print cartrige cleaning with the software included with the printer.
Jul 11, 2009 | Canon i860 InkJet Photo Printer
All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
Fixed a paper jam, printer started to print one line
When the printer jamed and you had to pull out the jam, the data being tranfered for that job got out of sequence. On Deskjets when that happens, you need to go to the print spooler and delete the job it is printing or you will have the same problem evertime.
Mar 06, 2009 | HP DeskJet 895cse InkJet Printer
Printing fuzzy
Sorry for the delay in getting back to you.
There are several things that can cause these problems.
Low grade toner. Have you noticed that fuzziness is always the same color or not?
A weak "Charge Roller" not charging the PC as it should.
A problem with the spinning mirror inside the laser unit.
The "Transfer Roller" not charging the paper properly.
To high a charge on the paper could cause artifacts on the PC to be pulled to the paper.
The fuser roller not getting properly cleaned and depositing residual image back on the paper.
Paper slipping in eiter the Tranfer Station or the Fuser.
I would suggest you place a service call on the unit and let a factory trained tech diagnose the failure for you.
Don
Jan 14, 2009 | Lexmark C762 Laser Printer
HP 5550 Laserjet prints dark
The only time I saw a color laser Printing darker than normal the issue was tranfer belt. The condition you describe matches the problem I was involved in and the tranfer kit fixed the problem.
Hope this helps
Aug 28, 2008 | HP LaserJet 5550 Printer
Extra background color in my printing
You really should not run labels through this machine unless they are full sheets. If you are running used pages the glue will build up on the tranfer belt and cause the hazing.
Jul 28, 2008 | HP Color LaserJet 2600n Printer
Printing t-shirts
Unfortunately, you can't print directly on to t-shirts. You have to print onto transfer paper, which you then iron on to the shirts.
Regards,
Javabytes
Nov 18, 2007 | Compaq A3000 All-In-One InkJet Printer
Epson Stylus 880 InkJet Color Printer Logo
66 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
